Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-19-2018, 08:10 PM   #1
twp1
1972 Blazer undecided!!
Here is the pic of the blazer i picked up today!! It was a 4x4 someone converted to a 2-wheel drive!!! If you notice i have a 4-wheel drive frame and suspension sitting next to blazer!! hopefully i get to start on it in the next month or so and i will post more!!!
twp1 is offline   Reply With Quote
Old 10-20-2018, 04:52 PM   #2
lks dcvn
lks dcvn's Avatar
Re: 1972 Blazer undecided!!
Alright! What are the plans for this one? Full resto back to stock or adding some modern comforts?
lks dcvn is offline   Reply With Quote
Old 10-20-2018, 08:51 PM   #3
twp1
would like some ideas!!! I think 4x4 is the option!!!!
Old 10-23-2018, 01:39 PM   #4
SeventyOne
Is a budget a concern? Skills for larger changes? Time?
Real easy for internet folks to throw out crazy ideas you may not have time/money/skills to pull off.
Big difference in me saying CUMMINS SWAP vs GM Goodwrench 350 haha.
SeventyOne is offline   Reply With Quote
Old 10-23-2018, 04:57 PM   #5
twp1
Money is definitely an issue!!!! But going to make it a 4x4 again and sell the other frame and 2-wheel components!!! Probably going to try LS-7 this time and make some other modifications!!! This may be the one I keep but it may take a little bit do to trying to finish up new house and old horse barn I am turning into my garage!!
Old 10-23-2018, 06:40 PM   #6
lks dcvn
lks dcvn's Avatar
I have 3 of these now. At one point I owned 7. Don't judge - I like these rigs.
1972 Chevy Blazer - factory 2wd
1970 GMC Jimmy - 2wd converted from 4x4
1971 Chevy Blazer - 4x4
I like them each in a different way.
If you want to go back to complete OEM specs based on the SPID- those usually have the best return on money - should you ever decide to sell.
Either way you go - it seems like solid examples of these trucks are going up in price.
Old 10-26-2018, 03:53 PM   #7
twp1
Starting the tear down!!!!
Old 10-27-2018, 04:15 PM   #8
lks dcvn
lks dcvn's Avatar
yeah -
Old 11-08-2018, 06:36 PM   #9
DeepOceanStepside
DeepOceanStepside's Avatar
sweet project!
1970 Base Step Side Dark Olive 250 3ott restoration
1972 k5 4x4 250 3ott project
1970 long bed light olive 283 th350 driver SOLD
DeepOceanStepside is offline   Reply With Quote
Old 11-08-2018, 10:33 PM   #10
flashed
Im in to see this one . One day I will own a Blazer ,know where an original untouched one is . I have a lot of Chevelle friends up in Ohio ,hope to go visit next august .
flashed is offline   Reply With Quote
Old 12-25-2018, 01:15 PM   #11
twp1
Got a lot of the new metal to get started!!!
Old 12-25-2018, 05:10 PM   #12
lks dcvn
lks dcvn's Avatar
Nice - that should save you quite a bit of time on body work for the rear half!
Which supplier did you go with?
Old 12-28-2018, 09:04 PM   #13
twp1
I tired southern Kentucky classics this time!
Old 12-28-2018, 09:07 PM   #14
twp1
Name:  blazer 12-28-18.jpg
Old 12-28-2018, 09:17 PM   #15
raggedjim
raggedjim's Avatar
Well, I'd say you got it apart! Are you going back 2wd or 4wd?
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-29-2018, 05:35 PM   #16
twp1
going back 4x4!
Old 12-30-2018, 03:17 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Back to 4wd? Nice!
Old 01-16-2019, 08:32 AM   #18
twp1
Getting started with body and suspension! Hopefully this turns out first time to do this much!
Old 01-16-2019, 04:51 PM   #19
lks dcvn
lks dcvn's Avatar
Just keep everything loose to confirm alignment before final welding and you should be good. Keep the pictures coming so we can follow along!
Old 01-17-2019, 11:41 PM   #20
Sand Wrench
Sand Wrench's Avatar
Rock on! Following with great interest.
You ever have one of those mornings where you wake up owning more trucks than you did the night before?
1972 K5
1972 K10
1967 K20 bucket truck
Sand Wrench is offline   Reply With Quote
Old 01-24-2019, 08:42 AM   #21
twp1
Starting to put body panels together and so far just have one quarter and inner fender on and had to do a little trimming on rear floor pan to get quarter to attach! Also received my new springs did a 2" lift. Hopefully can get front and rear end back today so I can get it on the skates to move away from wall to start on other side!
Old 01-24-2019, 10:49 AM   #22
jaros44sr
jaros44sr's Avatar
Nice way to start a build, new metal. curios to see how it bolts up?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-25-2019, 08:34 AM   #23
twp1
I got the axles back today and everything inside had to be replaced(Everything) so I started to put back under blazer to get it back on wheels and start the build.
Old 02-06-2019, 09:59 AM   #24
twp1
Started working on getting quarters on and ordered the lower piece that connects to the rear floor and the front floor pan and hopefully can start getting this together! Picked up a set of rally wheels that I may put on it!
Old 02-07-2019, 10:49 PM   #25
lks dcvn
lks dcvn's Avatar
the plate you are waiting on (the step up from the front floor to the bed) needs to go on before the bedsides get fully installed. So steps would be:
  • place bed floor on frame
  • attach step up plate to bed floor laying on frame
  • attach bedsides to other parts
Looks good so far!
