Old 01-18-2019, 12:38 PM   #2601
e015475
e015475's Avatar
Re: What did you do with your truck today, Part 3
"vintage air has a great rep for customer service"
That hasn't been my experience.
Bought a new condenser for my '49 GMC. Doesn't fit. Fits a Chevy, but not a GMC.
Called them several times this week. All I got was "We're busy and we'll call you back"
The parts house I bought it from called them for me. After 4 or 5 days, VA responded and said the kit for the GMC and the Chevy are the same. They offered to send me a set of universal condenser brackets and suggested I could modify them to fit my GMC.
Don't answer the phone? 4-5 days to respond? $325 for a truck-specific condenser and dryer and I have to fab the brackets?
e015475 is offline   Reply With Quote
Old 01-18-2019, 02:58 PM   #2602
mikebte
Lucky enough Speedway Motors dose offer great service and they are doing all the leg work to make it right. VA has a good reputation, but if they are gonna send out junk, that reflects bad on them.
mikebte is offline   Reply With Quote
Old 01-18-2019, 04:00 PM   #2603
dsraven
yep, send it back. call and talk to the guy, if possible, and you could email some pics. then see what they will do for you. should look like new if it is new. if not it is prolly a return from somebody els's project.
Old 01-18-2019, 09:17 PM   #2604
idbeast
I decided to work on dropping the driveline loop in my center crossmember to make room for my Gear Vendors Overdrive 2 1/2 inches. definitely not a 5 min job! Now to powder coat the center section and grind the welds then prime and repaint the frame.
idbeast is offline   Reply With Quote
Old 01-18-2019, 09:47 PM   #2605
idbeast
The powder coating is done!
Old 01-18-2019, 11:16 PM   #2606
MiraclePieCo
MiraclePieCo's Avatar
Very nice work!
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-19-2019, 01:44 AM   #2607
joedoh
joedoh's Avatar
that sucks! my last experience with VA was through summit, they changed the model number of a mini system I bought once before but the description and pictures were the same. when I got it there was no defrost outlets. I told summit the pictures and description were wrong, they basically said "huh, youre right. we drop ship from VA" and closed my case. they still havent changed the pictures or description.
Old 01-19-2019, 01:58 AM   #2608
idbeast
Originally Posted by MiraclePieCo View Post
Very nice work!
Thanks MiraclePieCo !
Old 01-19-2019, 03:24 AM   #2609
MiraclePieCo
I noted some marginal exhaust manifold threads in my rebuilt head so I installed a helicoil. Otherwise, since it was raining and my garage is too crowded to work inside, I was stuck doing nothing. Tomorrow's forecast is for more rain so I'll probably just work on my carburetor which, despite being brand new, is leaking.
Old 01-19-2019, 10:24 PM   #2610
DransportGarage
DransportGarage's Avatar
X2. I had a corrosion problem with a $30 pipe/fitting after buying and entire system for the truck. The guy started out nice enough, but when I requested a replacement the line went dead. He refused to communicate. I'll go to Southern Rods the next time.
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-19-2019, 10:26 PM   #2611
DransportGarage
Very nice work!
Nice pix too. Love the flying sparks!
Bob
Old 01-20-2019, 01:07 PM   #2612
dsraven
beasty, nice job on the loop drop. you will be happier with it now.
on to the next job
Old 01-20-2019, 01:10 PM   #2613
idbeast
Thanks DransportGarage and dsraven , I got everything painted, turned the frame around, put the motor transmission overdrive unit in place then started putting the removable cross member piece back in!
Old 01-20-2019, 01:12 PM   #2614
MARTINSR
MARTINSR's Avatar
Right on!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 01-20-2019, 01:15 PM   #2615
idbeast
on to the next job
True, now back to blocking out my hood, I hate block sanding!!!
Old 01-20-2019, 01:46 PM   #2616
DransportGarage
You'll be ready for the Power Tour and Drag Week soon!
Bob
Old 01-20-2019, 09:28 PM   #2617
MiraclePieCo
Moved all the fittings from my old (cracked) intake over to my new intake: temp sender, heater outlet plug, brake vacuum plug, thermostat, carb studs, etc. That's the most I can do on my workbench; still waiting for the rain to subside so I can actually install the head on the engine.
Old 01-20-2019, 09:39 PM   #2618
idbeast
Darn Rain.... when I get my truck painted and running we need to get together just for ****s and giggles!
really soon I hope!!!
Originally Posted by MARTINSR View Post
Right on!
Brian
Thanks Brian!
Old 01-20-2019, 09:40 PM   #2619
DransportGarage
You're getting close! Congrats for not chucking it all. There's time for that later!
Bob
Old 01-22-2019, 03:10 AM   #2620
MiraclePieCo
Thanks so much for your support gentlemen! The encouragement I've gotten on this forum has been invaluable.
It's a deal. Let's meet in the middle somewhere - say the Pacific Northwest Truck Museum at Brooks?
I got the head installed and torqued down today. Tomorrow will be intake installation.
Old 01-22-2019, 08:24 AM   #2621
evilokc
started up the truck yesterday just to let it run a little since its been so cold. it fired as it should without hesitation and quickly went in to its higher fast idle to war up. it sounded so good I HAD to drive it a little. so a quick relaxed drive around the neighborhood. im really pleased that the carb is tuned well enough that even cold it drives well without hesitation or stumbling. every now and then im proud of my truck.
evilokc is offline   Reply With Quote
Old 01-22-2019, 12:07 PM   #2622
DransportGarage
Originally Posted by evilokc View Post
<snip> every now and then im proud of my truck.
...as we all should be. We, as builders, have done things mere mortals don't even dream of. I am sure our trucks are proud of us as well.
Bob
Old 01-22-2019, 03:05 PM   #2623
MiraclePieCo
Eloquent!
Sometimes I look at my truck and imagine how it must feel to have sat in stasis for 20-some years and now be alive again because of my efforts. A reinCARnation, you might say!
Old 01-22-2019, 10:09 PM   #2624
idbeast
Sounds good!
Old 01-23-2019, 02:51 AM   #2625
MARTINSR
MARTINSR's Avatar
I am working on my brothers 39 Ford dash, so nothing to speak of on the truck. I did go dig out the steering box so I could see if the passenger car pitman arm fits on the box? It's about three inches shorter and would seem to work perfect on a 3" dropped axle! Could this be the holy grail of this mod on these trucks?
Brian
1948 Chevy pickup
