10-15-2018, 12:22 PM | #2101 |
Re: What did you do with your truck today, Part 3
What did I do with my truck? We did what trucks were meant for........ Haulin' wood chips.
Craig My truck '50 Chevy 3100-5 window If I'm not working on my truck, I'm fishing with the wife or smoking Salmon. |
10-15-2018, 12:43 PM | #2102 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
10-15-2018, 04:24 PM | #2103 |
I love it! Somewhere there was an old thread about these trucks still working; Maybe we should start another one!
I once loaded my '50 pickup with about a ton of bagged sand:
1951 Chevy Panel Truck |
10-15-2018, 05:31 PM | #2104 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=767843
10-15-2018, 05:52 PM | #2105 | |
Brian
10-15-2018, 07:44 PM | #2106 | |
10-15-2018, 08:26 PM | #2107 |
I just added some more pics to that thread.
10-16-2018, 01:15 AM | #2108 |
Just a little bit out in the garage tonight, made a patch and started welding it in the bed. Again, this is a custom thing I did 39 years ago that I am now un-doing. LOL It's so odd, I cut this hole for the fuel filler to up in the rear fender from the tank I got from my '64 Nova that I put under the rear of the bed. I will now be cutting another one like it up in the front of the bed for the stock 48 tank. I was rocking and rolling figuring I would finish this up, then I looked up at the clock to see it was 9:30! Nope, I will finish it tomorrow.
Brian
10-16-2018, 05:25 PM | #2109 |
been driving mine a lot. runs well. im still getting used to the sound of the new fan. its loud. sounds like a tornado. when you drive an old car or truck you get a lot of attention. any time I stop I get comments and questions. today I got an arm out the window thumbs up. the death rattle is a peoples truck for sure.
10-16-2018, 08:22 PM | #2110 | |
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
10-16-2018, 10:38 PM | #2111 |
Picked up an axle for free, hoping for the 4:11 gears and a posi, but I guess we will see. Installed 3:38 gears 10 years ago when I had a 3 speed. Now I have an OD transfer and the 4:11 would work great with the 283. Any bets before I open it?
Out of a 62 Chevy Truck |
10-16-2018, 11:40 PM | #2112 |
So.... I couldn't wait. Me and the wife dug in. 3.90 gears. Not what I wanted, but I'll take it for the price. At least till I build and axle.
10-17-2018, 12:57 AM | #2113 |
I got the patch over the filler hole welded in and finished. I then figured I would make a patch and fix the rear stake pocket where I ground the stock weld off 37 years ago to pull the bed apart. I painted it apart and never welded it. I am thinking I will patch this up and bolt it together like I did before and not weld it.
So I got the patch made and will get on that tomorrow. Brian
10-17-2018, 01:49 AM | #2114 |
Nice patchwork, Mr. Martin! In the pic in post #2108 you have 3 metal "feet". Are those to pull the heat out when welding? Are they magnetic? (I think I'm showing my rookiness...)
10-17-2018, 02:26 AM | #2115 | |
I installed my rubber hood bumpers today. Typically, what should have been a 10-minute task turned into an all-afternoon ordeal requiring removing the latch plate, sanding down the bumpers to close the gap at the nose, and then readjusting the hood.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 10-20-2018 at 05:44 AM. |
10-17-2018, 10:02 AM | #2116 | |
Brian
10-17-2018, 11:05 AM | #2117 |
if you don't have any of these c clamp vice grips, and you do any welding, you should invest in a pair or 10. you will be surprised how much you use them.
10-17-2018, 12:08 PM | #2118 | |
Brian
10-17-2018, 03:04 PM | #2119 |
[quote=MARTINSR;8366203]No, those are just "C Clamp" vice grips holding the metal behind the hole to mark it with a sharpie, then I cut the piece out to butt weld it into the hole.
Brian I see you're good at trick photography too! Egg on my face! I have about 10, maybe more! Big, little, a pipe holder, etc. Thanks!
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) Last edited by DransportGarage; 10-17-2018 at 03:15 PM. |
10-17-2018, 03:13 PM | #2120 |
the vice grips come with ends like shown or ends with a flat surface, sort of like a c clamp would have. sometimes they are great as well and leave less of an imprint. sometimes they can be a pain too though. I have a few sets of both kind plus a couple of long reach ones. I use them all the time. various sizes help too.
10-18-2018, 01:15 AM | #2121 |
I got the patch welded in and finished on the RR bed stake pocket.
Brian
10-18-2018, 08:28 AM | #2122 |
10-19-2018, 12:22 AM | #2123 |
Well, next to nothing, maybe not even the five minutes. Today is my wife's birthday so we went out for a wonderful Japanese dinner with the family and when we got home I got out there and simply primed over the bare metal on the bed side I welded the patches on so I could but it back outside to wait for stripping and priming. I need to get back to the hood and get it in primer then all the other panels, get them in primer so I can move on.
Brian
10-19-2018, 08:04 AM | #2124 |
I'm doing the one step forward two steps back... cut the dash for the Navigation unit only to find that hits both the Wiper motor and the A/C air distribution housing. So I went down to the local car toys and bought an Alpine 9" with a single din. Got it in and dash reworked.
10-19-2018, 10:08 AM | #2125 | |
