Old 02-10-2019, 09:10 PM   #1
Pvmt-Pndr
Clutch and flywheel
I just bought a 69 C60 with a tall deck 427 and a 5 speed, the shift pattern says it's an Eaton and definatly not an OD. It has a bad flywheel. I've asked in the heavy hauler section with no luck and have been beating my brains out on what flywheel I need. A link would be great or a place I can call to find out for sure. I figured a clutch since it'll be apart anyways. Any help would be appreciated.
Pvmt-Pndr is offline   Reply With Quote
Old 02-10-2019, 10:04 PM   #2
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: Clutch and flywheel
#3986185
Dont think you'll have any luck finding one though.
Edit: this might work
https://fortwayneclutch.com/product/...sku-mu1266_kt/
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 02-10-2019, 10:11 PM   #3
Pvmt-Pndr
Thank you a ton! At least I know what I'm looking for now. I've been beating my fingers on the keyboard for 3 days.
At least I learned a lot about everything I don't need
Old 02-11-2019, 12:43 AM   #4
Captainfab
60-66 Nut
What is wrong with the current flywheel? If it is the starter ring gear, those can be replaced separately. No need for a new flywheel.
Old 02-11-2019, 08:14 AM   #5
Pvmt-Pndr
That's exactly what the problem is.
Old 02-11-2019, 04:16 PM   #6
b454rat
Dont' have to get a new one. You can buy just the ring gear. Cut the old one off, stick the new one on the grill or in the oven, get it nice and hot, will almost fall into place....
Old 02-11-2019, 04:43 PM   #7
Pvmt-Pndr
Thanks! I just watched a video of a guy doing this and it looks very simple.
Old 02-11-2019, 07:16 PM   #8
geezer#99
geezer#99's Avatar
You need to take it to a machine shop to get the flywheel re-surfaced, so get them to install a new ring gear too.
Old 02-11-2019, 07:18 PM   #9
Pvmt-Pndr
It looks simple enough to do but like you said while it's there they can do it. Any idea what a rough cost is to have it resurfaced?
Old 02-11-2019, 07:25 PM   #10
kipps
I've been quoted in the $40 to $50 range to resurface a ford I6 flywheel. Your's should be similar unless it's a lot larger diameter.
kipps is offline   Reply With Quote
Old 02-11-2019, 07:27 PM   #11
Pvmt-Pndr
I've never had one resurfaced before. I was planning on doing it either way just didn't want to get hit with a ridiculous number walking into it blind. Thanks for the info
Old 02-11-2019, 08:52 PM   #12
mongocanfly
mongocanfly's Avatar
havnt had one resurfaced in several yrs...but it was $30 last time...so $50 now wouldn't be bad
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-11-2019, 09:02 PM   #13
Pvmt-Pndr
Either way it's a small price to pay for piece of mind to me
Old 02-11-2019, 11:55 PM   #14
Captainfab
60-66 Nut
Machine shop prices can vary a lot depending on your location.
Old 02-16-2019, 07:54 PM   #15
YoungPup1977
Two step flywheels cost more to resurface but if it’s flat as a Chevy one is we charge 35 bucks. Any time a clutch is replaced always resurface the flywheel. It’s like doing brakes without turning the rotors and/or drums.
YoungPup1977 is offline   Reply With Quote
