11-26-2018, 03:11 PM | #1 |
Build front suspension before or after mounting the engine?
I've read it's much easier to remove the suspension with the engine mounted, because the weight of the engine helps. Note: I've already removed the suspension, this is a ground up.
I figured the same logic applies to building the suspension, but I've seen a couple builds done without an engine. I can't drop the engine yet, so I'm wondering if it's just as well to build the suspension without it? If I build the suspension first, you figure I need a coil compressor or will a floor jack suffice? Also, is there any reason to torque everything down after the engine is mounted? Doesn't seem so, but just asking. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-26-2018 at 05:07 PM. |
11-26-2018, 03:26 PM | #2 |
Re: Build front suspension before or after mounting the engine?
Not to difficult to do at all with the truck. I just did a complete front rebuild with Moog components in 2 days taking my time. Only thing I had to remove was the wheel wells, just for convenience sake, and to ease my back.
Jack stands are a must, the coils will not compress without them under the rear frame. The coils come out easily by just lowering a jack under the lower control arm. Of course you have to pop the ball joints loose. I made a very simple tool out of a large bolt and nut with a washer welded to it. Torch the old ball joint stud only, hit with cold water hose and torque the tool, POP! I could get you a pic of it if you like. Had a local Chevrolet dealer do the alignment, they were more than happy to do the work. Drives like a dream. |
11-26-2018, 03:30 PM | #3 |
I have only worked on two full suspension rebuilds (two different manufacturers), but I would say that you will need spring compressors. It's just too dangerous not to and maybe impossible without a torch. I don't think the weight of the engine makes much difference. When removing the coil springs, I guess you would not have to cinch the compressors down as much, but what are we talking about...an extra few inches? NBD.
Don't over think it...do it with the engine in or without, you'll not notice any appreciable difference. If you build the suspension before installing the engine (that's how I've always done it), just get the alignment items adjusted close (eyeballed) and take it to the alignment shop once the project is ready for the road. A far as torquing the suspension parts, definitely do that as you go. It does not hurt to check it all afterwards, but not necessary.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
11-26-2018, 03:40 PM | #4 | |
Any considerations for assembling the control arm shafts, other than to make sure the hole in the lower shaft faces 12 o-clock? By chance did you spot weld the shaft nuts onto the control arms? I don't know that there's a reason to, but the originals were spot welded. Some don't even know they exist, my parts guy swears they were never spot welded.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-26-2018, 04:40 PM | #5 |
Who's got steelies?
I rebuilt my front end with engine in, no front clip. Tried using a spring compressor but no place to get it in good. Just used a jack under lower a-arm.
The nuts were not welded to the arms, and I am sure it was factory parts still.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-26-2018, 05:13 PM | #6 |
Thanks for the information, it's appreciated. Looks like I have plenty to do with or without an oil pan currently in paint prison.
For what it's worth, I highly recommend securing the coil springs when removing or installing the suspension. It's simple to do, hopefully unnecessary, but better than a coil spring to the head.
11-26-2018, 06:30 PM | #7 |
I just dropped the upper and lower control arms in today and I'll be dropping in the engine before the front springs and suspension is tightened up . I need the weight to compress the front springs .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-26-2018, 08:23 PM | #8 | |
The welds, if any are VERY small. I didn't know they were there until I realized the grease nuts weren't coming off
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-26-2018 at 08:29 PM. |
11-26-2018, 08:58 PM | #9 |
No preference engine in or out, with the exception of it is easier to clean stuff without the engine in the way. My experience says to check the lower shaft locating rivets for damage. (See photo) One of mine was sheared preventing positive indexing of the shaft for caster settings.
I may be mistaken but I think the factory manual says to do the final torque of the shaft bushings at ride height. I can see why they may have welded them. There is a lot of torque on the bushings and not much in the way of threads in the control arm.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-27-2018, 06:00 AM | #10 | |
Here is a good thread with good pictures ,Start at post 17 . .http://67-72chevytrucks.com/vboard/s...d.php?t=560841 Can't stress enough about having clean threads , After looking at these pics I think mounting the shafts on the frame first is easier when working on a bare frame . these are all new Moog shafts .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 11-27-2018 at 09:04 AM. |
11-27-2018, 12:49 PM | #11 |
Couple pics
11-27-2018, 01:20 PM | #12 |
If that's a C10, I can tell you from experience that you won't need a spring compressor. Just put a floor jack under the control arm, bust loose a ball joint, and slowly lower the control arm until the spring falls out.
