Old 10-01-2018, 02:52 PM   #1
Zone47
Zone47's Avatar
Angry What kind of gas mileage do you get with your 67-72?
... and what is your engine/tranny/rear end ratio?
I know most people don't care about fuel mileage but I noticed my 68 C10 was sucking gas like crazy so I started checking and am only getting 10.5 mpg.
I'm just puttering around town and to a few car shows now and then, nothing fast or aggressive.
So my setup is a 350 with pretty much stock cam and crappy 8.5:1 compression, an Edelbrock (quadrajet type) carb and headers. The tranny is a Turbo 400/stock torque converter and the rear end is a 12 bolt 3:08 limited slip.
I was thinking this truck sould normally get around 14 or 15 mpg. Maybe it's because the tires are larger and the body is not aerodynamic?
Ok so waddaya got and what's your mileage looking like?
Zone47 is offline   Reply With Quote
Old 10-01-2018, 03:04 PM   #2
mike1971c10
mike1971c10's Avatar
Re: What kind of gas mileage do you get with your 67-72?
I have just about the same running gear, but with a 350 tranny. I think the most I've gotten is 12 mpg. Maybe someone else gets better mpg
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 10-01-2018, 03:04 PM   #3
Smitty
Smitty's Avatar
I'm getting about the same as you. 60 over 350 edelbrock 4bbl. 700r4 3:56 posi.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 10-01-2018, 03:04 PM   #4
Barnfind46
Barnfind46's Avatar
12 to 14 MPG is not out of reach.Keep your tire pressure at the top of the safe usable range for your tires and keep it in good tune and you should do better. I do know that fuel with ethanol tends to drop mileage a bit. Mine is a C-20 with a 327, TH 350 and 3.73 gears. I get about 14 to 15 MPG.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 10-01-2018, 03:11 PM   #5
P7M89MM
P7M89MM's Avatar
6-7mpgs . ZZ502, built th350, 3200 stall, 3.73 posi.
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts
16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust
15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs
16 Malibu Response TXi
P7M89MM is offline   Reply With Quote
Old 10-01-2018, 03:49 PM   #6
dfwright
dfwright's Avatar
I have stock 350, stock quadrajet, stock TH350 transmission with .308 gears, and I get between high 12 to mid 13 mpg, depending on where and how I'm driving
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 10-01-2018, 04:37 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
Like my sig says, 400/400THM/3.54 axle, factory equipment, except the engine and trans have been rebuilt. I haven't checked it without the travel trailer; when towing that, I get 7 MPG. I recall my FiL telling me it used to get 13 mpg, but we put a 12" taller camper shell on it, so it's going to have dropped because of that.
~Steven
Simi Valley, CA
Old 10-01-2018, 04:56 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
I'm not much help because I really don't care, I just enjoy.
402 /400 /3.08 posi
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-01-2018, 05:08 PM   #9
tdangle
tdangle's Avatar
Around 14 mpg with a stock 350, 200r4 trans and 4.10 gears. This is mostly around town with a little freeway at 70 mixed in.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-01-2018, 06:18 PM   #10
Chris_oz
Chris_oz's Avatar
stock 350, 4 speed, 4.57 diff on 8.75r16.5 tyres, if I sit on or under 60, its 15mpg.
any faster and it drops to 12mpg.
Bone stock in every way, 72k on clock, stock Qjet.
Chris_oz is offline   Reply With Quote
Old 10-01-2018, 06:58 PM   #11
OregonNed
OregonNed's Avatar
I get 12 ish with the non-ethanol premium I use.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-01-2018, 07:12 PM   #12
72c20customcamper
72c20customcamper's Avatar
Really 10 mpg around town is about the norm for a truck made when gas was 45 cents a gallon. Mine gets 12 on the highway doing 60. And that's in 4200lb box.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-01-2018, 07:19 PM   #13
Andy4639
Old member
Andy4639's Avatar
Talking Re: What kind of gas mileage do you get with your 67-72?
71 with 2014 LS 6.0 and 4L80-e trans. 4:10 gears get 16-18 running 75-80 MPH with the AC on.
