Old 07-11-2018, 12:45 PM   #126
8man
Re: '50 chevy 3100
Man you are moving right along!
8man is offline   Reply With Quote
Old 07-11-2018, 12:56 PM   #127
Matt_50
Re: '50 chevy 3100
Thanks, my welds are still ugly but they penetrate. I'm hoping to set it back down later today.
1950 Build
Matt_50 is offline   Reply With Quote
Old 07-11-2018, 05:56 PM   #128
Matt_50
Re: '50 chevy 3100
I'm keeping busy today. That high build underseal went on super thick. I also cleaned up the frame some more.
1950 Build
Old 07-12-2018, 12:27 PM   #129
Matt_50
Re: '50 chevy 3100
I got the cab set back down yesterday evening. This morning I got the rear shackles bolted back on, got the doors on, and I set the bed back on the frame. Since the trans is set, I centered the engine today... it was off by 1/2 inch. I won't bolt it yet like I did the trans, just in case I need to make adjustments later I'll only need to undo the trans.
I might get the driveline shop to double check my angles...
1950 Build
Old 07-12-2018, 12:30 PM   #130
8man
Re: '50 chevy 3100
Moving right along.
Old 07-14-2018, 11:12 PM   #131
Matt_50
Re: '50 chevy 3100
I've decided to mess with my pedals and try to get my steering column where I want it. When I first set up my brake pedal I had it to low and to the left. I've gotten it in the right spot and need to brace it to the dash. I'm also going to try and get my gas pedal mocked up tomorrow.
1950 Build
Old 07-15-2018, 03:00 PM   #132
Matt_50
Re: '50 chevy 3100
I mocked up my gas pedal, got the brake pedal assembly moved over, and made sure I liked my steering column height by getting the seat in and pretending I was drivingbit already lol.
1950 Build
Old 07-15-2018, 03:06 PM   #133
Matt_50
Re: '50 chevy 3100
I'm thinking of doing something different with the gas pedal... looks kinda bulky, and I want to maybe lower it some...
I'll sit on it for a day or two, I'll mess with exhaust and e brake pedal next. The exhaust from my donor should work fine... it's the length that'll need to be fixed and maybe where I want the pipe to stick out. Straight out or behind rear tire.. what do you guys think?
1950 Build
Old 07-15-2018, 05:17 PM   #134
8man
Re: '50 chevy 3100
First, did you make vroom vroom noises when you were pretend driving?
Second, is the gas pedal really that noticeable from the driver's seat? If not you may want to keep moving forward on other things so you really can drive it.
Wish I had a thought on the exhaust, but that is so far from where I am now I can't even fathom it.
Good work.
Old 07-15-2018, 05:53 PM   #135
Matt_50
Re: '50 chevy 3100
Well... I may have made some noises in my head lol
No, gas pedal isn't really noticeable. I spaced it out from the brake pedal the same as from the donor. I wanted it to be the same as I was used too. But... due to space on both sides of firewall, I have brake pedal assembly a little higher than how it was in the donor. Not much, maybe 1 1/2 to 2 inches, but it's enough to make the gas pedal feel funny.
It is spaced good and really does seem ok, but I drove the c10 for so long it felt off. So I'm going to take a step back and worry about some other things for a bit. I know it won't be the same but it was comfortable.
I've been waiting to bolt the exhaust back up to the engine until I had cab undercoated and the trans set. Now that I have, I think I'll mess with exhaust some...
I jump from little project to little project, depending on how much extra cash I have lol
1950 Build
Old 07-16-2018, 11:40 PM   #136
joedoh
joedoh's Avatar
Re: '50 chevy 3100
if you plan to put in carpet or even a rubber mat with something on the back, do that FIRST! on the last 41 my pedals looked way too high but I put in some 5/8 jute and carpet and whaddayaknow, the pedals fit perfect.
Old 07-17-2018, 03:48 PM   #137
Matt_50
Re: '50 chevy 3100
I hadn't thought of carpet thickness. Maybe I'll throw something in to act as carpet and see how it feels.
Do you guys ever have those days where everything runs right with no hiccups? Usually I always have something go wrong but for the last few days I've been on a roll. Until today, I was so sure my exhaust idea would work. Shorten the donors exhaust and be done. Unfortunately it's hangs to low for my liking and I don't think I can cut up the Y and put it together right. I also think I need new exhaust manifolds. These are kinds bulky and ugly and when my engine was swapped out in the c10 I wasn't told my exhaust manifold on the passenger side was messed up. I never had a leak so I guess that's something.
So, what manifolds work well that I can find at a junkyard or swap meet without spending much? Are there any Y 's I can scavenge that will fit better?
With the exhaust on hold I started cutting the rusty spot out of the lower driver cowl panel. I think I can get away with a small patch. I was worried it would be worse so I'll do that tomorrow.
1950 Build
Old 07-18-2018, 02:35 PM   #138
Matt_50
Re: '50 chevy 3100
Started my driver side lower cowl patch fix. Ran out of wire had to go get more and hopefully I'll get it done in the morning.
Since I ran out of wire I decided to go after some spots on the body with the wire wheel. The PO really loved bondo, tiny little ding meant several inches of bondo feathered out all around it. So you can imagine a bad spot... I need to replace the cab corners. I attacked the driver side and it's rough, and it was reshaped with a lot of bondo. I haven't looked at the passenger side yet.
I also had a piece of metal inside the cab, it wasn't tacked on good and I was able to pull it up. It made a crack in the outside paint. So I went after that spot with the wire wheel and found a nice round hole.
