Old 07-22-2018, 09:43 AM   #51
IronCanine
I'm trying....
IronCanine's Avatar
Re: 1946 B.F. Avery Model A Tractor Restoration
Originally Posted by mongocanfly View Post
man I really like that red....it looks great...
It's call Tartar Red...and what's prescribed by Avery afiscionados as the correct factor color. Looking at my basement you won't think it, but I'm not big on red. But I like this too. Thanks!
Originally Posted by Advanced Design View Post
Looking very good!
It is interesting the engine is mounted on rubber bushings as I didn’t think the designers would have been concerned about vibration. The paint / build sequence and discussion is applicable to all our projects...sure helps with a nicer looking end result.
I've thought about this too and don't know the answer. I can think of several reasons that it made sense that aren't vibration. With regard to paint, it's always a catch 22 when you have so many painted surfaces. The ziplock bag on bolt technique works pretty well, but we've still nicked some nuts and bolts. There are some places where I did want clean gaskets and fittings to show, just to convey the type of restoration that was done...but I didn't want it too bejeweled with hardware that took it away from how it left the factory. I mean, they painted the whole thing red and didn't worry about the fact that you were going to skin it up when you changed the oil...or basically every other thing that it was purpose built for. But as you said, paint sequence is the chess game we play on all these builds.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 07-22-2018, 07:59 PM   #52
OLDYELLOW
OLDYELLOW's Avatar
Originally Posted by IronCanine View Post
Finally back home on a weekend and just so happens my girls are away, so a perfect time to make some hay. I was very lucky to find 70 year old NOS rubber motor mounts which were surprisingly resilient for their age.
I wonder what they were trying to achieve with rubber bushings, because it is still metal to metal connection to the frame and the bell housing bolts straight to the frame?
OLDYELLOW is offline   Reply With Quote
Old 07-22-2018, 08:54 PM   #53
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks great!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 07-22-2018, 09:38 PM   #54
IronCanine
I'm trying....
IronCanine's Avatar
Originally Posted by Ol Blue K20 View Post
Looks great!
Thanks!
I think they probably killed some vibration even if only on one side of the motor. I know how we set the motor and clutch assembly, I don't know how they did. It does conceivably give you a little play on installation. The mounting points on the front of the engine are kind of wimpy...four small bolts on the timing cover. They might benefit from a forgiving mount. After all this engine was just a power unit and not designed for a specific application. Finally, the core of this design was a crawler...which they turned into a wheel tractor. That's definitely an unforgiving arrangement.
....it's probably vibration. I don't know any engineers and the guys who drew it up are dead. I'm sure there's a solid reason...but at the end of the day I'm just a guy excited about finding septuagenarian rubbers.
Old 09-04-2018, 08:07 AM   #55
IronCanine
I'm trying....
IronCanine's Avatar
Eric fabbed this exhaust bracket with nothing to go on except two pics of the complete tractor in the original manual (no close ups or part specific pics). Very difficult to discern. A lot of research and questioning of old timers...but in the end just staring at 1mm of real estate on a 72 year old book. I engaged experts on her cousins (Oliver, Cletrac) to no avail. Maybe someone who stumbles on this thread can offer more info on this part. Even though the exhaust manifold would have been painted red from the factory...I couldn't stand to see the paint burn off, so we ceramic coated it cast gray. Just like the exhaust on the Blazer.
Old 09-04-2018, 08:09 AM   #56
IronCanine
I'm trying....
IronCanine's Avatar
She got loaded up and shipped back to Eric's for final paint on the block and other loose end paint work.
Old 09-04-2018, 08:14 AM   #57
IronCanine
I'm trying....
IronCanine's Avatar
She's pretty much all red now.
Old 09-04-2018, 08:17 AM   #58
IronCanine
I'm trying....
