Old 08-01-2018, 12:30 PM   #1
MDPotter
MDPotter's Avatar
1964 C10 Daily Driver/Restomod
Hello everybody, I'm a new member here and I've been exploring the forum and have found a lot of helpful advice and thought I'd share my experience with this restoration just in case anyone else out there is working on a similar build.
Dad and I are restoring the 64 C10 he drove in high school which belonged to his grandfather previously. It sat in the weeds for 20+ years before we pulled it into the shop in 2006 and took it apart. Life happened, the economy went down the drain, but we resumed the project with moderate effort in 2016 and really got after it this past year. I don't have pictures readily available for all the work done up to July 2018, but they are in the archives.
A summary of the work/mods done so far:
-Replaced inner/outer rockers, cab corners
-Replaced lower half of outer door skin (just below window sill down)
-Replaced inner door bottom
-Sandblasted all reusable parts and frame
-Purchased a whole new bed and front fenders
-Deleted tailgate chains and installed Mar-K hidden latches and links
-Welded up stake pockets
-Installed stainless tank between frame rails
-Rebuilt rear brakes (kept drums)
-Added front & rear sway bars
-1/3 drop
-Front disc brake conversion
-Dewitts radiator
-5.3 LC9 with 6-spd trans out of a wrecked 2012 2WD Silverado
-Power steering conversion
A summary of the work/mods to come:
-Vintage Air A/C
-17x8 6 lug Vision Legend wheels
-Headlights upgrade (TBD)
-Bucket seats out of 99-06 pickup
-Bed wood (Apitong)
-CPP steering column
-Single-DIN radio
We did mockups of (6) different color options and settled on the darker shade of GM Stone Blue Metallic:
-Eastwood rat rod black
-GM Torch Red
-GM Stone Blue Metallic (lighter shade, on fender in picture below)
-GM Stone Blue Metallic (darker shade, right half of bedside in picture below)
-GM Stone Blue Metallic (lighter shade with matte clear)
-Subaru Blue (left half of bedside in picture below)
-MIP or rubber floor mat & sound deadening
-Kick panel delete/speaker install
If all goes well this weekend, the bed will be painted.
MDPotter is offline   Reply With Quote
Old 08-01-2018, 12:33 PM   #2
KenAdams
KenAdams's Avatar
Re: 1964 C10 Daily Driver/Restomod
Nice! Keep the pictures coming!
KenAdams is offline   Reply With Quote
Old 08-02-2018, 12:09 AM   #3
Captainfab
60-66 Nut
Welcome to the forum
Sounds and looks like you have done a lot of work so far. Let me know if you need one of my hydraulic clutch conversions for that 6 speed.
Old 08-06-2018, 09:13 AM   #4
MDPotter
MDPotter's Avatar
Got the bed, cowl, outer cowls, bed braces, and inside face of the glove box, inner door panels, and ash tray painted yesterday. I'm pretty happy with it; they came out very clean considering my budget booth. I got a couple runs on one of the bedsides, but it should sand out and buff okay since I put on 3 wet coats of UV clear.
Next step is to gap the doors and finish blocking them as well as re-prime the tailgate before final sanding.
Old 08-06-2018, 11:45 PM   #5
Captainfab
60-66 Nut
That looks great
Old 08-07-2018, 07:05 AM   #6
Indian113
Indian113's Avatar
That sure is a Pretty Blue. Looking Good- Nice Work!
Indian113 is offline   Reply With Quote
Old 08-07-2018, 07:06 AM   #7
jimmythompson1964
jimmythompson1964's Avatar
nice work !!
jimmythompson1964 is offline   Reply With Quote
Old 08-13-2018, 09:19 AM   #8
MDPotter
MDPotter's Avatar
Got both doors fitted to the cab and test fitted/mocked up the seats and console.
I was pleasantly surprised at how well the doors fit, considering that we replaced inner and outer rockers, cab corners, and most of the door skin (also our first restoration). The gaps aren't perfect, but this is a driver, not a show truck so we're happy with them. Also sprayed two more coats of surfacer on the doors and the hood in preparation for another blocking session next weekend.
Seats are out of 99-06 GM truck and the console is out of 07-13 GM truck. The console straddles the transmission hump perfectly, we just have to put a spacer between the front mounting holes and the floor.
Old 08-20-2018, 12:11 PM   #9
MDPotter
MDPotter's Avatar
1/2
Got a lot of painting done this weekend. Painted the inside of the cab, both fenders, grille support, inner door panels, and tailgate. We're really excited to see the truck together and out in the sun because this blue really lights up in the sun and the picture doesn't do it justice.