1950 Build
Old 07-18-2018, 02:41 PM   #139
8man
Re: '50 chevy 3100
The hole looks like maybe a CB whip antenna, but just guessing.
As for the bondo, welcome to my world. I had a cab that looked good until I had it blasted. Then there were so many holes and dents that I had to get another cab.
IMO you are doing it right welding up the areas. A little skim is one thing, but all the bondo is just wrong.
Keep at it.
Old 07-18-2018, 03:24 PM   #140
Matt_50
Re: '50 chevy 3100
Someone went through a lot of trouble to bondo over a lot of areas, and yet half the floor was rusted out. So either this truck got rusted.. fixed up.. and then rusted again... or someone started to fix a really rusted truck and then it continued to sit for who knows how long. The paint was cracked and faded all over so it's been awhile. I've also run across areas fixed with lead instead of bondo. I'm thinking at least two different POs worked on the body at some point. I've found blue and green when taking off the paint. I'm thinking the blue was original because I can find it in hard to get to spots or from areas that needed to be opened up to paint. Like under the hood.
I was real scared when I first started gping over the body. I think 1/4 of the hood had bondo! I was expecting to be messed up. Just another tiny spot...
I wish I had just gotten it blasted.
1950 Build
Old 07-20-2018, 11:30 AM   #141
Matt_50
Re: '50 chevy 3100
It's nice to make regular posts. I've been moving along real slow up until recently. Thankfully I'm not waiting on someone else for welding anymore mine's not great, andbi have to redo it a lot, but I'm moving along. I've also got more time on my hands too.
This morning I attacked that new hole I found. And I also finished patching the lower driver cowl piece in. Slapped some bondo on both and maybe throughout the day I'll sand those spots and get them just right.
1950 Build
Old 07-20-2018, 01:35 PM   #142
8man
Re: '50 chevy 3100
Keep at it. You are making good progress.
Old 07-25-2018, 05:09 PM   #143
Matt_50
Re: '50 chevy 3100
Got a little work in. I cut and riveted a piece of sheet metal where my MC is now mounted. I did this to help bracevit and cover the old holes from where I moved it over. Now I can make some "arms" to extend the brake assembly to the dash to brace it further.
1950 Build
Old 08-01-2018, 07:38 PM   #144
Matt_50
Re: '50 chevy 3100
I got both cab corners ordered today. Let's see how long it takes to put them on lol.
1950 Build
Old 08-01-2018, 09:47 PM   #145
joedoh
joedoh's Avatar
Re: '50 chevy 3100
hey man, progress is progress!
Old 08-03-2018, 11:42 PM   #146
Matt_50
Re: '50 chevy 3100
I had mentioned making "arms" for my brake assembly to extend it to brace to the dash. It's ugly but I got it done. Used metal from my donor frame, pieces that still had a lip from where it was a channel. Pretty thick and the extra edge I feel gave it some stability.
I probably over thought it but it's installed. Spent a long time bending them into shape. Clamp, hammer, check it, hammer again. I also put the original brace in too. Even with the brake assembly out, I couldnt get it back in with out some trimming. Maybe I fixed it wrong. It rusted in two where it bolted to firewall. Right down the crease, only rust it had. I cleaned it up, used anouther piece over them and welded it back together.
Anyways, both are in and painted. I also did some sanding on a couple bondo spots. Remember that hole I filled in where maybe an antenna went? I'll try to sand and finish it tomorrow.
I've got a couple other spots to fix, I think I'll have them on tomorrow too with pics.
1950 Build
Old 08-04-2018, 11:41 AM   #147
Matt_50
Re: '50 chevy 3100
It probably takes me longer than some but that spot where I filled in the hole is turning out nice. I have a slight low spot and I'll be done. I'm using very little bondo at a time, then sanding and repeat. I needed to use more at first but I had had that problem before of using to much and then I would have to sand a lot. I'm learning.
Also patched in a spot that can't be seen with fender in place. I'll finish it next time, I jump around a bit, let welds cool.
Also tackled the door today, the big spot I mentioned before. A real pain and I had to walk away a time or two. I'm hoping it'll all smooth out real nice. I'll admit, the welds sucked. Some pin holes but I had to leave it. I kept burning through. I was able to somewhat reach in the door and built up the back side though. I'm getting better, but it will be a while until I have even half the skill as some of the guys on here.
I'm hoping to have all my little spots fixed and done by the time I start on corners. Between the inners and outers, I'm going to try to make the inners, it might take a couple of weekends.
1950 Build
Old 08-05-2018, 12:02 AM   #148
vintovka
vintovka's Avatar
Re: '50 chevy 3100
The light coming in the cab corners reminds me of a house i once owned. Soooo Glad mine were in such good shape. I also made sure the weep holes were clear this last 50+ years
vintovka is offline   Reply With Quote
Old 08-05-2018, 12:27 AM   #149
Matt_50
Re: '50 chevy 3100
Lol, and I didn't get all the bondo off either.
1950 Build
Old 08-05-2018, 12:36 PM   #150
Matt_50
Re: '50 chevy 3100
Today I cut a small patch for the other side like the one I just did, but I didn't put it on yet.
Since my cab corners should be here Tuesday, I thought I'd better do some more prep. Got thevrest of the bondo off and went ahead and cut out just the rust area on passenger side. The inner looked more complete and I thought if I was careful I could copy or patch it and then use it for reference on driver side.
1950 Build
