Old 04-05-2018, 10:48 PM   #376
Wantavant
Re: show me your 73-87 lowered/bagged c10's
Few more pics, 6 drop up front now
Wantavant is offline   Reply With Quote
Old 04-06-2018, 11:33 AM   #377
G-NUT
Junior Member
G-NUT's Avatar
Originally Posted by julio_10 View Post
5.5/9 22/24 rolling shots
Man this setup looks sweet! You say 22 / 24 setup? What are your specs if you don't mind me asking?
1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed using 5-lug C10 rolling attire - in process to lay pinch weld to the ground
G-NUT is offline   Reply With Quote
Old 04-06-2018, 01:12 PM   #378
cooperhw
cooperhw's Avatar
El Chapo. 78
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 04-06-2018, 05:31 PM   #379
Jotto82
Originally Posted by MURPH82 View Post
Here is my 84 that i am almost done with
Beautiful truck. Everything fits perfectly. Colors and rims. The whole thing just lights up when you look at it. Nice work
Jotto82 is offline   Reply With Quote
Old 04-06-2018, 05:33 PM   #380
Jotto82
Originally Posted by Richya View Post
Here's mine
Love its great look.
Old 04-23-2018, 12:09 AM   #381
cooperhw
cooperhw's Avatar
Thanks. I'm loving how it's coming out so far.
Later,
Wayne
Old 04-23-2018, 12:12 AM   #382
cooperhw
cooperhw's Avatar
Finally figured out just How Low it is
Later,
Wayne
Old 04-24-2018, 12:08 AM   #383
ilnvyb360
ilnvyb360's Avatar
Killer stance! Can you share who you went with for the drop? And also what size tires you're running?
I'd like mine to sit like yours!
ilnvyb360 is offline   Reply With Quote
Old 04-24-2018, 09:04 AM   #384
Wantavant
Thanks man, it is just a Belltech flip kit in the rear. 3" drop spindles and Djm 3" springs up front, had 2" springs at first but swapped them out for some rake. Belltech Nitro drop shocks all around as well. Tire sizes are 255/60 15 front and 275/60 rear.
Old 04-26-2018, 07:12 AM   #385
jkk
jkk's Avatar
That truck is clean!
jkk is offline   Reply With Quote
Old 04-26-2018, 10:29 AM   #386
Wantavant
Thank you sir!
Old 04-26-2018, 10:53 PM   #387
ivorton74
ivorton74's Avatar
My 83 again. The front lowered 6 inches but was dragging the frame n control arms. So had to put my back chopped spring along with 3 inch spindles. It’s at about 5 1/2 inches. Also now has 2 inch shackles in the rear.
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 05-04-2018, 10:39 PM   #388
ivorton74
ivorton74's Avatar
Now with new wheels n tires.
Old 06-17-2018, 08:04 PM   #389
Wantavant
Out for a cruise with the AC crankin
Old 06-25-2018, 05:50 AM   #390
RUN GMC
RUN GMC's Avatar
Reposting mine since photohacket took my other pics....cruising on the 2018 Hot Rod Power Tour......
RUN GMC is offline   Reply With Quote
Old 06-25-2018, 10:03 PM   #391
808_67C10
808_67C10's Avatar
at the beach
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 350/700r4 shortbed http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 07-21-2018, 09:29 AM   #392
3drburb
Plugging along slowly.
3drburb is offline   Reply With Quote
Old 08-15-2018, 11:27 PM   #393
BIGglaSS
BIGglaSS's Avatar
81 GMC. Beltech 3" spindles, moog 6454 springs cut one coil, rear axle flip. 235/70r15.
My museum of good intentions: 1957 3100 BBW restomod -- 1981 swb -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 08-15-2018, 11:40 PM   #394
GMC Guy
GMC Guy's Avatar
Hows the ride with those 3/4 ton springs?
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 08-16-2018, 11:19 PM   #395
BIGglaSS
BIGglaSS's Avatar
Fine, so far. I wish it would have come down another inch, though.
Old 08-27-2018, 11:31 AM   #396
The_Lucane
The_Lucane's Avatar
Great looking trucks in here.
I'm trying to figure out how to fit 325/50/15's flush with the fenders on my '76, as I'm going for a VERY aggressive meaty NASCAR look. I think 15x10 with 4.5-5" backspace will do the trick for the rears, but have no idea what I'll need to do for the fronts. Not trying to put it on the frame rails either- probably a 3/4 or 4/5 drop, depending on how much clearance I need during suspension load.
Strength is the Only thing that Matters in this world. Everything else is just a delusion for the Weak
The_Lucane is offline   Reply With Quote
Old 08-28-2018, 08:54 PM   #397
cruizin01
10" wide and 5" backspace center you between the tubs on the back. Its gonna be hard to fit that big of a tire on the rear with a 5" drop. I run 295/50 and its as big as I feel comfortable going with a ~5" drop in the rear.
8's on the front with a 4" BS are typical on a 15" wheel. You have to grind the control arm and its sit close to the tie-rod end. 10" wide wheel sit just outside the fender and doesn't look great imo.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 08-29-2018, 09:39 AM   #398
The_Lucane
The_Lucane's Avatar
I see. What about with tubular control arms? Do they offer up any additional clearance?
As far as the outside of the wheels, I've entertained the idea of cutting the fenders/bedsides and adding flares to accommodate the fitment if need be. I know it seems stubborn, but I will not be happy with the build unless I have 325's on all four corners lol. One way or another, I'll make it happen.
Old 08-29-2018, 10:04 AM   #399
cruizin01
If it was mine I would run larger bed tubs. Then get the correct offset wheels. The front, even with tubular arms is still gonna cause problems with the tie rod end on 15's. Most everybody that has ran something that wide runs larger diameter wheels. You could also have someone build/modify a front subframe/arm setup to allow for what you want.
'78 C10 Build
Old 08-29-2018, 10:10 AM   #400
The_Lucane
The_Lucane's Avatar
If it was mine I would run larger bed tubs. Then get the correct offset wheels. The front, even with tubular arms is still gonna cause problems with the tie rod end on 15's. Most everybody that has ran something that wide runs larger diameter wheels. At least from what I've seen.
Hmm, well damn. I guess I'll have to run a staggered setup afterall. Sound like a pain in the ass lol.
But hey- I can still get the look I'm after. This is pretty slick looking, though I'd go a touch lower. If anyone has his specs, I'd be interested in knowing them.
https://www.youtube.com/watch?v=vL51VkIqQ0k
Copyright ©2000 - 2019, vBulletin Solutions Inc.
