Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-23-2018, 06:14 PM   #26
Zach119
Re: Zachís 72 blazer build
My dad picked up a bottle for the welder today and we got some work done. I patched bothe the right and left step up on the bed floor today in preparation for putting the bedsides back on. We also cleaned up the lip up the bed floor that will be covered and primed it.
Zach119 is offline   Reply With Quote
Old 11-24-2018, 12:25 AM   #27
Getter-Done
Getter-Done's Avatar
Great progress.
Looking Good.
Once the fenders go on. Then you can
really see the Real progress of a Good Job
Well done.
Best part is your Dad is helping you.
84 Chevy K-20
paypal.me/Dwayne67CrewCab
Old 11-29-2018, 09:59 PM   #28
cst 72 blazer
cst 72 blazer's Avatar
Following
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 11-29-2018, 10:21 PM   #29
Zach119
Iíve gotten a lot more done on the blazer. I have about 6 weeks to get most of the body work finished on the tub and set it on the other frame so I can send it to get painted. Bedsides are all mounted up and seem to fit great. I have gotten bolts in every hole so far without needing a die grinder. Tonight I got the wheel wells bolted in as well. Next on the list is mount the tailgate and put the top back on so I can mount the doors before I start work on the cab floor.
Old 12-06-2018, 10:35 PM   #30
Zach119
Did a little work on the dash tonight, a previous owner hacked up the radio so I cut it out and put in a double din plate. Still needs a little smoothing but itís all welded in and should look decent when Iím done.
Old 12-07-2018, 09:58 AM   #31
lks dcvn
lks dcvn's Avatar
fixed pix. Looks good - how did the bedside install go? Everything line up as it should have?
lks dcvn is offline   Reply With Quote
Old 12-11-2018, 02:06 PM   #32
Zach119
Thanks they fit really well for an aftermarket part with so many bolt holes to get lined up. Every bolt was able to be installed without having to enlarge any holes. I was worried how everything would line up once I started putting more parts but I got the tailgate on with a pretty acceptable gap and the top set on today. Next it’s time to cut down a set of doors and get them mounted up so I can start work on the floor pans and rockers.
Old 12-11-2018, 02:07 PM   #33
Zach119
Old 12-22-2018, 12:06 AM   #34
Zach119
Started working on the floor and inner rockers on the drivers side. So far I have the a pillar repaired, inner rocker tacked and bolted in , and the cab support replaced.
Old 12-22-2018, 08:35 AM   #35
lks dcvn
lks dcvn's Avatar
Looks great! Did you put the bedsides on first and then the wheel wells? Any challenges with those holes lining up? Might have to pull the trigger on a bed floor and bedsides in 2019 if it is that plug and play.
Old 01-14-2019, 07:00 PM   #36
Zach119
Nope everything lined up great I highly recommend them. The tailgate gap looks very nice and the top fit with the sides well too.
Old 01-14-2019, 07:08 PM   #37
Zach119
Iíve gotten a lot done lately since my last update. Almost all of the wedding has been finished inside the tub and I replaced the cab supports while everything was cut out. I swapped the front axle under the frame so I could test fit some tires before I get it ready for paint. I also decided to go a new route and picked up an aluminum 5.3 to swap in.
Old 01-15-2019, 12:17 AM   #38
Big Al 1972
Nice
Big Al 1972 is offline   Reply With Quote
Old 01-15-2019, 09:58 AM   #39
72gmguy
72gmguy's Avatar
Looks great! But I must admit I'm a little sad the turbines are leaving.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 01-15-2019, 02:58 PM   #40
Zach119
You canít tell in the pictures but two are one backspacing and two are another, I had no idea until I got the tires mounted on them and something didnít look right.
Old 01-18-2019, 11:39 AM   #41
Dads79GMC
Dads79GMC's Avatar
I love watching these blazers being totally reconstructed. Great work! Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 02-10-2019, 10:22 PM   #42
Zach119
The last couple weeks we’ve been prepping the frame and finally got it sprayed in a little warm spell. Sprayed por15 first then too coated gloss black. Everything was taken off the frame and I went ahead and rebuilt the rear drums.
Old 09-14-2019, 01:06 AM   #43
Zach119
Got the rocker boxes in and all underneath the tub undercoated and the tub back on the frame.
Old 09-14-2019, 01:10 AM   #44
Zach119
Now Iím working on body lines and gaps. Hopefully about a month and sheíll be ready for some paint.
Old 09-14-2019, 01:50 PM   #45
Getter-Done
Nice progress.
Will you make steps to get up in there?
84 Chevy K-20
Copyright ©2000 - 2019, vBulletin Solutions Inc.
