Old 06-11-2018, 02:07 AM   #176
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Getter-Done View Post
Nice. That a good looking rollback.
It will look even better as a 4wd.
The Dumptruck is getting the K30 treatment, and the rollback is complete and I am glad you like it. It drives and rides awesome!
fishnixon is offline   Reply With Quote
Old 06-11-2018, 11:29 PM   #177
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Got the driveshafts out including carrier bearing. I also got all bolts out of the leaf spring mounts and left one bolt in loosely on each so I can still roll the beast out of the garage and strip the front axle out at the trucks final resting place. It took me awhile...I guess I am a slow worker.
Old 06-11-2018, 11:38 PM   #178
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
While I was working “slowly”, I was thinking about the question earlier about matching up the gear ratios front and back...looking at the pumpkin on the Beast, the first picture, the thought hit me that Dolly’s rear end looks the same, the second pic. I think I have it figured out...I’ll take the ring and pinion from the donor and put them into Dolly, while retaining the dual wheels...a benefit of not rushing things...hope this idea works out.
Old 06-12-2018, 07:18 AM   #179
Getter-Done
Getter-Done's Avatar
Re: Dumptruck Dolly
You could take the cover off the back of both rear-ends and count the teeth.
You may get lucky. If there the same you won't have to change anything.
84 Chevy K-20
Old 06-16-2018, 11:58 PM   #180
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
That’s a good point, and an easy task. Thanks. I’ll have to check the pumpkins for tags (including the front differential)...might even get more lucky!
Old 07-07-2018, 07:16 PM   #181
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Got back to the project. Took the front end, cab, motor, trans and transfer case off/out of the donor truck today.
Old 07-07-2018, 07:19 PM   #182
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Used the excavator to pull the motor/trans/TC.
Old 07-07-2018, 07:23 PM   #183
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Here it is after one round with the pressure washer. I sprayed WD40 all over afterwards, and I’ll do another round to clean it up some more. I am not too worried about how clean THIS V8 is at the moment...
Old 07-07-2018, 07:37 PM   #184
Getter-Done
Re: Dumptruck Dolly
Nice Progress.
I like your engine hoist.
84 Chevy K-20
Old 07-08-2018, 08:25 AM   #185
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Nice Progress.
Thanks, I had some time off this past week, and had a chance to get to it.
Gotta love heavy equipment, yet you have to make sure EVERYTHING’s unbolted because the whole truck will be up in the air before you know it...and/or you’ve bent or broken something.
Old 07-21-2018, 01:44 PM   #186
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Got some work done today, not glamorous, but necessary. This is what’s getting thrown out to the metal pile.
Old 07-21-2018, 01:50 PM   #187
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Here is some of the stuff I am keeping. I still have to tear apart the cab.
Old 07-21-2018, 01:53 PM   #188
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Down to the frame… Now I can get after the crossmembers easily.
Old 07-21-2018, 11:31 PM   #189
cornerstone
cornerstone's Avatar
Re: Dumptruck Dolly
Is the grill on the 67/8 so bad that you cant sell some of it? looks fairly decent from this pic... I'd bet some guys would take it off your hands if its just scrap to you.
cornerstone is offline   Reply With Quote
Old 07-23-2018, 10:53 PM   #190
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Twisted, dented...it can be a project for somebody with a lot of time. First come , first served...must take whole clip.
Old 08-09-2018, 12:48 AM   #191
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Took out the crossmembers today.
Old 08-09-2018, 12:53 AM   #192
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Front axle and leaf springs removed from the Blue Beast... I have to finish removing the rivets from the rear mounting points. Then, cleanup on the parts will start.
Old 09-15-2018, 07:35 PM   #193
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Well, I am back...I made a list of front end parts for 4x4 rebuild and called LMC...quick delivery.
Old 09-15-2018, 07:39 PM   #194
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I want to use the original hardware so I spent time removing this rear mounting point for the shackle...they put up a fight, but you’ll see that I got it done.
Old 09-15-2018, 07:44 PM   #195
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Refer back to the above photo of the parts list, and you’ll see notation of “Spring Eye Bushing, Qty 2. Here it is...and when I looked at it, I knew that it was not intended to be used with the original hardware mentioned above. What I really needed was new rubber and the inside sleeve...the metal casing has to go.
Old 09-15-2018, 07:48 PM   #196
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I drove out the metal sleeve with my shop press...on the left is the new sleeve (much bigger) and the original sleeve on the right...
Old 09-15-2018, 07:53 PM   #197
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
A bigger sleeve going into the original hardware means the new rubber won’t fit...but a saved heater core hose fits great with a little help of liquid dishwashing soap...check that out!
That is what I had time for today.
Old 09-15-2018, 08:13 PM   #198
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Oh, I did one more thing today...I made a template with measurements for the upcoming fabrication and installation of these mounts. Don’t look too long...it kinda gives me a headache.
All measurements were taken from the front edge of the cab mount...both right and left.
Old 09-16-2018, 07:28 AM   #199
72 tigger
72 tigger's Avatar
Re: Dumptruck Dolly
Nice progress- you’re doing things the right way
72 tigger is offline   Reply With Quote
Old 09-16-2018, 08:55 AM   #200
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks...
