Old 11-10-2018, 08:38 AM   #1
clemsonteg
Step up Patch
I’m considering purchasing a 71 burb and it has an area of rust on both sides at the step up to the cargo area. Is a patch panel available for this area?
clemsonteg is offline   Reply With Quote
Old 11-10-2018, 03:31 PM   #2
HO455
HO455's Avatar
Re: Step up Patch
Not to my knowledge. But either way here is the best thread I have encountered on the subject. For what it's worth if that is the only rust on the Burban I would find it hard to pass it up.
http://67-72chevytrucks.com/vboard/s...d.php?t=724682
P.S. Thanks to 04ls1gto for post his fine work.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 11-10-2018, 08:59 PM   #3
04ls1gto
Re: Step up Patch
Check out my thread on fixing this, it was a huge amount of work. I had to remove plywood floor and replace and it's going to be a lot worse then it looks
04ls1gto is offline   Reply With Quote
Old 11-10-2018, 09:09 PM   #4
04ls1gto
Re: Step up Patch
Old 11-10-2018, 09:33 PM   #5
clemsonteg
Re: Step up Patch
That’s what I was afraid of. I haven’t seen it in person yet and if it looks like that on both sides I can only imagine how bad it really is.
Old 11-12-2018, 09:00 AM   #6
Bigdav160
Bigdav160's Avatar
Re: Step up Patch
You can see in 04ls1gto's thread that his crossmember is rotted away too. In my case the crossmember is pretty solid but rust has gotten between it and the inside sheet metal.
Look in from the wheel well side.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
