#126 |
Re: 79 K20 Custom Deluxe - Goldy LS1
It's been a while, but it's time to get back on this build. I'm going to need to start towing my K10 to the trails soon, so I had my buddy come over and help me get it to the garage!
#127 |
Thanks for the updates and keep them coming.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#128 |
It's been a while but I'm back on project Goldy. The current plan is to make it a hauler / driver. Here are a few videos to get you caught up.
Project intro video. Front crossmember. Sway bar mounts and brake lines. And a bonus video, of working on my buddies bagged out square. Last edited by whitels1; 01-10-2018 at 12:55 PM. |
#129 |
Yes! Good to see the updates.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#130 |
Sure is.
![]() ![]() It was cool seeing the k10 going up onto the hauler in the video. I have been patiently waiting for an update on that one.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 Last edited by daddyjeep; 01-11-2018 at 01:39 PM. |
#131 | |
Thanks man! I gotta get caught up on yours too!
#132 |
It's time to get back on Goldy, this time I'm determined to get it finished! It's been a while, and I've been doing Jeep stuff, so hopefully you guys will still like me, ha ha!
#133 |
Welcome back Dave! I missed your videos of the squares.
#134 |
Thanks buddy, it's time to get busy! Hope all is well on your side.
#135 |
Jeep stuff??? I guess I can let that slide. Glad you're back. I was worried about you. You stopped posting right around the time that Jack Wagon shot up that country music show.
Wait....... You are parting out the K10?????
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 Last edited by daddyjeep; 12-12-2018 at 01:23 PM. |
#136 |
Jeep stuff is OK if you get bent! Don’t part out the K10 just yet... you might get tired of that little V6.
And welcome back.
#137 |
You were that guy, the one who would wheel a full size right along with all those Jeep guys. Now you are just one of the Jeep guys. Being a Jeep guy myself I can certainly understand that. I am going to miss wheeling videos with that K10 though.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#138 | ||
How about an update on Goldy, disc brake swap time!
I was that guy, and it wasn't bad, but needs lot's of improvements! I'm in parts gathering mode for the K10. Once the K20 is done, it's on! |
#139 |
#140 |
I've been getting after it lately, did a live Q&A Friday, it answered a few questions about the disc brake swap, ls stuff, and general truck stuff.
Felt like I needed some motivation, so I got the front axle swapped, bolted up the H2's, and 37's. Got me motivated to box the front spring hangers, and sway bar cross member. |
#141 |
#142 |
Engine bay mock up in full effect! I'm diggin the 2005 Intake air box, looks like it was meant to be. Currently LS1 Fbody manifolds, Ford Expedition Fan, stock K20 shroud / radiator, drive by cable 2002 Tahoe throttle cable.
#143 |
More work on this sucker! Had to fab up some mounts for the battery tray and the air box mount plate, that came off the 2005 Silverado. It's always amazing how many little projects are within the larger project.
#144 |
looking good. still my favorite square chevy channel
#145 |
Thanks brother, I appreciate it!
#146 |
The speed holes in the battery bracket may have been a little overkill since you will never see them, but as long as it makes you happy.
#147 | |
#148 |
It's time to do the fuel system, and as always a video of how I do it. I decided to do it different on this build, as far as the sender and tank. 87 Baffled K5 Blazer tank, 87 EFI sender with an EP381 fuel pump. Russell -6 AN fuel lines and fittings. Links to all parts used in the video description.
#149 |
Looking good! Awesome videos!
![]() You mentioned possibly capping off the vent line that goes to the charcoal canister. For what it’s worth, I did that and had an issue with the truck dying occasionally. It would start right back up. I think it was some kind of vapor lock issue. After I hooked up the vent line it stopped happening. I’m running the stock TBI. Just a word of warning on that. I’m still not 100% sure if that’s what the problem was. |
#150 |
Why would you willingly put the fuel filler on the wrong side? A couple of my vehicles have it over there and it is a pain. The majority of vehicles on the road have them on the drivers' side. The auto makers really should get together and standardize that.
