Old 07-25-2018, 11:03 AM   #51
daddyjeep
daddyjeep's Avatar
Re: "Outkast" 1985 C10 in Hawaii
I'll throw another vote for the grey. I really don't think there is another choice. These trucks just seem to look right with those old aluminum caps on them. I got one for mine and planned on just putting it on when I needed it it but it has stayed.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-06-2018, 11:23 PM   #52
BIGglaSS
BIGglaSS's Avatar
After removing the rear bump stops, any trouble with the axle hitting the frame?
BIGglaSS is offline   Reply With Quote
Old 08-07-2018, 02:38 PM   #53
808_67C10
808_67C10's Avatar
Not at all... I just have a flip kit so, there is about 5" of travel without the bump stops and brackets. I have had some weight in the back too - a couple full kegs and giant coolers of ice and she never hit the rails.
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 08-15-2018, 05:38 PM   #54
808_67C10
808_67C10's Avatar
Well, I finally got her running smooth, its been a challenge. The PO had the original distributer in the newr crate GM 350 and it didnt have any advance on it, mechanical or vacuum. So, Got a MSD HEI dizzy with vacuum advance and got everything tuned like it should be and bada bing bada boom!
I put my rallys back on too... the US Mags just look plain for an aftermarket wheel on the white... I get more props with the rallys on for some reason.
Old 09-20-2018, 03:38 PM   #55
808_67C10
808_67C10's Avatar
Sorry I have been off the site for a bit. Since I got the truck running good, I have just been driving the hell out of it and working on my Harley so, no real updates on the C10.
I am about to do some changes in the interior so, stay tuned for that. I am keeping it relatively stock but, trying out something I did with my 67 that turned out really well.
Old 10-22-2018, 07:25 PM   #56
808_67C10
808_67C10's Avatar
Finally finished up restoring the shell and putting it back on.
Old 10-22-2018, 11:18 PM   #57
BIGglaSS
BIGglaSS's Avatar
Perfect!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
Old 10-23-2018, 07:24 AM   #58
Old 10-23-2018, 11:56 AM   #59
808_67C10
808_67C10's Avatar
Thanks all, it turned out pretty good. Now I need to move on to the next task of getting some sounds in the truck. Someone cut the doors out for 6x9s along the way and a hole to get to the window motors. It looks like they used a butter knife to do it... I am going to make a panel to cover the bottom of the door and hopefully match the look. Then move the 6x9s to the back in the corners with a singe 12" KICKER sub.
I need to find a good fitting saddle blanket seat cover. I got one off amazon and it barely covered the seat and the damn string that holds it on all broke because of the slippery pleather seat. Any ideas?
Old 10-23-2018, 10:58 PM   #60
BIGglaSS
BIGglaSS's Avatar
Honestly, I wouldn't bother with the 6x9s. Properly tuned front speakers + a sub will be plenty. What do you have for amp and head unit? Let me know what 12" you have and I can help you design a box.
I haven't read any good reviews on saddle blanket seat covers. It sounds like they don't make them like they used to. I'm just going to do a new cover from Acme via rock auto. If you need new seat bottom foam you can get thru ebay: https://www.ebay.com/itm/12548992-MF...0/162357301815
Old 10-24-2018, 04:59 PM   #61
808_67C10
808_67C10's Avatar
I have a new Alpine head unit, an Alpine 550 single out amp, 2x 4" coax in the dash, a Kicker 3x9 in the center of the dash, 2x Kenwood 6x9s and a kicker 12" - I think I am gonna get the alpine power pack for my front speakers too...
My only concern is the mounting depth of the 12. I dont want to have to move my seat up if I dont have to. By my measurements, I have 4" at the top of the box and 8.5 at the bottom which makes the 5.5" mounting depth of the 12 really close.
Old 10-25-2018, 01:34 PM   #62
LT7A
Hey 808, good progress. Canopy looks good too!
Old 10-27-2018, 09:45 PM   #63
BIGglaSS
BIGglaSS's Avatar
Those measurements sound about right. Box volume is more critical than depth, and you can adjust that with width. My box was .7 cu/ft not counting the port area. For a sealed 12, it will have to be a bit wider than what I built. What's the model # of your kicker 12?
Old 10-28-2018, 06:49 PM   #64
808_67C10
808_67C10's Avatar
Here is my plan... I have two 12" Kicker COMP Subs.... the box measurements I came up with are 49" wide the top is 4" deep and the bottom is 8.5" deep. I am using 1/2" MDF and I figured it out to be about 1ft of air space per sub - sealed. I'd rather go ported for depth but, I am okay with sealed - and its less work! LOL Right now, I only have the Alpine M650 (550W) amp and its a single channel set up so, I can run both 12s in series until I get another amp.
