03-05-2019, 02:43 PM | #26 |
Re: 1965 C20 Dump truck
Well we had some really good weather over the weekend witch prompted me to get some work done on the truck. (finally)
I got the coolant drained and now just need to get some new coolant and fresh oil. More updates coming soon!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
03-20-2019, 03:53 PM | #27 |
Over the past few days I have got a lot done on the truck. I don't have time right now to go in detail but will update you all really soon!
03-20-2019, 04:32 PM | #28 |
Anxiously waiting!!!!
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
03-21-2019, 01:27 PM | #29 |
Well for starters, I got the valve/rocker cover back on. I did use the suggested thread sealant on the bolt that had the coolant leaking past the threads. I'm pretty sure it should work but time will tell.
All so I'm going to run some stop leak in the coolant system just for added safety.
03-21-2019, 02:13 PM | #30 |
The next thing I did was rebuild the carburetor.
All so the fuel filter in the carb. was gummed up real bad witch explains why It didn't start real well or have as much power as I was thinking it should. THE TRUCK RUNS MUCH MUCH BETTER NOW! I still have to fine tune the carb. a little bit and I need to re gap the points but overall the truck runs way better than it did for sure.
03-21-2019, 02:22 PM | #31 |
Then It was time for an oil change!
It was fun having both my chevys parked beside each other. LOL
03-21-2019, 02:42 PM | #32 |
So since the oil change I have driven the truck around the property a little bit and it does have a lot more power after cleaning/rebuilding the carburetor.
I just need to finish the truck bed and then I can haul some firewood! So still a lot of work to be done on the truck but at least I am finally getting some where on it!
03-21-2019, 05:51 PM | #33 |
292 in my 66 woke up alot after rebuilding the little 1 barrel....woke up even more when I did the 4 barrel and dual exhaust though. lol I need to get the new motor fired up soon or I'm gonna go nuts.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-22-2019, 12:25 AM | #34 | |
Still waiting for that video on your new truck to. LOL
05-03-2019, 03:10 PM | #35 |
Not much progress on the truck lately mostly just been trying to work bugs out of the engine. Had a small leak on the carburetor that I had to fix with gasket sealant (Yes I know it's not the best idea but it'll have to do for now)
Spent most of yesterday gaping the points, setting timing and fine tuning the carburetor and was able to drive it around for a while. I'm hoping my coolant leak is fixed but I'm not for sure yet. Yesterday I looked at the oil cap and I saw a drop of water on it but I'm hoping it was just condensation or something.... I did run some stop leak in the engine yesterday so hopefully if there is a problem that will fix it... Hopefully.... All so on the problems list I don't think my vacuum advance is working. I thought that it was but looking at it again I don't think it is. I'm pretty sure that I have it hooked up to the right vacuum port on the carb. so it must be something wrong on the distributor. So I'm going to have to figure that out sometime. The real thing holding me back from getting what I really want done on the truck right now is money so it's just kinda a slow project for now. All so guys I'm thinking of digging into my 76 c10 to see what doom awaits in that truck.... so be on the lookout for a build thread for that truck sometime soon!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! Last edited by straight6chevyguy; 05-07-2019 at 03:43 PM. |
05-03-2019, 04:23 PM | #36 | |
Its funny when we use to have a leak we would put a tablespoon of grits in the radiator and soon....no more leak. Not real sure what that does to the motor but the leak was gone...lol Itll come along, trust me I definitely know the feeling.
05-07-2019, 03:42 PM | #37 |
Thanks for the encouraging words John.
05-15-2019, 09:29 AM | #38 |
Most of us don't have unlimited money to put into our projects...so we save and pinch pennies to get the parts we need. In my case, this is going to be my daily driver, so I can sell one of my cars when I finish...so spend money now on the truck then recoup it when I sell the car...it's a weird dynamic. Otherwise, it would be taking me more years than it already has and I am not doing a show truck, but doing it with show truck speed of build.
You're doing great! |
05-15-2019, 01:46 PM | #39 |
Thanks Andy...
Just a small update: I believe the vacuum advance is working after all. I drove the truck with and without it hooked up and the truck seems to have more power with it hooked up so it must be working, right? Not really sure what I was thinking maybe I was just looking for more movement from the arm on the dist. then is supposed to be there.
05-27-2019, 05:26 PM | #40 |
I'm planing on getting the wood to finish the truck bed soon so be waiting for updates!
05-31-2019, 02:09 PM | #41 |
Well here is some of the lumber... (there is some more that is not in the picture by the way)
Just the cheapest stuff I could get, the trucks going to be a work truck not a show truck. LOL Now time to get to working on it! I will be sure to take lots of pictures!
06-05-2019, 04:14 PM | #42 |
Well, been working on it these past few days so here are the updates!
Cutting the plywood to size...
06-05-2019, 04:17 PM | #43 |
Doing a test fit...
06-05-2019, 04:22 PM | #44 |
Some painting...
06-05-2019, 04:32 PM | #45 |
Getting it secured.
06-05-2019, 04:39 PM | #46 |
I have started working on the tail gaits but am not done yet.
I'll have more pictures and updates coming soon...
06-10-2019, 12:16 PM | #47 |
Almost have the tail gates done, just have to buy some more hardware today.
06-12-2019, 02:06 PM | #48 |
It's been real warm lately so not as much progress as I would like but I'm still moving along.
Trying to remember to take pictures as I go along too. I will try to have them up in a day or so.
06-27-2019, 03:27 PM | #49 |
Been real busy with other things lately but I do have the tail gates done just have to install some sort of latches (to keep them closed LOL)
I will try to get those over due pictures on here soon.
07-12-2019, 03:57 PM | #50 |
I know It's been a while but....finally updates.
