07-01-2019, 09:11 PM | #1 |
Rear Bumper measurements
Looking to fab my own 3/4 but need some dimensions first. Was wandering if anyone out there wouldnt mind stretching a tap measure across one for the lenght, depth, height and width.
07-09-2019, 09:09 PM | #2 |
Re: Rear Bumper measurements
Ttt
07-09-2019, 10:55 PM | #3 |
I can probably get this one out of storage and take some measurements if you are interested. It is an aftermarket bumper which telescopes out for an extended camper. It does tuck tightly to the truck though and could be mounted without the telescoping feature. It originally had only 4 holes for brackets, but I added four to use it on newer trucks. I also added the hitch receiver.
07-10-2019, 09:23 AM | #4 |
Thank You so much really i'm looking for the measurements of the bumper itself and once I get that I can figure on some brackets. If it wouldn't be any trouble Id sure appericate the measurements.
07-10-2019, 01:09 PM | #5 |
I have a bumper like the one on the GMC. I can get you measurements this weekend if you still need them.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
07-10-2019, 04:51 PM | #6 |
Yes Ill take all the measurements I can get.
07-11-2019, 12:33 AM | #7 | |
Here you go... The diamond plate is set back 1/2" from the edge of the 4" vertical "channel iron". Last edited by FirstOwner69; 07-11-2019 at 12:40 AM. |
07-11-2019, 02:00 PM | #8 |
Thank you so much hope to get some metal soon to build it.