I am also debated just building a box for one sub and running all the power through it... It will give me room to put crap behind my seat too. What do you think?
Old 10-28-2018, 10:41 PM   #65
BIGglaSS
BIGglaSS's Avatar
These?:
https://www.kicker.com/comp-12-4-ohm-subwoofer
If you can fit it, I think it will work OK. My box is 7.5" at the bottom with the seat all the way back. I'd go sealed with as big of a box that you can fit. I wouldn't go ported with that sub/amp combo, plus the box size would be huge. You would also need the theile/small parameters from Kicker and run it through a modeling program to calculate volume and port tuning.
Kicker doesn't provide enough parameters to run it through a modeling program, so I wasn't able to come up with an "optimum" size. However in the owners manual, it says 1.25-3.5 cu/ft sealed.
Here's a calc that I use for box dimensions/volume:
http://www.bcae1.com/spboxnew2.htm
That's slightly too much amp for those speakers. But, it should be fine if you keep the gain set low. Wired parallel (optimum), it will see a 2 ohm load. Wired in series (8 ohm) I don't think there is enough power. Whether you run one or two comes down to how much space you want to sacrifice.
What were you thinking about for changing amps?
Old 10-29-2018, 08:59 PM   #66
808_67C10
808_67C10's Avatar
These?:
I think that was the same link that I used to figure out my volume when I did my measurements a little while back. I came up with 1.2ft of airspace for each 12 which should be pretty close.
I plan to cut the box out Wednesday and start slamming it together to finish it by the weekend. We will see. As for the amp, thats what I have right now and dont want to spend too much on another right now - we will see what I can dig up though. I am still saving to turn my life savings over to ridetech for a bag set up "someday".
Old 11-05-2018, 03:15 PM   #67
808_67C10
808_67C10's Avatar
Here is my Monday status report. Got the box for the 12s build and made some wings for the 6x9s... Its still kind of raw - debating on what I am going to do about covering them but, I got a cool idea... gotta check back to see where this goes.... !
Old 11-09-2018, 09:04 PM   #68
808_67C10
808_67C10's Avatar
This weekend its on like donkey kong! Gonna finish up the box, cover it and start wiring up my amp and massage chair (my 12s). I have installed my Alpine Power Pack too. Then its time for tuning. Alpine has an app for that... pretty cool!!! Hopefully, I will have more pics on Tuesday.
Happy Veterans Day to all who served!!! Freedom aint free!
Old 11-10-2018, 10:04 PM   #69
BIGglaSS
BIGglaSS's Avatar
Excellent! git-r-dun
Old 11-11-2018, 07:11 PM   #70
Whamo
Whamo's Avatar
Dig the C Shell
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
Old 11-12-2018, 08:15 PM   #71
808_67C10
808_67C10's Avatar
Old 11-13-2018, 11:22 AM   #72
808_67C10
808_67C10's Avatar
Got it covered. Not sure if I like it yet... I wanted it to look a lil retro to match the truck. That fabric was a nightmare to work with. It frayed and came apart with every cut. It sounds pretty damn good though... the mass volume of speaker helps. Now I need to spend some time and tune it. The Alpine app is pretty complicated and I have a lot to learn to get it where it should be... for now though... she pumps!
Old 11-15-2018, 01:44 AM   #73
808_67C10
808_67C10's Avatar
Originally Posted by Whamo View Post
Dig the C Shell
Thanks bro... I get good and bad comments about it! I appreciate the support! The comments have swayed to the positive side now that its grey though... plus, I can put my dogs in the back of the truck - that makes it all worth it for me... till I have to clean up the drool all over the truck!
Old 11-16-2018, 04:09 PM   #74
Whamo
Whamo's Avatar
Actually! I've been thinkin bout going with an old school c shell myself for my longer jaunts...and you've encouraged me to go ahead with it...sometimes function beats form and I'm getting a little too long in the tooth to try and look like everyone else...keep doin your thing, Brother!
also...the horse blanket speaker upholstery is starting to grow on me...
Old 11-16-2018, 04:23 PM   #75
daddyjeep
daddyjeep's Avatar
My neighbor has a black aluminum one that would be perfect on your truck. It probably isn't worth an 8hr drive though.
04 1500 crew cab
