Old 11-29-2018, 10:03 AM   #2376
mikebte
Re: What did you do with your truck today, Part 3
Originally Posted by MARTINSR View Post
I got out to the garage and added a few more strips of wood than I had up in the attic in the garage so I could put the hood halves up there until I am ready for them.
I then removed some bolts from the gas tank brackets and a crossmember. It's the first time I have actually touched the truck in over a week and it felt good.
Brian
I love how we all adapt in different ways when working in tight places. The stuff we put up with when working on our trucks.
mikebte is offline   Reply With Quote
Old 11-29-2018, 11:27 AM   #2377
MARTINSR
MARTINSR's Avatar
Got to make due. They are all nicely primed, I realistically could put them outside but just couldn't see myself doing that after all the work on them!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-29-2018, 09:35 PM   #2378
DransportGarage
DransportGarage's Avatar
I needed to upholster the panel behind the seat so I could install it and run wires to/through it. The power antenna had to go in first. All of the wires going to the roof are in as well, along with the few controls and A/C vents that go into the dash. Center speakers mounted in the dash and wired. Wiper mechanism installed. No sooner did I have the rear panel in that I realized I have to pull it to put in the lower outside seat belt brackets and the "B" pillar brackets. That'll be tomorrow.
Later: I just realized that the headliner has to be in before I put in the seat belt "B" pillar brackets and it's not upholstered. I'll have to think about all of this...
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-29-2018, 10:52 PM   #2379
MARTINSR
MARTINSR's Avatar
You are making a hell of a beautiful truck for sure.
Brian
1948 Chevy pickup
Old 11-29-2018, 11:57 PM   #2380
MARTINSR
MARTINSR's Avatar
Tonight the cab got unbolted from the cart, cleared the way to get it off, probably won't happen until Saturday but I'll find something tomorrow.
Brian
1948 Chevy pickup
Old 11-30-2018, 02:28 AM   #2381
DransportGarage
Brian
Thanks, Brian. I've got a lot of folks on this forum to thank for all of the ideas, encouragement and tips.
Bob
Old 11-30-2018, 10:49 AM   #2382
mikebte
Very nice, I like all the one off personal touches. That is what makes the truck unique.
Old 11-30-2018, 12:20 PM   #2383
DransportGarage
Thanks, Mike. As Ogre knows, it's almost as unique as his truck, because I stole a lot of his ideas. Kudos to Ogre!
Bob
Old 12-01-2018, 11:41 AM   #2384
evilokc
ive been neglecting work on my truck. I have been driving it though. I need to get out and do about 2 hours of work and get my heater going but I have been concentration on my daily driver. everything I own is broken. well not broken but it all needs some maintenance.
evilokc is offline   Reply With Quote
Old 12-01-2018, 11:43 AM   #2385
DransportGarage
Sometimes life gets in the way. Ask me how I know...
Bob
Old 12-01-2018, 01:34 PM   #2386
MARTINSR
MARTINSR's Avatar
My plans for lifting the cab off the cart have changed a little. I was going to use floor jacks on each side with a 2x6 board under the length of the rocker cowl to rear of the cab. Then I started thinking about the crazy balancing act that would be and the thought of having the cab roll off like a ball onto the garage floor gave me the shakes!
So last night I got the cherry picker out planning on starting one of those wooden braces under roof to lift it......then I see that with the chopping and sectioning of the cab and the big cherry picker I have I will have to go over the top of the cab! So I will be making a more complex piece for that, we will see!
That is my project today.
I also got a load of strap metal and wheels I had from my sons Falcon, that FILLED my little F100 bed trailer down to the shop to throw in the metal bin last night. That is always good, getting crap out of the yard!
Brian
1948 Chevy pickup
Old 12-01-2018, 02:31 PM   #2387
crossfire84
crossfire84's Avatar
So last night I got the cherry picker out planning on starting one of those wooden braces under roof to lift it......then I see that with the chopping and sectioning of the cab and the big cherry picker I have I will have to go over the top of the cab! So I will be making a more complex piece for that.
Brian[/QUOTE]
Why not use a strap?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 12-01-2018, 02:48 PM   #2388
MARTINSR
MARTINSR's Avatar
Brian
That just seems so slippery!
Brian
1948 Chevy pickup
Old 12-01-2018, 03:13 PM   #2389
dsraven
just make the wooden part long enough to attach some uprights on the outside ends. then make another mirror image wooden part that goes above the cab and attaches to those uprights with pins that pull out easily. that way there is no slipping of the strap and the cherry picker idea still works. ensure to make it long enough to attach the picker and lift but not hit the cab.
Old 12-01-2018, 03:16 PM   #2390
dsraven
you could even use the single wooden part above the cab, like a spreader bar used by cranes, then drop down some J style hooks to slip into the door openings. just would possibly be slippery in the door opening area.
you'll figure it out, you always come up with something innovative.
Old 12-01-2018, 03:33 PM   #2391
idbeast
straps bend the little rain channels above the doors. I use the wooden framing under the door jambs, with a second one with stand offs over the roof to keep the lifting straps from doing any damage. Unfortunately I can't find the pictures right now.
Jim
idbeast is offline   Reply With Quote
Old 12-01-2018, 08:09 PM   #2392
MARTINSR
MARTINSR's Avatar
After I did this I went into the house to get my wife and daughter to show them what an awesome dad and husband they have, just incase they didn't know really how awesome I was.
I rolled the cab back onto the rolls of bubble rap I laid on the garage floor and wham-o-bam-o it went back like it was nothing, like laying over a cardboard box, wham, done.
Also got the rear fenders up in the attic to get them out of the way until I need them in the future. I also relocated my inspirational picture so I can still see it.
I spent some time cleaning it up a little more and gave up for the day.
Brian
1948 Chevy pickup
Old 12-02-2018, 02:06 PM   #2393
svr
svr's Avatar
Steering column in
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 12-02-2018, 02:08 PM   #2394
svr
svr's Avatar
Made a bracket to hold master cylinder res.
Old 12-02-2018, 02:54 PM   #2395
evilokc
sound this in the kitchen last night when I came in from the garage
Old 12-02-2018, 02:57 PM   #2396
DransportGarage
Ruh-Roh...
Bob
Old 12-02-2018, 04:51 PM   #2397
DransportGarage
It's 65 degrees in SW Ohio this afternoon, so I'm painting some small parts in a 40-MPH wind.
Bob
Old 12-02-2018, 05:59 PM   #2398
dsraven
stand up wind, use high temp reducer,
don't park your good stuff close, lol
Old 12-02-2018, 08:33 PM   #2399
MARTINSR
MARTINSR's Avatar
LOLOL, I love that, "The management." Sounds like you have a nice lady to share life with.
Brian
1948 Chevy pickup
Old 12-02-2018, 08:34 PM   #2400
MARTINSR
MARTINSR's Avatar
Hope to get more done but this kicked my butt. Went to Harbor Fake tools and got some discs to keep going, I may get out there for some more.
Brian
1948 Chevy pickup