IronCanine's Avatar
Advanced Electrical Rebuilders in Michigan rebuilt our generator, starter and distributor. Almost all NOS Autolite stuff. Stamped new plates and based on internal wear confirmed this was a low hour piece of equipment--of course it was up to Eric to make it red.
Old 09-04-2018, 08:45 AM   #59
mongocanfly
mongocanfly's Avatar
Looking good...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-04-2018, 11:38 AM   #60
IronCanine
I'm trying....
IronCanine's Avatar
One more quick shout out to Jason at AER. The restoration of these pieces was over the top. He even powder coated them. It was almost heresy to paint them.
Old 09-04-2018, 11:39 AM   #61
IronCanine
I'm trying....
IronCanine's Avatar
Looking good...
Thanks.
Old 09-04-2018, 12:44 PM   #62
plainred65
plainred65's Avatar
First class all around!
plainred65 is offline   Reply With Quote
Old 09-04-2018, 05:28 PM   #63
Russell Ashley
Russell Ashley's Avatar
Beautiful. I'm betting that the paint wasn't that nice when the factory got through building it.
Russell Ashley is offline   Reply With Quote
Old 09-05-2018, 09:29 PM   #64
Clyde65
Clyde65's Avatar
Very nice! Your paying exceptional mind to detail on this old work horse!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-06-2018, 10:58 PM   #65
Advanced Design
Advanced Design's Avatar
Impressive AER powder coated the components they rebuilt. Looking really nice.
Advanced Design is offline   Reply With Quote
Old 09-07-2018, 10:55 AM   #66
Ol Blue K20
I think it's beautiful. A lot nicer than the factory ever did
Dale
Old 09-11-2018, 08:11 AM   #67
IronCanine
I'm trying....
IronCanine's Avatar
Thanks guys. Yes the paint is a bit better than factory I think.
Old 09-11-2018, 08:12 AM   #68
IronCanine
I'm trying....
IronCanine's Avatar
Ceramic coated manifold.
Old 09-11-2018, 08:21 AM   #69
IronCanine
I'm trying....
IronCanine's Avatar
A lot of assembly on Saturday...basically all day. Got to the end and filled her up with fluids, hit the button and nothing. Eric very quickly diagnosed it as a ground problem. A price paid for paint on every surface. We called it a night, Eric added a ground strap on Monday we fired her off last night. It was all that 6V battery wanted...we didn't get too many turns out of it before it went soft. We didn't test it when we got it and I wonder if it had gone weak on the shelf. Though candidly this motor is probably tighter than factory. The best part of the whole thing was, after a few turns with no result, my daughter asked to give it a try. It fired right off when she hit the button. There was no doubt who this horse belongs to.
Old 09-11-2018, 11:11 AM   #70
Clyde65
Clyde65's Avatar
Nice!
Clyde65
Rebuild of Clyde
support our troops!
Old 09-13-2018, 01:24 PM   #71
Russell Ashley
That is beautiful, makes me wish I had been there when it fired up. The generator and starter looked good but were they painted red from factory? I was thinking that usually the starter and generator were black and not painted engine color, like on cars.
Old 09-13-2018, 02:08 PM   #72
mongocanfly
Man this thing is so sweet!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-13-2018, 02:17 PM   #73
IronCanine
I'm trying....
IronCanine's Avatar
Nice!
Thanks.
Double Thanks.
This was an original paint tractor. Everything was painted red except for the steering wheel and the rear rims. I don't know if they "roughly" taped off the Autolite tags, or just wiped off the wet paint. We obviously detailed it beyond that. We didn't paint any rubber or wire looms...which was done from the factory.
Old 09-14-2018, 03:09 PM   #74
Advanced Design
Looks great! When most of us look at the second picture, we imagine the first picture. Easy to imagine, hard work to get there. Well done!
Old 09-14-2018, 05:31 PM   #75
IronCanine
I'm trying....
IronCanine's Avatar
It's mostly fun work though. But thank you--I appreciate those kind words.
bf avery, ixb3, model a, restoration, tractor