Never thought about this before, but it may be easier to install new springs with the engine's weight holding the frame down on the jack stands as you jack up the A-arm to compress the spring. Be sure to check the control arms shafts for excessive play, and at the very least clean and grease the threads. BTW, the control arm shaft nuts on my 69 C10 were NOT spot welded.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-27-2018, 04:19 PM | #13 |
I rebuilt the suspension on my 64 impala with the clip off and engine out. What a pain in the a@#!
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
11-27-2018, 09:36 PM | #14 |
I rebuilt the entire front end and put my motor in the frame for the weight when i installed the springs.... I though it would make it easier ..I have never seen the cross shaft caps tac welded
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-28-2018, 12:07 AM | #15 | |
I'll check out the link, thanks........Edit, just read it, nice. I didn't realize the "dimple" in the lower control arm shaft wasn't straight up 12 O-clock. I like your way of doing it, skip the vise and mount the shafts first.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-28-2018 at 12:25 AM. |
11-28-2018, 03:03 AM | #16 |
At the body shop.
The lower pivot U bolts are 200% easier with the engine out.
Never used a coil spring compressor ever. Usually get a coil cut while theyre out anyways.
" That didnt make it any newer " " Dont antique the equipment " |
11-28-2018, 08:46 AM | #17 |
"Great info. Grumpy, and I'll do just that. I was contemplating having my shafts finished as well (Moog), but being yours look so nice, I think I'll have them powder coated as opposed the paint prison alternative. "
The lower shafts should be installed and torqued it's easy to align the shaft with the pin in the front saddle .The upper shaft just needs to be slid on the shafts to keep it from rotating while installing the arms . Don't forget the u-bolt upgrade to the Dorman 13503 ,Just redrill the saddles to 9/16 . https://www.oreillyauto.com/detail/b.../13503/4527001 This frame was prepped /primed and then painted using Tractor supply Matte black with the catalyst hardener . Low budget frame paint and works great as long as you do good prep and prime . USE THE CATALYST HARDENER . https://www.tractorsupply.com/tsc/pr...ck-1-gal?rfk=1
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 11-28-2018 at 08:52 AM. |
11-28-2018, 12:23 PM | #18 | ||
The U-bolts slid through 2 of 4 powder coated saddles. They're all snug, which seems to be right.......I'm no expert, perhaps some play is more desirable with vibrations and that. I used a fine rounded file on a hole each for the two, not much to it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-28-2018 at 12:51 PM. |
11-28-2018, 12:31 PM | #19 |
I'm doing the same thing ,I cut 1 coil off . just touch up the cut end with some decent paint .
11-28-2018, 12:56 PM | #20 |
I put one together with the entire truck apart. Use a coil spring compressor, and make sure everything is together correctly when you take the compression off the spring. This was several years ago. I put the suspension together before I sat the engine. I've seen guys use a jack and bolt the frame down with a chain to hold it, but you can compress the spring enough with a clamp that compresses down the center (you can rent one from the auto parts place likely).
Good Luck!! |
11-28-2018, 01:22 PM | #21 |
You need the weight of the truck, the engine alone isn't enough. You'd still need a spring bomb, er, compressor.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-28-2018, 01:47 PM | #22 |
Just did a 2.5 drop and all new suspension parts on mine with engine in.
Edit: don't know why the pic is sideways was straight when I posted it.
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
11-28-2018, 03:50 PM | #23 | |
Also, I'm not sure original coil springs were intended to cut. The bottom coil differs from those above it, so seems it wouldn't seat quite right. Here's a pic. with some info.
11-28-2018, 05:18 PM | #24 |
This should help explain it from a suspension supplier Global West Suspension . A LOT of guys are riding around with cut coils . Cutting your old coils will provide drop but also increase a firm ride = good thing . Buying new drop springs can leave you with the drop and less of a firm ride = bad thing.
https://www.youtube.com/watch?v=VHPosx2oStU
11-28-2018, 09:51 PM | #25 | |
I suppose a cut coil offers a firmer ride because the coil is stronger toward center. Must make up for compromising the factory platform And how did you know I inquired on another set of springs?.....Shoot man, this is resource intense the first time out. Here's another area I'm not clear, what a shock. I understand a 1" drop coil by itself drops the body 2". But back to the 2.5" drop spindles. Do you believe I need 1" drop coils to accomplish that 2.5"? I did ask the vendor, pending.......No doubt stock coils would be more difficult and dangerous, the spring would have to compress another inch.
