Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-22-2019, 08:37 AM   #3051
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
I got rid of my TPI setup and went with a Holley Sniper. I like it.
Might be an option for you?
Looks like someone was a little rough on that heater hose nipple...
litebulblsc is offline   Reply With Quote
Old 05-22-2019, 11:45 AM   #3052
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I was looking for the cool factor, but you're right , there maybe better systems out there!
Note the red arrow, cracked intake manifold. That's what happens when you use a tapered easy out, I was able to get a hacksaw blade in there to cut some of the threads and roll back the fitting with a punch. Hopefully I can have it tigged
Just one of my SNAFUs.
on to the shaft bushings for the quadra jet
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-23-2019, 08:29 PM   #3053
litebulblsc
Re: PO has me PO'd
I seen the crack before the arrow. Hopefully it is a simple weld and good to go.
Old 05-24-2019, 07:48 AM   #3054
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Installing throttle shaft bushings, grind the staked screws or you WILL snap the heads off. mark blades for location and direction
[url=https://flic.kr/p/2g1QCQu]20190523_093722
SAFETY FIRST
AS usual, off topic
Jim
Old 05-24-2019, 08:05 AM   #3055
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
referance pics
[url=https://flic.kr/p/2g1QBNq]20190523_085540
[url=https://flic.kr/p/2g1Rqrf]20190524_070829
Notice 4 snapped screw heads, you would've thought I would have stopped and checked after one
SAFETY FIRST
AS usual, off topic
Jim
Old 05-25-2019, 03:18 PM   #3056
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
very little wear on the shafts, can't feel it with your fingernail
[url=https://flic.kr/p/2g2kpzA]20190525_081428
baseplate was cooked in my ultra sonic bath, at low temp, with purple power, changed to aluminum to a slate grey
SAFETY FIRST
AS usual, off topic
Jim
Old 05-26-2019, 07:46 AM   #3057
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2g2UuTv]20190526_063805
Be careful!, what appears to be a slotted screw is not, just a spring holder in the slot. The silver screw does come off for disasembly. In my application both shafts had to come out for the bushing kit to be used
these shafts are very delicate, so don't force things when you disassemble
SAFETY FIRST
AS usual, off topic
Jim
Old 05-26-2019, 08:21 AM   #3058
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Still Waaaaay more patience than I have bud. I have none when it comes to carb rebuild or all that wiring you were doing for the other style. I am gritting my teeth not really wanting to do a harness upgrade on my panel even though I know it should be done.
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is online now   Reply With Quote
Old 05-28-2019, 09:21 AM   #3059
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
patience, is not my problem, 35 years raising a special needs son helps with that! My problem is that I'm a control freak, my other son was going to take it to his shop, finish up and then take it to his buddies shop for the wiring. But, I would not have control of the process along the way. I know my son would do quality work, but after that???
Plus he's trying to paint his house this summer and I don't want to tie up his time...
So, the ball is back in my court and I will continue to muddle along, carb is kinda fun, have an extra carb for reassembly help
Bought the re-bush kit from cliff rugles, plus his forum helps with info......
Thanks for all your help over the years of this build
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2019, 07:32 AM   #3060
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2gadD1T]20190606_162033
shifter is running, just some tuning left
[url=https://flic.kr/p/2gadJmz]20190606_161944
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2019, 08:37 AM   #3061
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2gadJqc]20190606_162049
I just want to get my kicks before the whole sh!t house goes up in flames
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2019, 09:40 AM   #3062
litebulblsc
Re: PO has me PO'd
Is that a 250cc on there?
Old 06-11-2019, 08:29 AM   #3063
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
no, just a 125cc, still pretty quick for a 67 year old, with your butt 1" from the ground
SAFETY FIRST
AS usual, off topic
Jim
Old 06-19-2019, 06:05 PM   #3064
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Date with the eleltrical shop, July 8 2019
I give up
SAFETY FIRST
AS usual, off topic
Jim
Old 06-19-2019, 07:32 PM   #3065
litebulblsc
Re: PO has me PO'd
The kart does look like a blast.
