Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 05-14-2019, 12:29 AM   #26
Foot Stomper
Foot Stomper's Avatar
Re: Block sanding. How am I doing?
Originally Posted by Johns 66 View Post
Ok....Do I need to sand with 80g before I epoxy. It is currently down to 220g
No, clean and abraided is suffice.
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 05-14-2019, 12:34 AM   #27
Johns 66
Johns 66's Avatar
Thanks so much for your help....as you can tell...never done this before. I think Im sanding too much because I seem to keep going down to metal in places...may be my technique. So will epoxy then 2k again and start with 220 then 320.
This my seem ignorant but Im not repriming in between grits......is this where I may be messing up?
Former Decorated Combat Marine...Semper Fi!!
Instagram jorourke322
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699
2019 GMC AT4
Johns 66 is offline   Reply With Quote
Old 05-14-2019, 12:38 AM   #28
Foot Stomper
No need to reprise between grit. The goal is a 320 final sand which is good for paint.
Old 05-14-2019, 12:41 AM   #29
Johns 66
Johns 66's Avatar
Thanks so much.....will do this tomorrow and see how it goes....Ill post tomorrow eve when I get done.
2019 GMC AT4
Old 05-14-2019, 05:25 PM   #30
Johns 66
Johns 66's Avatar
Well reprimed with epoxy then 2 good coats of 2k high build and started sanding away...first with 220 then 320.. I did sand down to the epoxy is a couple of places but not metal....I stayed away from the edges as best I could and used really light pressure.
I also found a couple of pin holes while sanding and spread some glazing putty then continued to sand.
Before I primed everything I ran water over the pieces and washed them to get all the sanding dust off. I did not notice any glaring areas that looked funny ...kinda simulating the gloss.
So now that Im down to 320....do I need to put more 2k on the areas that went to the epoxy?
Im planning on sanding with 400 then 600 before color. My truck was originally 521 white and I will be going back with the original color.
I really do appreciate all the help.
2019 GMC AT4
Old 05-14-2019, 09:21 PM   #31
Foot Stomper
Glazing putty? What exactly do you mean by "glazing putty"??
Is it red, drys by letting the air to it OR is it something like Metal Glaze from Evercoat??
This is important because if you used the red air dry stuff, you're going to have to sand it out of there.
Old 05-14-2019, 09:40 PM   #32
Johns 66
Johns 66's Avatar
The actual name is Icing....Comes in a tube and you add hardener to it...mix it up just like bondo. This is what the paint store sold me to fix minor imperfections like pin holes.
Is this stuff good? I know it costs like its really good..lol
2019 GMC AT4
Old 05-14-2019, 09:42 PM   #33
Johns 66
Johns 66's Avatar
Originally Posted by nsb29 View Post
Iíd skip the 400 you only have so much primer the 600 will take out 320 scratches you donít need to re-prime you can paint over the epoxy
Yeah...I know its kinda getting thin after sanding with 220 then 320...guess that's why I hit epoxy in a few places...Figured I would just give it another coat of 2k high build...Better to be safe than sorry.
2019 GMC AT4
Old 05-14-2019, 10:42 PM   #34
Foot Stomper
USC Icing is perfect!
Thanks for clarifying.
Years ago guys used Laquer Glazing Putty...some stores still sell that crap.
Old 05-15-2019, 10:45 PM   #35
Johns 66
Johns 66's Avatar
I saw on your build site you were going to prime w/high build and sand w/400.600 thatís to fine to start sanding high build I would go ahead w/600 then if you sand through to metal spot it in with a reduced epoxy feather it out w/600 and paint it
Can you explain the reduced epoxy?
2019 GMC AT4
Old 05-16-2019, 04:29 PM   #36
Johns 66
Johns 66's Avatar
Reduce it with urethane reducer so itís thiner you donít want a lot off build you just want to seal the metal that way it lays down better less sanding
Thanks for the info....A had someone tell me to use sealer before I put color on????/ What were they referring too?
2019 GMC AT4
Old 05-16-2019, 11:58 PM   #37
Johns 66
Johns 66's Avatar
Sealer is a non sanded primer that is applied before paint some times it is tinted to match the paint color I never use it sum people use it all the time if youíre using a lo end paint that doesnít have good coverage you want all your panels the same color or even tinted to match your finish paint I would buy a quality single stage pant give and it 4 coat as I believe itís the easiest for a novice to get a nice paint job it can be sanded and buffed to to remove any orange peel/dust or miner imperfections
Ok...I thought it was a waste of my time. While I have never painted a truck before I have sprayed lacquer and poly when I have built furniture....its a little different since wood absorbs the material.....mainly what will be single stage is the suspension, inner fenders, frame and under the hood...I practed on the inner fenders today...didn't turn out too badly.
2019 GMC AT4
Old 05-27-2019, 10:38 PM   #38
jgr
Don't ever wet sand slick sand/polyester primer; only dry sand . 2k can be wet sanded.
jgr is offline   Reply With Quote
Old 05-28-2019, 12:48 PM   #39
jgr
It is a great primer and I also have been using it forever without any problems and I have only dry sanded it The tech sheet says nothing about wet or dry sanding; I did call their tech line about 8 months ago and the guy I talked with said I would not recommend wet sanding. That is all I am going by.
Old 05-28-2019, 03:06 PM   #40
jgr
it's all good , I can't imagine sanding it with 600 either! I prefer wet any day over dry. I like to get everything all squared up with slick sand finish with 180 and then go to the 2K and wet sand and paint. I don't like to seal on the restoration jobs.
Old 05-28-2019, 11:33 PM   #41
Foot Stomper
Itís been 20 years since I took and looked at their tech sheet
Once again, you're the smartest guy in the room. I am in awe!
p.s.
Proper grammar makes your posts easier to read.
Old 05-29-2019, 03:00 PM   #42
AZ 67 C10
AZ 67 C10's Avatar
I just avoid reading posts without a single period. Grade school was hard..
1967 C10 SWB 6.0 LS swap in progress
2011 CCSB Duramax 4x4
AZ 67 C10 is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
