12-16-2018, 05:11 PM | #1 |
Active Member
Hmm won't start.
So, went to go get some hay for the critters this morning and got nothing when I turned the key (72 C10). Battery has 12.45 volts and when the key is turned, no dimming of the lights, no solenoid clicks, nothing. Checked the fuse for the ignition and it's good. Thinking possibly the ignition switch which of course no one in this little town has. Am I missing something else that may be the issue? Thx for any guidance.
Jeff
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
12-16-2018, 05:30 PM | #2 |
Active Member
Re: Hmm won't start.
I bought a start switch from the local auto parts years ago for a similar problem. I hook up the battery to S connector on the starter and actually found the battery cable was so badly corroded internally at the post that it was not making contact to the starter.
You could try shorting the two together with a screwdriver to check to see if the starter will turn or if it has voltage going to it. Some don't care for that practice but I've used it many times to diagnose similar issues with my vehicles.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
12-16-2018, 05:32 PM | #3 |
Moderator
Is this an auto trans? If yes, check the gear lever is in Park...maybe a bad neutral start switch....
Do the gauges react when you turn the ign switch on? Can you jump the solenoid terminal to the battery lead on the starter? Should crank...if t doesn't, most likely a bad solenoid...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-16-2018, 06:01 PM | #4 | |
Active Member
12-16-2018, 06:09 PM | #5 |
First thing that I do if the battery is up and I get nothing is clean terminals, clean grounds, and check starter connections. The neutral safety switch might have come out of adjustment since you recently replaced it. Good luck hope you solve it quickly.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
12-16-2018, 06:18 PM | #6 |
Moderator
Use a small jump lead to jump between Sol terminal and battery positive lead on starter solenoid...
If it cranks, it is most likely Neutral start switch...you can bypass it with a jumper plug lead if its failed...the aftermarket ones sometimes dont last If it doesnt crank...check battery voltage at end of battery lead on starter... Must be 12V or more... If it is 12 V and still no crank...its a bad solenoid...
12-16-2018, 06:22 PM | #7 |
Active Member
Thanks all, I'll do some more checks tomorrow after I get off work
12-17-2018, 04:04 AM | #8 |
Had a similar issue with my '67 a few months back.
No neutral safety switch on that one. Ignition switch and wiring all good. Turned out to be the starter. Replaced and haven't had a problem since. Would sometimes start, then nothing.... but all gauges working and full battery charge. |
12-17-2018, 09:31 AM | #9 |
The first thing I do with an auto trans truck that won’d Do anything when I turn the key and I know the battery has juice is to hold the steering column collar with my left hand and wiggle it while turning the key to start.
After that it’s time to bust out the meter and check for proper voltage everywhere. If I am working on a truck that has an original style starter I’ll usually just order a late model gear reduction starter off Amazon because that’s a mod I will want at some point regardless.
12-17-2018, 01:27 PM | #10 |
Try hot wiring it with the switch disconnected.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-24-2018, 06:49 PM | #11 |
Active Member
I would like to thank everyone who responded with all the suggestions as to what it may have been. Of course it was the starter as many stated. However I also replaced the the ignition switch as it and everything attached to it was loose and wouldn't tighten up in the dash. The switch itself seemed like it was also leaking a bunch of sticky whatever.
All is good now with my truck. Thanks again to all and hope everyone has a Merry Christmas.
12-28-2018, 05:24 AM | #12 |
Check voltage at solenoid when turning key. If you have voltage check ground straps to engine. ( can check for good resistance by putting meter on resistance setting and going neutral post on battery to starter motor casing)
12-28-2018, 05:25 AM | #13 |
Sorry just seen you sorted top job
