07-19-2018, 12:30 PM | #26 |
Re: Just did the Brothers LWB to SWB conversion...
Absolutely can use it again.
I gave mine to a buddy.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
07-19-2018, 07:39 PM | #27 |
If anyone has one sitting around I could buy. It would save me some money. I even thought about buying the frame stiffeners and mocking up my own template and makeing tons of measurements. I’ve seen both the straight cut and the z cut both with the same results.
07-19-2018, 09:47 PM | #28 |
...another THANKS for the write-up. I'll be jumping into this in the near future as well.
07-30-2018, 11:46 PM | #29 |
I’m curious as to the reliefs in the frame. Are they in place for any reason. Can I eliminate them if I wanted to shorten up my frame. It looks like I would cut out the 12” that has my vin# on it.
09-24-2018, 07:52 PM | #30 |
Great posts,great information looking to do this soon. Thanks guys!
70 custom10 swb fleet side 454 th400 |
09-24-2018, 08:29 PM | #31 |
Good write -up. Thanks for the information.
09-24-2018, 08:53 PM | #32 | |
In California framing they like nails because they bend and distort in earthquakes, where's a screw will hold rigid till it snaps. That said, Brothers probably did it to save money! I think I would get that kit if I was willing to hack a frame. Grade 5/8 ? I wouldn't be comfortable till it was welded anyway. I'm like you... I like overkill! OP nice write up, have fun!!! j
White K20 |
01-02-2019, 03:14 PM | #33 |
Great write-up. Just used their kit on my '70. Pretty straight forward except the new brake-line included with the kit. Anyone have a pic of where they disconnected/connected the new line? My existing brake line I disconnected under the cab, right by the fuel line. But the new brake line is WAY longer. Unless someone has changed the lines on this truck before, I cant see the location. Thanks
01-02-2019, 11:28 PM | #34 |
Great write up.
Maybe if enough of you all do this it’ll make my LWB more desirable than a SWB! ;-) |
01-03-2019, 12:58 AM | #35 |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
