04-12-2018, 11:20 PM | #76 |
60-66 Nut
Re: 6 Lug Rear Disc with 15" Wheels and an E-Brake
I'll have to take a look and see if I can ship the trailing arm mounts in the same box as the rear disc brackets. I will let you know.
04-13-2018, 11:37 AM | #77 |
No worries if not, last night a local guy told me he has a set. I can paypal you the $$, is the price the same with the substituted parts?
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen |
04-13-2018, 10:54 PM | #78 |
60-66 Nut
The trailing arm mounts will fit in the medium box along with the rear disc brackets. I will send you a PM with ordering and payment info.
The base plates with a different hole pattern does not change the cost of the rear disc brackets.
06-15-2018, 11:02 PM | #79 |
Has anyone found a set of brake lines and used them for this setup?
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg........... |
06-16-2018, 01:26 AM | #80 |
60-66 Nut
So neither of the suggested hoses on the parts list are working for you?
09-09-2018, 08:39 PM | #81 |
I’m interested. How does the stopping power compare to the drums?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
09-09-2018, 11:54 PM | #82 |
60-66 Nut
Hopefully someone that has bought these and installed them will chime in......
06-17-2019, 11:33 PM | #83 |
You don't make a kit to fit the Dana 44 GMC truck rear ends, do you? Does this fit them???
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
06-18-2019, 11:22 PM | #84 |
60-66 Nut
No I do not make a rear disc conversion for the 6 lug Dana 44. No, this bracket set is designed for the '64-'82 GM truck 12 bolt or '79-'87 GM truck 10 bolt. You are the second to ask about this in about a month, but before that I have not had a request for. If I were to develop a rear disc bracket set for the Dana 44, I would use the '79-'85 e-brake caliper. But now you have posted elsewhere discouraging people in regards to the '79-'85 e-brake calipers. I have not seen that they are hard to find, nor have I heard of anyone having a hard time finding them.
11-18-2019, 06:01 PM | #85 |
Are these brackets still in production?
Thank you... |
11-18-2019, 11:38 PM | #86 |
60-66 Nut
I fabricate all of my products everyday. This is one way I attempt to make a living. As long as the thread isn't closed, the parts are available.
01-02-2020, 08:13 PM | #87 |
Any word yet on how to hook up the ebrake with this setup? Just curious if someone has determined a way to use the stock ebrake cables.
01-02-2020, 10:26 PM | #88 |
60-66 Nut
I don't think the stock e-brake cables for your drum brakes can be utilized. You will have to go with a custom set of cables.
01-19-2020, 09:11 AM | #89 |
I have a stock 6lug 72 12 bolt 4x4 and would like to get a set of brackets for my application with gloss black powder coat. Can you pm me with a total cost and payment info. (PayPal )
Thanks Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
01-19-2020, 10:59 PM | #90 |
60-66 Nut
PM sent
07-06-2020, 02:22 AM | #91 |
GM Addicted
I see you reference a GM metric caliper and showing photos of front calipers test fitted. What GM metric calipers are those if their not D52 calipers. Are they D154?
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
07-06-2020, 09:46 PM | #92 |
60-66 Nut
Yes the '78+ Metric calipers are the D154 calipers.
12-09-2021, 08:39 PM | #93 |
Junior Member
I'd like to order a set of brackets.
12-09-2021, 09:11 PM | #94 |
60-66 Nut
03-17-2022, 07:16 PM | #95 |
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
11-09-2023, 02:10 PM | #96 | |
I am looking at converting to a 6x5.5 rear axle. Would it be as simple as swaping my axles and using the later chevy truck rotors as mention in this kit? Or do I need to change the spacing, calipers, and rotors? |
11-09-2023, 04:42 PM | #97 | |
60-66 Nut
Sorry but no it is not that simple. There is no such thing as a 6 lug rotor that has the exact same dimensions as the Astro/Safari rotor. Everything must be changed including the brackets. The only bracket that is the same are the base plates.
