#1751 | |
A guy with a truck
Re: How to: Ruin a perfectly good C10
Thanks for the boost, this will be a big hurdle that allows lots of reassembly to occur.
Progress report: I took a break from sanding to do some, um, sanding. What kind of psychopath wet sands and polishes his valve covers? This kind... Perfectionism is a disease. I’m leaving these at 90%, good enough ![]()
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#1752 | |
![]() Join Date: Sep 2015
#1753 | |
A guy with a truck
The eye for detail is a blessing and a curse. Nothing is ever good enough...
#1754 | |
![]() Join Date: Oct 2009
#1755 |
Still Learning
The firewall and valve covers look great! Keep at it..
#1756 |
On the road
![]() ![]() Join Date: Jan 2004
Chris, it's been ages since I've been on here and I have to say it looks great bro, can't wait to see it in person.
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
#1757 |
A day late and $1 short...
What did you use to clean and prep the engine for paint?
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#1758 | |
A guy with a truck
Thanks, Mike!
Sorry for the delay, hope it’s not too late. Initial clean was with oven cleaner to get rid of the gunk, then simple green/power purple/whatever skin-eating acid cleaner I had around with various brushes, rags, scrapers, and implements, then final prep with laquer thinner and 3M scrubbies. Lots and lots and lots of time spent in all of the little books and crannies.
#1759 |
A guy with a truck
Ok, folks. Need to some honest input, here. My original plan was to do everything under hood in black and orange, like a truck engine, but I kindof accidentally mocked up the engine like a late ‘60s hipo car big block and I also kindof accidentally like it. Thoughts?
#1760 |
A guy with a truck
It reminds me of this style, though I’m not sure I’d go so far as to do crossed flags and tonowanda decals.
#1761 |
Man of Mini-Talents
Chris, I think the engine looks great. Personally I like some color comtrast, and the only time I do blocks in black is to help hide any leaks
![]() I hate cleaning crud off more than about anything else on a project, but it's so nice when it's done.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#1762 |
It Is What It Is
I like it, think that it would look good in the truck. I have always liked the hi-po car big block look.
Kevin 65 Chevy SWB Fleetside Custom Cab (sold, so long old friend it was a fun ride) 68 Chevy SWB Fleetside Custom Cab 68 Camaro convertible www.louisianaclassictruckclub.com |
#1763 |
It looks good like it is, but you know I like the black and orange more. I will say that if you go with it like it is, you better powdercoat that intake an aluminum color because it won't stay pretty very long in the elements. I would seal up those billet valve covers too.
Where does the A/C compressor mount?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#1764 | |
#1765 | ||||
A guy with a truck
![]() Quote:
![]() The plan for the AC compressor is stock-ish location. Need to get the motor back in and see if plan A (Alan Grove with current compressor) will work. I fear it will interfere with the steering rack, so then on to plan B (Dirty Dingo or Holley). If. One of that works, maybe I’ll save my pennies for a Holley mid mount setup or just go ahead and install that rear sliding glass I want ![]() Quote:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 01-07-2019 at 12:33 AM. |
#1766 | |
I know, I know... But I have WAY too much invested in my little small block to change directions now. Brandi will kill me!
#1767 |
Personally I would like the black and orange, nothing shinin' up the joint. Subtle is sexy.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
#1768 |
On the road
I think you hit the nail on the head Chris, I think It's perfect the way it is, I love the orange.
#1769 |
Looks damn good brother, simple but tuff
#1770 |
![]() Join Date: Feb 2011
Tough decision...I think either way you go is going to look great....I really like the pics a few posts back!!
![]() '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
#1771 |
That's a tough one. I did mine all orange and black and I like it, but I see the muscle car look in the current color scheme you have and it looks nice too. I do agree that you'll need to do something with the aluminum pieces though. You'll be polishing like crazy if you don't. And that intake won't look good for long if it's left bare.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#1772 | |
I had the factory painted steel valve covers chromed because they were: A) Cheap B) I already possessed them C) After comparing to TRUE 70's era BBC chrome v.covers, they were much smoother. I used an Edelbrock TBI intake vs. the cast iron BBC intake w/the TBI adapter & a period correct dual snorkel air cleaner to top it off. I re-routed wiring & other asthetics to appear less electronic. I liked the older look once finished. I also did the 'Built by Chevrolet Tonawanda' v.cover & 454 air cleaner engine displacement decals to finish off the 'look'. The repop decals didn't survive underhood life for long before coming apart & have been removed...
#1773 |
Wow! I really like the look now.
I'm not a fan of the orange and black.
'71 C/20 350/T350. |
#1774 | |||||
A guy with a truck
Agreed, thanks Quote:
Thanks, I’m still undetermined. I like a simple, stock look, usually
#1775 |
A guy with a truck
Another variant. Pretty sure the water pump will be orange and the accessories black no matter what else happens...
