Old 07-26-2018, 03:05 PM   #176
JohnJ@RideTech
JohnJ@RideTech's Avatar
Re: Ridetech 4-Link Coil-Over Install
Originally Posted by z71se View Post
Yes I decided to retain the stock-type front suspension with 2.5" spindles, and 2" Eibach springs that the truck had when I got it, for ride quality purposes.
We can probably get you in a good spot just using a set of our HQ shocks with what you have. If you can get me a measurement from mount to mount at ride height in the front, I can spec something out for you.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 07-26-2018, 03:09 PM   #177
z71se
I do need front shocks... I'll measure when I get the motor in and back on the ground. Truck is getting painted next.
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 07-26-2018, 05:02 PM   #178
GIZZ
GIZZ's Avatar
Loving this color combo, same as my panel truck.
Do you offer same shipping and T deal for our other vehicles?
We need the matching IFS to this c3 rear kit
http://www.youtube.com/watch?v=DJZzc...ature=youtu.be
My other car is also due for an upgrade... I need more money and time for all the stuff I'd like to do.
GIZZmotorsports on YouTube & my panel truck build
'69 c10 panel, '75 c35 flatdeck car hauler
GIZZ is offline   Reply With Quote
Old 08-01-2018, 10:30 AM   #179
JohnJ@RideTech
For sure man! We can get you fixed up!
John J.
Sales/Tech
Old 09-05-2018, 03:38 PM   #180
JohnJ@RideTech
Is there anything you guys would like to see pictures of?
John J.
Sales/Tech
Old 09-05-2018, 03:48 PM   #181
z71se
Yes how about tailpipe routing above/ below the rear cross bar.
Old 09-28-2018, 11:35 PM   #182
Rexroth
After we had the front end buttoned up, it was time to install the front frame bracing included in the kit.
These components are designed to take the flex out of the front of the truck and add support to the steering box area. The braces will give the truck a better feel through corners and remove the steering box flex under hard cornering. The cross brace has Heim ends and lock nuts for adjustability.
Installation of these pieces is pretty straight forward. The instructions will tell you what bolts will need to be removed and where holes will need to be drilled. Just like the c-notch, we used a center punch and a pilot hole before drilling to final size.
Attachment 1689602
Attachment 1689603
Curious, does the cross brace with the heim joints come with the front braces when you order separately?
Rexroth is offline   Reply With Quote
Old 09-29-2018, 12:19 AM   #183
z71se
Mine did not
Old 09-29-2018, 10:38 PM   #184
PunishedC10
I ordered the front brace kit and mine didnt come with the heim joints so this must be a newer design
1964 Coupe Deville(cruiser)
1966 Chevy II Nova 2door Hardtop
1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys
2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s
2000 Trans Am WS6, LS1/T-56, too many mods to list
PunishedC10 is offline   Reply With Quote
Old 09-30-2018, 12:47 AM   #185
Sik66
Like the look of the "squared" u bolt for the rear diff brackets on the 4 link....I might have to see about bit upgrade for mine.....would have to be way better then 4 bolts a side....
Sik66 is offline   Reply With Quote
Old 09-30-2018, 05:09 AM   #186
z71se
John @ Ridetech, I would like to know, why on earth isn't there a rod end at both ends of the panhard rod? Even getting things lined up during install, I have to bind the bar into place. I can only imagine what it's doing going down the road, even with a heim joint on the passenger side. Ever have anyone cut off the urethane bushing on the driver's side and weld on a reverse threaded piece of tubing so they could run a 2nd heim joint? Even the Mustang guys do it:
Old 10-05-2018, 02:36 PM   #187
z71se
Is John @ Ridetech still monitoring this thread??
Old 10-08-2018, 01:35 PM   #188
N2TRUX
Happy to be here
N2TRUX's Avatar
He is, but he has been traveling quite a bit too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-13-2018, 04:56 PM   #189
1957 Chief
Proud Vet that loves the USA
I asked him the same thing when we were at LS fest last month. I also mentioned the 4-link bars too. He said he would take it back to the engineers.
I will most likely make all new bars with dual heim joints in the near future.
And John has been on the road ALOT the last few weeks.
Bubba
1957 Chief is offline   Reply With Quote
Old 10-15-2018, 08:11 AM   #190
JohnJ@RideTech
Whats up guys! Im terribly sorry for the slow response time.
I've been all over the place recently and for whatever reason, I stopped getting notifications on my new phone when someone replied to these threads.