You are going to have them wire up the FAST fuel injection?
Old 06-21-2019, 07:08 AM   #3066
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
yeah, the XIM XFI 2.0 gotta start with at least 12V
[url=https://flic.kr/p/2ghDpBP]20190621_065354
second attempt, maintained with trickle charger for 5 years and battery still failed...trying Genius this time, maintenance charger
I wonder if I can replace bad cell on the old battery
we're still driving on a country road, so I'll have to wait until I can get it on a track to see how it really preforms
SAFETY FIRST
AS usual, off topic
Jim
Old 06-21-2019, 07:38 AM   #3067
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Is a dual battery hold down clamp differant then a single battery hold down clamp
[url=https://flic.kr/p/2ghEj2x]2019-06-21_07-34-16
SAFETY FIRST
AS usual, off topic
Jim
Old 06-25-2019, 09:28 PM   #3068
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
No way dude. Don't give up on it Jim. I've taken a ridiculous numbers of steps backwards on mine over 11 years. You've done so much. Don't farm it out now. Take a break, come back to it. Keep making progress.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-26-2019, 07:07 AM   #3069
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
AJ, thanks for posting up, but time is my constraint, I'm 67 going on 68 in August, and I'm afraid I won't get to drive it much as I get older. So, I've made the choice to get it worked on by someone who understands the system...
For me, it's like putting a string on a yo yo, when you don't know what a string or yo yo is or does, it just doesn't make sense to me, and trust me when I say I've tried, I've sourced, I've read, sourced, and read some more, gleamed thru countless wiring diagrams, to no avail. If someone had done this before, I would have been able to ask questions, but no one has
You've been a great source of info. over the years, and I consider you my friend, sorry to let you down, but it just has to be this way
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2019, 08:58 AM   #3070
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Not a let down, my friend. I mean, you're no spring chicken here.
I totally get the aspect of wanting to drive it. Get it done and get in the driver's seat. Keep us posted.
- AJ
Old 06-26-2019, 09:28 AM   #3071
richard2717
Re: PO has me PO'd
Come on Jim, I am sure you have a kid close by to help out with the yoyo.
As I told you before you have stuck at it way longer than I would have ever dreamed of doing. I can't say that I would have ever tried it so mad props to you for going as far as you have with it.
Members I have met.
Old 06-28-2019, 07:38 AM   #3072
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Richard, got the battery hold down yesterday, thank you. Can I at least pay for postage and paint?
BTW, have'nt seen any kids playing with yoyos lately for me to ask, if you do, get me an email addy
[url=https://flic.kr/p/2gmfJPn]20190628_075541
SAFETY FIRST
AS usual, off topic
Jim
Old 06-28-2019, 08:12 AM   #3073
richard2717
Re: PO has me PO'd
[QUOTE=jaros44sr;8549678]Richard, got the battery hold down yesterday, thank you. Can I at least pay for postage and paint?
BTW, have'nt seen any kids playing with yoyos lately for me to ask, if you do, get me an email addy QUOTE]
Jim
Glad it arrived. No need, consider it a small contribution to the build.
TBH I probably would need help with the yoyo nowadays lol
Richard
Members I have met.
Old 06-28-2019, 08:28 AM   #3074
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
AJ, your truck looks awesome on the show floor, that was a great deal on the headlights. glad everything worked out on your drive
posted by not a spring chicken, what ever that is
SAFETY FIRST
AS usual, off topic
Jim
Old 06-28-2019, 08:34 AM   #3075
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[quote=richard2717;8549687]
Jim
Richard
dabbed a little anti sieze on the threads and install, thanks again. we should start a thread, Who has thier OEM duncan yoyo. or do a you tube video on installing string on a yoyo
SAFETY FIRST
AS usual, off topic
Jim
