08-11-2018, 02:13 PM | #126 |
Re: slammed 57
agreed! the floating grille is a great look
08-11-2018, 05:59 PM | #127 | |
Posted via Mobile Device Last edited by slammed57; 08-11-2018 at 07:04 PM. |
08-11-2018, 07:14 PM | #128 | |
Re: slammed 57
To me, this is what sets yours apart from other attempts at floating centers I’ve seen. They looked good. Yours looks much better/more custom. What if anything will be done on the center grille where the factory perimeter pieces used to mount? In the pictures it looks like the surface is raised in those spots to “locate” the factory pieces.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
08-11-2018, 07:37 PM | #129 | |
Re: slammed 57
08-12-2018, 12:39 AM | #130 |
Re: slammed 57
Nice work!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
08-13-2018, 06:54 PM | #131 |
Re: slammed 57
Sweet I bet you have a smile every time you drive it, and laugh like a little school girl every time you mash the gas.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-18-2018, 06:49 PM | #132 |
Re: slammed 57
movin forward a bit
fabicated some bumper mounts, a little beefy but it wont be flexing installed the steering colum. the hole just below the colum is where i first mounted it, didnt really csare for the fit so i moved it a little higher , so now I have another hole to fix picked up some seats , had to raise and stretch to seat mounts to get them to work, I will be trimming the top of the seat to where it will be flush with the rear window Last edited by slammed57; 09-20-2018 at 09:01 AM. |
09-20-2018, 09:03 AM | #133 |
Re: slammed 57
I guess I did something wrong for the pictures were not showing, I believe you should see the pics now
09-21-2018, 06:37 PM | #134 |
Re: slammed 57
those seats look great Mike, how will they feel on your back if you chop off the tops?? You're getting closer my friend.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
09-23-2018, 11:26 AM | #135 |
Re: slammed 57
they should be ok morrie , we'll see, its all about looks not comfort with hot rods isn't it? lol
10-11-2018, 11:23 AM | #136 |
Re: slammed 57
Well I installed some soff seal door seals and it knock off all my door pannel alignment with the cab . They did settle in quite a bit, for they been on for about 3 weeks and I pushed the truck in and out out of the garage into the hot florida sun hoping it would form better which they did ,but still about a 1/4" off. so I decided to split the door sills and push them out where they need to be
I appolgize for the side ways photo, I forgot to turn my phone sideways to take a picture but here you can see about a 1/4” difference from the door and the cab And now after spiiting the door jam and welding into place, back to where they should be. WHEWWW! Got a few more goodies . this will keep me busy for the next 2 weeks. Iam welding in a smooth dash so I decided to pre install the a/c system for it would be easier to mock up before welding in the dash. If i didnt do it this way it would be a nightmare to put in Last edited by slammed57; 10-11-2018 at 06:06 PM. |
12-05-2018, 04:00 PM | #137 |
Re: slammed 57
graphed in the one piece dash yesterday
Also squeezed in the vintage air gen iv unit( its a big unit and tight fit due to the engine set back ,but its as snug as a glove).. after i cut out the original dash I mocked up the condenser, pre- ran all the lines, bulk head fittings made sure there was enough room for all the vent runs, and defroster vents, welded in threaded studs so the fire wall remains clean. If didnt do this when the dash was cut out and would have put the smooth dash in first, it would have been a nightmare to get it all put in.( Thanks rick mellon for that idea ) If you look way down there you can see how i ran the A/C lines and the heater lines just hidden under the A/C lines ( for a clean look with easy maintenance if need be,, the dryier is tucked up under the fender Found some pre-molded heater lines so I can run them where It needed to be. put in a more compact size hood latch and relocated |
12-05-2018, 04:39 PM | #138 |
Re: slammed 57
Very clean!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-05-2018, 07:43 PM | #139 |
Re: slammed 57
Very nice
My taking way longer than expected 58 build |
01-26-2019, 11:26 PM | #140 |
Re: slammed 57
working on a radiator cover to finish off the engine bay.. need to add some speed holes and mounting hardware. All I need is the brake master cylinder and booster to have it ALL completed....I think!
01-27-2019, 01:01 AM | #141 |
Re: slammed 57
gorgeous!
01-27-2019, 03:37 AM | #142 |
Re: slammed 57
Nice work, some really nice custom touches. I'll be fitting the door seals soon for the every same reason.
01-27-2019, 09:18 AM | #143 |
Re: slammed 57
Very nice work.
Kim |
01-27-2019, 12:19 PM | #144 |
Re: slammed 57
Looking good!!
01-27-2019, 07:42 PM | #145 |
Re: slammed 57
Nice work!
01-30-2019, 01:22 PM | #146 |
Re: slammed 57
relocated the air bag bracket hieght and pan hard bar for the correct ride height, still need to intall the shock mounts and rear sway bar....I would like to go over the rear end with the exhaust but Iam running out of real estate quickly here
02-01-2019, 12:09 PM | #147 |
Re: slammed 57
sorry for the re post here, but they way I use to post pictures , most people cpould not see them.......so here we go again, lets see if i figured it out... please let me know if you cant see these pics.. I would appreciate it
I graphed in a smooth dash and installed the vintage air geniv. its a pretty big unit but its in (thank god) also in one pic you can see how i routed the ac lines as well as the heater lines for a clean look down under the inner fender well I also found some pre molded heater lines so i can route them where i wanted them Last edited by slammed57; 02-01-2019 at 12:21 PM. |
02-01-2019, 12:16 PM | #148 |
Re: slammed 57
here you can see after i added the soffseal door seals it knock my door pannel alignment off . I pushed the truck in and out of the garage to sit out in the sun for the past few weeks to see if they would settle in which they did but still not where i wanted them to be.....soooooo more cutting and welding....I did get them back into alignment (WHEEEWWW) (sorry for the side ways pic.
02-02-2019, 11:02 AM | #149 |
Re: slammed 57
Looking fantastic ! Nice job on everything.
02-02-2019, 12:45 PM | #150 |
Re: slammed 57
I enjoy following your build. It seems like the Soff Seal seals were a lot better than the brand x stuff I tried first. It took some readjusting to get the doors to line up with adjacent panels. So far the rubber has not compressed, 4 months and counting. Nice tight seal though, no rattles or wind noise...