I had trouble getting the gun inside the concave corners in the back of the cab, they came out very rough so I'll be sanding and buffing those out.
Also got most of the cab sanded for base/clear. Will not have much time in the next few weekends due to a vacation, but at this point all that's left to paint are the doors, outside of the cab, and the hood.
Old 08-20-2018, 12:13 PM   #10
MDPotter
MDPotter's Avatar
2/2
Old 08-20-2018, 02:10 PM   #11
62bagger
62bagger's Avatar
That color looks great. Cant wait to see it assembled.
62bagger is offline   Reply With Quote
Old 08-21-2018, 07:35 AM   #12
65truckowner
65truckowner's Avatar
A friend of mine had a truck that color. His was a 66 I think. Great job
65truckowner is offline   Reply With Quote
Old 08-22-2018, 04:46 AM   #13
kdad
Subscribed..... Great color BTW
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039
She may not be the prom queen but at least she puts out..
kdad is offline   Reply With Quote
Old 08-22-2018, 08:43 AM   #14
hank scorpio
Looks great! Which UV clear are you using?
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
hank scorpio is offline   Reply With Quote
Old 08-22-2018, 09:16 AM   #15
MDPotter
MDPotter's Avatar
I'm using SPI's Universal Clear with slow activator. I'm by no means experienced, I've got a run on almost every panel but I'm getting better with every panel and am planning on cutting/buffing when it's all put together anyway.
Old 08-22-2018, 09:45 AM   #16
hank scorpio
Nice! I've been spraying UV cured clear (and sealer) for the last few years and it literally transformed my business (guitar manufacturing). I've been using Hentzen UV poly and I love it. The name of the game for us in clear is build so I'm not as concrerned about having it lay down perfect with out orange peel (almost impossible since we can't spray one side at a time, we're always dealing with a 3D object with full paint coverage).
I've found that 2k urethane sprays a bit thinner and typically will lay down a little nicer than UV Poly but the speed and ability to cure runs and sags thru the entire material is so nice.
I'd say maybe consider either going up in tip size or reduce slightly. Sometimes it seems counterintuitive but I found when I was getting runs, reducing the material to flow out or spray thinner let me put LESS material on and get better coverage at the same time.
Guitars are also tricky because the really good guns are meant for spraying wide patterns so when you narrow down to work on something smaller, it's really hard to balance the flow with out it having one heavy wet path.
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
Old 08-22-2018, 02:50 PM   #17
MDPotter
MDPotter's Avatar
I was able to spray the 2nd fender without any runs (on the outside anyway) and I've found that I was moving too slow and I have to be aware of double coverage. The concave surfaces are tough too - the inside corners of the cab came out really rough but I'm looking forward to having everything painted in the next month or so and put it together finally.
Old 08-23-2018, 05:12 PM   #18
hank scorpio
You're doing a great job. I literally paint all day for a living but I hate doing body work. Quite jealous here
64 C10
A bunch of Volvos
Luthier
Simpsons Nerd
Old 09-10-2018, 09:04 PM   #19
MDPotter
MDPotter's Avatar
I'm back from vacation and I've got time off this week so I'm getting a lot done. Today I painted the hood and prepped the outside of the cab for paint (finished sanding, seam sealed, masked). We're very much looking forward to having the cab painted so we can set it on the frame and from there the only parts without paint will be the doors (hopefully later this week).
Tomorrow painting the cab!
Old 09-11-2018, 08:16 PM   #20
MDPotter
MDPotter's Avatar
Painted the cab today - I am very pleased with the results.
Painting the doors tomorrow!
Old 09-12-2018, 02:31 PM   #21
Clyde65
Clyde65's Avatar
Looks a lot like GM 29 Midnight blue from 85, had a truck that color and loved it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-12-2018, 05:25 PM   #22
rollin thunder
rollin thunder's Avatar
Love the color! keep up the good work!
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 09-12-2018, 08:30 PM   #23
MDPotter
MDPotter's Avatar
Clyde - It's Stone Blue Metallic G1K from the current body style Sierra. It's such a dynamic color, I can't wait to see it put together in the sun. It looks so dark out of the sun, but the sun shows the metallic and it almost has a little bit of purple to it in the right light.
Old 09-12-2018, 08:33 PM   #24
MDPotter
MDPotter's Avatar
Painted the doors today - now all parts are in paint. We will start putting it together this weekend! We're really excited; this will be the most complete (in terms of being assembled and work progress) since we took it apart.
Old 09-13-2018, 07:20 AM   #25
Indian113
Indian113's Avatar
Your doing great, anxious to see it all together
