09-16-2018, 11:17 PM | #1 |
Blazer for snow plowing?
Just ended up in a deal which could change my plow plan. Was in process of moving the snow plow to a 88 one ton crew 4 speed, 454, 456 ratio. Would be long with how far the plow sticks out.
In this deal I ended up with: -a 1/2 square auto, 4x4, good motor, good canopy -A blazer, auto, 6 bolt wheels, motor started to be removed, older winch, manual boat lift, part of propane set up and a Detroit locker, dash apart; -A cab with the high buckets. I got all this for $500. I ended up in this deal as I was looking for a $500 -900 motor for another square and a friend arrange this, had 5 min. to decide. Would it be worth it to use the blazer as the plow truck, I have a fairly large Arctic plow. Are the Blazers with 6 bolt wheels a heavier set up or did they all have 6 bolts. Will a auto hold up for the plowing? Thanks |
09-17-2018, 07:18 AM | #2 |
Re: Blazer for snow plowing?
Lots of people have plowed with Blazers since they came out. An 8 ft plow may be a little too heavy though. New leaf springs would solve that issue.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-17-2018, 02:29 PM | #3 |
Robert Olson Transport
I have used blazers for plowing but a 6 ft blade no issues great turning radius
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-17-2018, 04:22 PM | #4 |
If plowing anything other than. A driveway, I'd use a blazer for sure
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
09-17-2018, 09:30 PM | #5 |
The small turning radius was the idea, just figured out it is a 77 and has duel fuel, not sure how that works or if all the parts are there. Starting to look like a bigger project than can be completed before snow fall or longer. More projects than time, need to prioritize, septic tank and well are at the top of the list at the moment. Would of liked to use the locker on something. oh well
