Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-24-2016, 11:23 PM   #301
Boog
laying low
Boog's Avatar
Re: Color Wiring Diagram FINISHED
You guys should know boundstaffpress hasn't logged on here since July 2015 just so you know and aren't waiting patiently for an email.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
2 GMCs and 1 Tahoe
All GM..'nuff said,
Member of Jr Nation 88
Old 12-30-2016, 09:23 PM   #302
jimbosprint
jimbosprint's Avatar
Here is the full cleaned-up version:
jimbosprint is offline   Reply With Quote
Old 12-30-2016, 11:02 PM   #303
Boog
laying low
Boog's Avatar
That's way better. I have been trying to print some clear copies of the others but no success.
Boog
primer is finer
2 GMCs and 1 Tahoe
All GM..'nuff said,
Old 12-31-2016, 02:33 PM   #304
crakarjax
crakarjax's Avatar
That looks super nice! Excellent work.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 05-18-2017, 01:42 AM   #305
staydubbin
does anyone have this in a spreadsheet by chance? ive been searching and cant find it.. i cant get a ahold of a color printer, honestly a chart or spreadsheet is easier while im going through.. thanks in advance!
staydubbin is offline   Reply With Quote
Old 05-31-2017, 03:37 AM   #306
Unsub
A BIG thank you to all who posted diagrams and offered advice. I have just been through all 13 pages, downloaded and printed a heap of information all of which is worth its weight in gold. I am still neck deep on gloom over this EZ kit but it will come good soon.
Regards Peter.
Unsub is offline   Reply With Quote
Old 05-31-2017, 06:48 PM   #307
SuperChief
Thumbs down Re: Color Wiring Diagram FINISHED
Does anyone have a generator/reg delete converting to 3 wire alternator that would kind of overlay this outstanding rendition?
SuperChief is offline   Reply With Quote
Old 05-20-2018, 12:29 PM   #308
dmjlambert
dmjlambert's Avatar
Discussion
http://67-72chevytrucks.com/vboard/s...d.php?t=763180
12SI with regulator delete and add accessory junction block overlay.
Example application for parts store is 1984 High performance Chevy Camaro, with 5.0L (305G) engine 94amp alternator
CS130 with regulator delete and add accessory junction block overlay.
Example application for parts store is 1989 Pontiac Safari 105amp v-belt alternator
More info about CS130 resistor and terminal
https://www.americanautowire.com/PDF...20IN%203.0.pdf
Example pigtail with resistor
https://www.amazon.com/dp/B0055ALN56/
Old 05-20-2018, 03:58 PM   #309
dmjlambert
dmjlambert's Avatar
HEI overlay
Old 05-28-2018, 12:19 PM   #310
fixer3333
Could you please send a Hi-Res copy to passst@aol.com.
thx
fixer3333 is offline   Reply With Quote
Old 05-30-2018, 07:39 AM   #311
Will B
There isnt one of these buy chance for the 73 to 87 trucks is there?
Will B is offline   Reply With Quote
Old 06-13-2018, 11:39 PM   #312
dmjlambert
dmjlambert's Avatar
Wiper correction overlay
Old 06-21-2018, 09:28 PM   #313
463
463's Avatar
Here is a link for you
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
Trueman
463 is offline   Reply With Quote
Old 07-17-2018, 04:39 AM   #314
mosh89
Helping my brother work on a friends Blazer, this diagram was very helpful!
One question though, what does the black and black/white fused wires go to? I see they terminate at the firewall junction, but doesnt look like they go anywhere on the cab side.
Thanks!
Nick
mosh89 is offline   Reply With Quote
Old 07-27-2018, 07:09 AM   #315
Christopher1
An electrical circuit consists of 3 main wiring components that is live(also known as phase or main), neutral and earth(ground). To distinguish between them different countries use different color code for identification.
In India 3 colors i.e. Red, Blue and Yellow are used for 3 phase live supply, Black is used for neutral and Green or Green with yellow stripes wire is used for earthing(ground) .
Here's a Wikipedia link for electrical wiring. You can go through details and can learn different color codes for wiring in various countries.
Christopher1 is offline   Reply With Quote
Old 08-25-2018, 10:43 AM   #316
Tackleberry
Tackleberry's Avatar
Hello, can I get that Hi-Res copy as well? Thank you in advance mllrd269@gmail.com. Looks great, great job BTW
Tackleberry is offline   Reply With Quote
Old 08-26-2018, 02:25 PM   #317
dmjlambert
dmjlambert's Avatar
Originally Posted by mosh89 View Post
....what does the black and black/white fused wires go to? I see they terminate at the firewall junction, but doesnt look like they go anywhere on the cab side.....
In the cab those wires go to the cluster connector if you have a gauge cluster. They connect to the ammeter.
It is above in jimbosprint's post number 302. You can right click on it and save it to your computer if you want.
Old 09-02-2018, 02:52 PM   #318
moon
moon's Avatar
Greetings- may I have a high-res copy also?
moon@moonskie.com
Thank you for all the time & effort you have afforded us!!
1970 CST long bed Fleetside
moon is offline   Reply With Quote
Old 02-18-2019, 07:20 PM   #319
Ghost's68
Ghost's68's Avatar
Could I get a Hi-Res copy as well? Thank you for putting this together! Super helpful
jimmywhispers14@gmail.com
Ghost's68 is offline   Reply With Quote
Old 04-07-2019, 09:33 PM   #320
Ramiro0727
Hello, can I get that Hi-Res copy as well? Thank you in advance rhernandez0727@att.net. Thanks.
Ramiro0727 is offline   Reply With Quote
Old 04-08-2019, 01:55 AM   #321
SRU1436
Hello, can I get a high res copy too? ktmmatt@gmail.com. Thank you.
SRU1436 is offline   Reply With Quote
Old 04-08-2019, 07:22 AM   #322
Getter-Done
Getter-Done's Avatar
10-13-2017 was the last time Original Poster has logged in.
This is the same wiring diagram in the
Factory Assembly Instruction Manual.
Here's a link another member shared
link: http://www.chrismeadtattoos.com/wiri...ruckwiring.jpg
84 Chevy K-20
paypal.me/Dwayne67CrewCab
Old 04-08-2019, 10:01 AM   #323
SRU1436
Awesome, thank you.
Old 04-08-2019, 02:36 PM   #324
jimbosprint
The full resolution copy is just a few posts back guys. Scroll.
Old 04-13-2019, 02:55 PM   #325
howell57
Re: I suck at reading wiring diagrams..
Just took a 350 out of my C10 for a new L83. Marrying the ignition to the computer is beyond my 72 year old brain. A lot of what you have written helps. Everything will be stand alone. Engine needs hot to starter and one wire to cpu. AC will be stand alone as will be lights.
howell57 is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
