04-11-2018, 01:38 PM | #126 |
Re: '66 Budget friendly driver
Maybe not.
I just saw you were in GJ and looked like you worked at the Chevy Dealership. I droped some off to a guy that worked there, thought it might be you.
63 k20 with cummins 4bt, owned sence 1982 |
04-11-2018, 01:55 PM | #127 |
Oh, crap yes! I remember now. Yep thats me
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
04-13-2018, 05:09 PM | #128 |
Check out the videos! Please do me a huge fave and comment on them on the YouTube channel
https://www.youtube.com/watch?v=b9BAjzPo8fE
04-13-2018, 05:11 PM | #129 |
Video 2
https://www.youtube.com/watch?v=lH64FCP-llM Video 3 https://www.youtube.com/watch?v=vAM0bzhIYds
04-13-2018, 11:23 PM | #130 |
Coooool
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
05-16-2018, 06:39 PM | #131 |
Finally got the 8" wheels painted black. Have to get some wider rubber now too. Also working on getting the dual master cylinder installed.
05-22-2018, 10:02 PM | #132 |
Finally got to the master cylinder. I had the help of big Willie once again. I didn't have time and he can run brake lines like no other.
05-23-2018, 10:50 AM | #133 |
Great build! Ive seen those hub caps somewhere but I don't remember what they are off of?
my 86 c10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=496829 my 56 3100 build: http://67-72chevytrucks.com/vboard/s...09#post5712509 my 95 silverado build: http://67-72chevytrucks.com/vboard/s...35#post5879335 my gray 86 c10 http://67-72chevytrucks.com/vboard/s...34#post7624734 |
07-17-2018, 03:01 PM | #134 |
Any updates,How well do the brakes work without a booster,Can the front be adjusted to get it lower,Thanks Lucky
07-19-2018, 01:29 PM | #135 | ||
The front could be brought down a little bit, but I don't want it any lower. I don't really have to worry about much sticking up in the road when I'm driving. Everything is working perfectly together. Couldn't be happier with this setup.
09-07-2018, 04:10 PM | #136 | |
Are those the stock steel wheels that came on the truck or are you running something different? Which spindle did they use on the front, the modular or just the regular 2.5” drop? Looks like there was no issue with the brakes clearing those wheels are you running a wheels spacer also? |
09-07-2018, 04:43 PM | #137 | |
09-07-2018, 05:02 PM | #138 |
So the wheels you had on it when you had the qa1 suspension where from a 4x4 blazer do you recall the year? 15x7? I was gonna order some of the wheel vintiques but I’m not sure what size and backspacing.
09-07-2018, 06:12 PM | #139 |
The plain steel ones remind me of the military blazer wheels (m1009). Good looking truck man and I bet its a fun drive with suspension dialed in.
09-07-2018, 06:27 PM | #140 |
Wheel Vintique will know exactly what you want. I think my wheels are from a late 70's early 80's square Blazer
09-07-2018, 06:28 PM | #141 |
Thank you. It's a blast!
09-07-2018, 11:55 PM | #142 |
60-66 Nut
I have a set of 4 of the factory 15" x 8" 6 hole wheels for sale in the classifieds.
09-08-2018, 11:05 AM | #143 |
09-12-2018, 03:52 PM | #144 |
So, you've said a number of times how well the truck handles with the new suspension, how is the ride? I'm about to assemble my suspension. I have been going back and forth on what to use. I live in Maine where the roads are hilly, curvy and not the smoothest.
65 short step edited by staff |
09-13-2018, 11:05 AM | #145 | |
Hope this helps.
09-13-2018, 01:13 PM | #146 |
I'm in GJ as well, restoring a '64 for my dad. I just finished painting everything. Chassis is 80% complete and we will start putting the body back together this weekend.
Your '72 is awesome, I'd like to build that body style for myself. |
09-14-2018, 03:58 PM | #147 |
That's awesome! I'd love to see it sometime
09-15-2018, 01:01 AM | #148 |
Very cool. Been in the back of the crowd watching. Did ya get the vibration issue doused out ?
The Snortin' Bull |
09-15-2018, 10:47 AM | #149 |
ya, it was the bearing in the back of the tranny
01-31-2019, 07:17 PM | #150 |
Who here has replaced the bearing in the back tail section of the 3 on the tree tranny? Where the drive shaft slides in.
I need some advice. Can I just pull it out or does the transmission have to be dropped? Thank you.
