09-11-2018, 04:50 AM | #1 |
windshield wiper pump
How do you wire a windshield wiper pump
09-11-2018, 02:28 PM | #2 | |
The Older Generation
Re: windshield wiper pump
The pump is wired with the windshield wiper motor They use the same wire loom. If you are talking about an external aftermarket pump here is a post by member "Linus6129":
The original wiring is shown in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=413551 LockDoc
09-12-2018, 09:08 AM | #3 |
Old member
The stock pump and after market pumps I have done are 12 volts to pump motor and the ground goes to the switch. So when you turn it on you ground it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-19-2018, 01:31 AM | #4 |
The ground goees to the pump, where does the positive go?
09-19-2018, 12:27 PM | #5 |
Positive is the Yellow wire and it comes from the fuse block to the washer pump then on to the wiper connector. Here is a picture of the wire connections on the wiper/pump. The Brown connector is the washer pump and the Black connectors are for the wiper. The Light Blue, Dark Blue, and Black wires go to the wiper switch in the dash.
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-19-2018 at 12:42 PM. |
09-21-2018, 02:06 AM | #6 |
This the pump that's on my 71 C10. Do I just follow your instructions juice using the negative in the positive?
Last edited by tino0217; 09-21-2018 at 02:08 AM. Reason: Asking another question |
09-21-2018, 02:09 AM | #7 |
Did the picture of my pump come through can you see the picture
09-21-2018, 02:10 AM | #8 |
Before I forget I really appreciate your response the very quick and very beneficial this is new to me but I really appreciate your help
09-21-2018, 03:11 PM | #9 | ||
No problem.
09-26-2018, 07:00 AM | #10 |
Gonna try again. This a pic of the pump for my 71 C10. It looks like it's stock for this truck. With these two wires to start with, would i go positive to the fuse box and negative to the wiper motor?
09-26-2018, 10:22 AM | #11 | |
To wire it into the stock switch look at the picture I posted in post #5 above. You have to unplug the brown connector, put extensions on the red and black wires on the external pump that you have, with male spade terminals on the ends. Solder all splices and use some heat shrink tubing on them. Plug the red wire into the connector with the yellow wires and plug the black wire into the connector with the Dark Blue wire. With the key on the external pump should now work with the push button on the original wiper switch. The nice thing about doing it this way is that it already has a fuse in the circuit. I would wrap the connector with a piece of electrical tape. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-26-2018 at 11:04 PM. |
09-26-2018, 10:25 PM | #12 |
Brother, i appreciate your patience and quick response. I'm in Seattle n it's gonna get hazardous without this working. Thank ypu and God bless
09-26-2018, 10:59 PM | #13 | |
No problem. Let us know how it goes.... LockDoc
