08-08-2018, 10:52 PM | #1 |
Sloppy Steering GMC 2500 1968
Hey Gang, Still working on my 1968 GMC 2500. This week I am trying to take some of the sway out of the steering. I have what I believe is called POWER ASSISTED POWER STEERING. The pitman arm goes int some sort of control valve ant it relays to the center link I guess, and so on. There is a little circular play in the wheel with truck off. Where the pitman arm goes into the control valve? I guess, there is more play. I have looked for rebuild parts, but everything reproduced is way different than what I have. Is it better to try and hunt down replacement parts? Or, tear it all out and upgrade the steering to what is being mass produced and sold? I'm open to all suggestions. Thank you in advance
08-08-2018, 10:57 PM | #2 |
oops!
08-08-2018, 11:00 PM | #3 |
Here is what I see
Posted via Mobile Device These pics were taken on my back laying under the truck in case you needed to catch your bearings Last edited by markizme; 08-09-2018 at 05:15 PM. |
08-09-2018, 01:26 AM | #4 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Sloppy Steering GMC 2500 1968
Cant say that I've ever seen anything like that before...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
08-09-2018, 03:36 AM | #5 |
Scrapper 1
I have 1955-- 1967 or 8 had the ram power assisted ram.www.truckandcarshop.com has the new ram and bushings and parts.In 1968 they went to the box.If your having a looseness Its the manual box that whore out.You need to find a used box or buy a new one that will fix the looseness.The Ram is only there to make it easier on steering.
08-09-2018, 09:38 PM | #6 |
So I am looking for a MANUAL box? Will it matter that the box is incorperated with a “Jet Ram” system when I look for a replacement? With a price that everyone is saying, I should have taken care of the steering issue sooner. Thanks Gang 👍
Posted via Mobile Device |
08-09-2018, 11:46 PM | #7 |
Does anyone maybe have the part number for the box I need? That would be a big help. Thank you everyone👍
08-10-2018, 12:56 PM | #8 |
You can send your box out to Red-Head for a rebuild https://www.redheadsteeringgears.com/. That's what I would do. These guys do quality work and are known around this forum as being one of the best. You can have them upgrade the box to a faster ratio as well.
For the ram assist, Corvettes and a couple other cars used them as well back in the day. Here's a great thread on rebuilding the ram assist if you need to go that route: http://67-72chevytrucks.com/vboard/s...d.php?t=253657
72 C10 lwb fleetside -stock 350/350 combo |
08-10-2018, 01:26 PM | #9 | |
Also, I am unclear on what you are describing, is it a hydraulic cylinder on the center link/tie rod? I have always heard that called "ram assist" A power steering gear has ports for the hydraulic fluid, and a ram-assist-gear is essentially a power steering gear with additional ports that feed the lines to the ram. Agree with the guy who said send it to Redhead for a rebuild. They seem to be a very reputable operation. If you can't afford to have your truck out of service that long for them to rebuild the steering gear, call them up and see if they could supply you with a rebuilt gear, then you send yours in for the core charge.
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels 1976 K20 crew cab, 350/Ranger/SM465/NP205 |
08-11-2018, 01:34 AM | #10 |
Here is what I am working on. She’s in very decent shape for being 50!
08-11-2018, 01:46 AM | #11 | |
08-14-2018, 04:32 PM | #12 |
A big THANK YOU to everyone that posted and pm'd me about my steering issue. After the bushing replacement, I greased the front end, and gave the steering box just a bit more than 1/4 turn and all in all the steering tightened up. It is something that I can live with for the time being. The "Things to make the truck streetable" list is a long still. As I mentioned before, I super appreciate the knowledge that everyone has passed on to me. You guys rock