Anyways, you guys are correct. The new design does NOT include the parallel brace that runs between the two primary brackets. When we originally designed that brace, we believed that having the additional component in there would prove to be beneficial in stiffening the front end. Come to find out, the other bars did an adequate job of removing flex on there own so we removed the double heim end piece (which in turn helped reduce the over all retail cost.)
As for the rear panhard bar, it has to have a fixed style bushing on one end. If not, the bar will rotate and you will have metal on metal contact which would create abnormal wear and excessive noise. That is the main reason for the bushing on one end and the R-Joint on the other. That design provides minimal stiction, noise and rotation.
Hopefully that will help you guys out.
As always, if you ever need anything dont hesitate to call me direct at the office. Ill be more than happy to try and answer any questions you have (812-481-4737). You can also shoot me a message direct on Instagram @Ridetech_John
John J.
Sales/Tech
Old 10-15-2018, 08:12 AM   #191
JohnJ@RideTech
I will try and get some photos of our exhaust, hopefully that will help.
Ken (N2TRUX) has some pretty detailed photos of his exhaust. Maybe that will help you out.
John J.
Sales/Tech
Old 10-15-2018, 06:14 PM   #192
SCOTI
SCOTI's Avatar
Why wouldn't an adjustable poly bushing would work as long as there is an appropriate jam nut?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-15-2018, 06:39 PM   #193
z71se
John, a swedged tubing panhard rod with heim joints on both end, and spacers on either side of the heim joints, cannot possibly come into contact with anything. Yes, the bar will rotate, just like a Cal-Tracs setup rotates as the suspension compresses and articulates. Spacers on either side of the heim joint prevent it from contacting any bracketry.
I've got the 4-link installed on my truck right now. But I couldn't help notice that I had to pry the panhard bar into place. Binding at rest will be multiplied several fold as the suspension articulates. It just seems to be like a bad design considering you are already using one of the "R-Joint" heim type joints on the passenger side.
Basically 100% of the solid rear axle panhard bar setups on the market today from BMR, Maximum Motorsports, and others use this dual heim joint swedged tube design. The added benefit of the swedged tube is that it allows you to center the rear axle with the truck/ car on the ground instead of removing the bar over and over to do so. Perhaps I'm beating a dead horse here and need to modify this new kit as I see fit.
Old 10-16-2018, 08:41 AM   #194
JohnJ@RideTech
I get what you are saying but our panhard bar is NOT straight like the one on the Mustang. (See photo below)
Because the bar is bent, obviously the weight of the bar is offset. Because of this, if you put a double heim on the bar it would rotate down towards the ground. In a situation where the roads were bumpy or rough..the bar would "flop" up and down THEN we would be on here talking about why we didnt put a bushing in it to cut down on rotation.
The panhard bars job is to keep the rear end housing located in the center of the truck. If you take it out, there is a chance that the frame and rear end would not be centered (especially when you remove all of the rear suspension to install a 4-link) So, its not uncommon that the panhard bar doesn't fall right back into place when you reinstall all of the suspension.
Our engineering team has designed the bar to re-center the rear end in the truck, they did the math to ensure that the bar length is correct. We made one end adjustable for small adjustments where needed. If the amount of adjustment that is built into the R-Joint wont get the rear centered, then you may have something else going on.
Hopefully this clarifies why we dont use double heim ends.
Name:  Squarebody with Blazer Tank Measurements-Unedited.jpg
John J.
Sales/Tech
Old 10-16-2018, 09:40 AM   #195
SCOTI
SCOTI's Avatar
Ahh..... That fills in details I wasn't aware of & negates my suggestion.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-16-2018, 09:44 AM   #196
JohnJ@RideTech
No problem man.
We put that bend in the bar to accommodate different housings.
John J.
Sales/Tech
Old 10-18-2018, 10:11 AM   #197
N2TRUX
Happy to be here
N2TRUX's Avatar
Exactly. With out that bend a straight bar would be close to the rear end cover. For those that chose to run a HD rear end, or a high capacity cover this resolves those clearance concerns.
Articles-
"Refining Sierra"
Old 10-18-2018, 10:17 AM   #198
N2TRUX
Happy to be here
N2TRUX's Avatar
When I bought Scarlett it had dual exhaust that ran out behind the rear wheels. I really liked how the Borla XS mufflers sounded great outside, but the rear exits and a butt load of sound dampner made the cab nice and quiet. Running true duals out the back is a challenge with a 4 link, but it is possible. My guy was able to rout 2.25" exhaust pipes up and over the axle. He ran straight back and we added turn downs right before the rear bumper.
Articles-
"Refining Sierra"
Old 11-05-2018, 09:06 PM   #199
z71se
Hey John, what size wheel and tire are you using on this truck?