Ramp truck might get 12 with 350 and a granny 4 speed in it. No idea what rear end gears are.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-01-2018, 08:32 PM   #14
Willys47
Willys47's Avatar
460 / 400 trans / 373 rearend I cant pass a gas station .
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 10-01-2018, 09:05 PM   #15
custom10nut
custom10nut's Avatar
I’m satisfied if I average 13-15 on the highway. I will stop for gas at 200ish miles, but try not to go less than an 1/8th before stopping. If I put a load, or have long hills, and the ol girl drinks like a sailor on shore leave. Doesn’t matter though, she ain’t goin nowhere
I run a standard 350/4bbl TH350, and 3.73 diff
custom10nut is offline   Reply With Quote
Old 10-01-2018, 09:10 PM   #16
weim55
SWB fleet 1/2 ton, '99 roller cam 350 9.8 compression w/ mild cam, Edelbrock performer intake and AFB carb, headers, TH400 w/2500 stall, 3.54 rear. 15mpg @ crystal 65mph, 11mpg @ 75mph, 10-12mpg mixed driving. 10mpg pulling the race car on a trailer @ 60 mph. 5000-7500 feet elevation.
In my years of engine building I found a typical V8 will get one additional mile per gallon per point of raised compression.......
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 10-01-2018, 09:13 PM   #17
I don't want to talk about it!
It sucks now, but used to get a steady 12.5 no matter how I drove, hiway or country roads. It's been more like 10 in more recent years. I put different heads on a couple years ago and now it seems to be just under 10.... '72 K2500 350/TH350/4.10 with 285/75-16 Goodyear Duratracs
Old 10-01-2018, 09:23 PM   #18
gvw5400
gvw5400's Avatar
LWB fleet 1/2 ton, 350 300 h.p. cam, Edelbrock performer RPM, 750 cfm AFB, ramhorns ,2.5 true dual exhaust, CH 465 4 spd, 3.73 axle ratio. 15.25 mpg @ 65-70 mph 5000' to 9000' elevation.
All the Best, Dirk
gvw5400 is offline   Reply With Quote
Old 10-01-2018, 09:28 PM   #19
Zone47
Zone47's Avatar
Arrow Re: What kind of gas mileage do you get with your 67-72?
Hmmm! I guess I'll just some high compression heads, an air gap performer, a 280/460 cam and not worry about it. It sounds like it will probably at least still get 10 mpg with all that, but at least run better.
Old 10-01-2018, 09:30 PM   #20
Fbks_Cruiser
Fbks_Cruiser's Avatar
72 K2500. 350/TH 350, 4:10, 235/85 R16 tires, HEI, Eldebrock 1406 carb, RV cam. 10-11 mph mixed highway and town driving using gps since my speedo is off by about 10%.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is online now   Reply With Quote
Old 10-01-2018, 09:44 PM   #21
lutronjim
My 70 C10 with 307 4 barrel when new got 16mpg on highway when driven for mileage. I upgraded to LC9 with 65E and now driven for mileage on highway gets 21.
lutronjim is offline   Reply With Quote
Old 10-01-2018, 10:00 PM   #22
Steeveedee
Who Changed This?
Steeveedee's Avatar
402 /400 /3.08 posi
I don't know if I've said it before, but that is one SWEET truck!.
~Steven
Simi Valley, CA
Old 10-01-2018, 10:35 PM   #23
poway
1968 GMC half ton fenderside. Stock 250 six, turbo 400 trans, 3.54 rear end. My daily driver for about 2 years. 13-15 mpg.
poway is offline   Reply With Quote
Old 10-01-2018, 10:46 PM   #24
jocko
jocko's Avatar
That's the spirit. Just remember - it takes MANY MANY years of spent gas money before you'd have paid what it would have required to have bought a brand new truck today that MIGHT do maybe 5-10 mph better in the fuel economy department. Drive and enjoy
Old 10-01-2018, 11:17 PM   #25
weim55
Like to hear from some six-cylinder people.......
