Old 06-06-2019, 12:17 PM   #1
Ford Assassin
Ford Assassin's Avatar
Question 454 Dually....5.3 Swap....Pros and Cons.
Hey guys, I have a mild 454 mated to a NV4500 in my 88 R30 dually. I get 14 mpg now highway, but under 10 in town.
I am considering swapping in a spare/fresh Gen IV 5.3 into it and retaining the NV4500. I tow about 6 times a year, but it it only weighs 3500 lbs. I have done no less than 20 LS swaps, mostly with a turbo, but nothing in something this heavy.
I am after better MPG without losing a bunch of towing ability.
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 06-06-2019, 12:24 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 454 Dually....5.3 Swap....Pros and Cons.
14mpgs from your setup sound pretty good to me...
I swapped my 350 for a 6.0 in my C30...went from 8-9mpgs to 15-16.....I also swapped the sm465 for a nv4500 at the same time and have 4.10s in the rear....I wouldnt think a LS would get enough better mpgs to justify the swap..
Mine tows great...regularly pull a 9500lb loaded trailer...gas mileage is terrible while towing
Hanging a NV behind a LS isn't cheap if you have to go with AA like I did
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 06-06-2019, 12:35 PM   #3
Ford Assassin
I don't think it will be bad at all since the bellhousing is the same pattern. I just need a 2000's 6.0/NV4500 clutch setup and crank spacer.
Unless you know something I don't.
Cable
Old 06-06-2019, 12:42 PM   #4
mongocanfly
Yeah I realize you've got the bellhousing...but I couldn't find the OEM parts to do the swap...
I used all advance adapters...the flywheel,clutch ,pressure plate was the big expense..
It cost me roughly 1k to connect a LS to a NV....I've done 2
I'm betting you wont see much if any jump in mpgs though
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-06-2019, 12:45 PM   #5
Ford Assassin
https://www.rockauto.com/en/catalog/...mission-manual
Cable
Old 06-06-2019, 05:10 PM   #6
kipps
No crank spacer needed. Just a 6.0 flywheel from the mid 2000's. nfw1050 is the classic example. It will fit a LS clutch, which will be the better option because it has more friction area. It will also fit an old-school 454 or 350 clutch, which will be the cheaper option. Just price out the parts, and decide if the extra friction surface is worth it. You will need to ream three of the bolt holes in the gen 1 pressure plate if you go that route.
I "think" all the chevy nv4500's were 10 spline by 1-1/8 diameter, but keep that in mind.
That 6.0 flywheel will still leave you with a 1/8" misplaced clutch surface. Use an adjustable fork pivot ball to make up the difference. Note that the fork pivot ball that I referenced in the link below will probably not fit your transmission.
Keep in mind that the commonly recommended manifolds for LS swaps are not assuming manual transmissions. Your passenger side external slave might be a challenge to get around. A driver's side slave can be cleared with a LS1 F-body manifold, but I think the passenger side manifold for these cars dumps further back.
Link to some of my measurements. Scroll down to post #11. Some day I'll get around to finalizing that list and neatening it up a bit.
https://ls1tech.com/forums/conversio...lhousings.html
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 06-11-2019, 10:55 PM   #7
Captainfab
60-66 Nut
Subscribing for later reference
Old 06-15-2019, 04:19 PM   #8
cdub2010
14mpg is damn good for yours right now, id be thirilled with that. I cant imagine why the 5.3 wouldnt meet your towing needs.
If I remember right I was getting 10-12 mpg from my 2007 2500HD 4x4. I couldnt get any better than 18 mpg from my '16 gmc 1500 4x4 with a 5.3. My '88 dually with a gutless tbi 454 gets maybe 10mpg so Im swapping in a supercharged 6.0 next summer. I figure If I can t have mpg Im gonna have fun.
cdub2010 is offline   Reply With Quote
Old 06-19-2019, 03:58 PM   #9
Clyde65
Clyde65's Avatar
I think the NV4500 is your biggest mpg draw, that thing is huge!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-03-2019, 10:46 PM   #10
Ford Assassin
Change of plans, still moving forward with the 5.3 swap, but going with a GT45 turbo either in the engine bay or under the truck in a mid mount configuration.
Cable
Old 11-04-2019, 12:11 AM   #11
mongocanfly
That sounds interesting...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-13-2020, 05:43 PM   #12
Ford Assassin
Found a low mile reasonable priced 6.0 and grabbed it last Friday. Heads are at the machine shop getting checked out and getting bigger valve springs. Bought and installed a new 8719 Summit truck cam, smallest aftermarket cam I have ever bought too, lol.
Going with my typical boost prep, including LS9 head gaskets. Oil pan is already drilled and tapped for a 1/2" NPT to -10AN for the turbo oil drain.
Cable
Old 02-13-2020, 06:36 PM   #13
mongocanfly
Sweet..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-05-2020, 01:47 PM   #14
Ford Assassin
Build thread....
Cable
