04-28-2019, 12:59 PM | #1 |
pinion angle help please
Ok, so i have a 1969 C10 that is lowered 4" in rear with springs and 2" blocks, the front is dropped 2.5 with springs and drop spindles. At say around 40 to 45 miles an hour there is a vibration, harmonics. The drive line is new single piece that replaced a 2 piece that did produced the same vibrations, so this tells me it is Pinion angle. Here are the angles:
4L60E tranny is from front of truck to rear = 7 degrees down Drive line is at 1 degree down (from front of tranny looking to rearend) Rearend is 5 degree up (from rear of truck looking towards the front) all measurements are done with truck on 4 separate blocks, so suspension is fully loaded. I have trailing arms not leaf springs Where i get lost here is what to do. Should i install wedges to rotate the rearend to decrease the "positive" pinion angle? If i am not mistaken, if i move the 5 degree pinion angle to "Down" to 3 degrees of up angle, then the Driveline angle would increase to -3 degrees. This would then take the rearend pinion angle to a net "0" pinion angle, is this correct? If that is correct, that would then make the transmission angle increase correct? damn i am confused here and i know it is something simple i am just missing. Thanks for any and all help here. |
04-28-2019, 01:12 PM | #2 |
Re: pinion angle help please
A perfect rear angle will be parallel to the trans angle. So theoretically you'll have to move the pinion down 12 degrees. A 2 piece driveshaft helps with these angles as you can fudge them a little more. I would start with a 6 or 8 degree shim on the rear diff. Or if you can push the trans up? (not usually)
04-28-2019, 03:34 PM | #3 |
That is correct.
However your numbers aren’t! Tranny is down 7 degrees so pinion should be up 7 degrees. You need to shim the pinion up 2 more degrees. Don’t worry about the driveshaft angle. It isn’t a factor in your case. |
04-28-2019, 04:14 PM | #4 |
In my opinion you should try to move the tail of the transmission up a bit if you have room. It will extend the life of your U-joints. Less angle less wear. That being said you need a minimum of 1.5 degrees of angle on each end of the shaft for things to work correctly. As it was stated earlier try to match the angles as close as possible.
If you are interested I have some information posted on my WBM thread (page 14) below of what I did to mine. Good luck
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-28-2019, 04:39 PM | #5 |
All about them K’s
TREMEC has a smart phone app that helped me set the angles on my K20
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-28-2019, 11:48 PM | #6 |
https://www.speedwaymotors.com/Rear-...sku=91016072-2
I would buy 2 degree and 4 degree ones. Install. Drive. |
04-29-2019, 01:57 AM | #7 |
Fender or alignment shims under trans mount
04-29-2019, 09:21 AM | #8 |
I appreciate all your comments!! Thanks guys. The micro vibrations at about 40 to 45 are just killing me. My tuner is taking the truck to set up the LS tune next weekend so I'm trying to fix this now.
I am first going to try everything I have to raise the tranny up. Not sure what I have available, hopeful for 1/2" min, 1 " if possible maybe? Get the angles down, then I bought the 2*, 4* and 6* shims for the pinion. I'll post how it's going. |
04-29-2019, 01:08 PM | #9 |
04-30-2019, 12:17 AM | #10 |
So, tonight I was able to make some tranny shims, moving the tranny down angle to 5 degrees, the driveline is now at 2 degrees down and the pinion is at 5 degrees up. What does everyone think of that?
04-30-2019, 12:21 AM | #11 | |
04-30-2019, 12:45 AM | #12 | |
The drive test will tell us for sure. Please report back after you run it through it’s paces.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-30-2019, 01:04 PM | #13 |
Cornerstone i update after I drive it. I hope it is gone a d the issue is fixed. If not, then I have axle shims in the mail to adjust the pinion angle slightly, 1 to 2 degrees.
07-07-2019, 08:08 PM | #14 |
Been a few since i last updated this. So I looked at raising the tranny, but it is hitting the trans tunnel. So i went over to a buddies place who has 40+ 1960's through 1970's C10s and picked up a High Hump trans cover. I then traced out the outline and cut out the existing cover. This allowed me to raise the tranny up so i can have just under .5 down angle. This is an increase of 2" over the existing mount! I then installed .5 angle spacers in the rearend and got the rearend to .5 down which if i am not mistaken is not what i want. I want about a .5 degree up angle on the rear so that is in the same plane as the tranny. I will remove the .5 and install the 3/16" spacer. With this all said, the driveline is about .5" away from the top of the driveline hole in the crossmember that holds the trailing arms. This makes me nervous. I also have 2" lowering blocks and think that maybe that is to much and that i should try 1" blocks with the 3/16" angle spacers.
So overall i currently have .5 degree down angle (down to the tranny) on the rearend / pinnon, 5 degree angle on the driveshaft (from the tranny it is 5 degrees down to the pinnion) and the tranny is at .5 degree down (towards the pinnon). So with a few alterations (remove the 2" lower blocks on the rearend and installing 1" instead) & (replace the .5 angle spacers with 3/16") this should then get me to a .5 degree up angle to the tranny and then maybe reduce the height of the tranny spacer from 2" to 1.75". This will increase the amount of Down angle i will have at the tranny by maybe .5 degree, ending with a tranny down angle of 1 degree to the rearand. This should all get the driveline angle from currently 5 degrees to 4 or less degrees. Comments? Thanks, |
07-07-2019, 09:53 PM | #15 | |
One caveat is that no u-joint should run completely straight. If a u-joint runs with no angle at all, it will wear or pound little slots in the bearing surface on the cross, and then THAT will vibrate. The angles on the u-joints really shouldn't be over 3 degrees either. |
07-10-2019, 12:05 AM | #16 |
Thank you for the response Bloo. Also good to see a local on here
07-10-2019, 11:34 PM | #17 |
Anytime. I am in Wenatchee most of the time now and Seattle the rest. I was just revisiting this pinion angle problem the other day on a truck I did an axle swap in a long time ago....
Good luck 88Stanger, I hope you get it sorted out. |
07-10-2019, 11:36 PM | #18 |
So, I got the tranny to 4.25 degrees down, the rearend is up 4.0 degrees, the driveline is 6 degrees down. That makes the rear and tranny almost equal, and the driveline to either at 2 degrees or less. I am hoping this fixes the issue.
07-10-2019, 11:40 PM | #19 |
Sounds good to me!
07-11-2019, 02:08 PM | #20 |
Good work. How does it drive? I know the ride (NVH) in my Burban got much smoother once I got the angles right.
07-11-2019, 03:14 PM | #21 |
I honestly have yet to get it out. I had to cut the tunnel alot and will be installing the high hump this weekend, then get the cold air induction completed, then its driver. I'll post how it is after I get it out. Thank you for all the help guys!!
07-12-2019, 03:02 AM | #22 |
Waiting to see also.
07-12-2019, 06:38 AM | #23 | |
The difference in the working angles should be close to 0 to cancel each other out.
07-12-2019, 09:19 AM | #24 |
Thanks for the correction.
07-13-2019, 02:51 PM | #25 |
thanks for all the great input. Now my only issue is what to do with the center console that no longer fits!!! DAMNIT. And the carpet does not Fit!! Damnit!! Oh well, .....
