Rock Tumbler DIY -reduce RPM
Wife wans a rock tumbler (larger).
I have one of these I dont use much. https://www.harborfreight.com/power-...fer-61557.html Half inch arbor. 3450 RPM I need to drop that down to around 30 rpm. How do I work out the pulley sizes Im likely to need. Similar to this setup.
FAKKY 57 PANEL BUILD |
Re: Rock Tumbler DIY -reduce RPM
Damn.
According to this website 1:100 ratio. Meaning a 1" pulley small to a 100" pulley large. Ratio 1 : 100 Surely thats not right. https://www.blocklayer.com/pulley-belt.aspx
![]() Join Date: Sep 2014
I am not a certified electrician
![]() How about a rheostat? https://www.harborfreight.com/router...xoCb9IQAvD_BwE |
samkost - thats frigin interesting - just generally
![]() I *think* the issue is the calculator only shows what the final shaft speed will spin at. Its not the final rotation speed of the actual container. So its like a double reduction. Gotta work out how to calculate that.
![]() Join Date: Jan 2001
If we say your barrel is 6" in diameter and the drive rod is 3/4", that gives you a ratio of 8:1. So to reduce your 3450 RPM to 30 RPM you need a 14:1 ratio on your pulleys. If your drive pulley (the one on the motor) is 1.5" in diameter, you'll need a 21" pulley on the driven end to achieve 30 RPM.
If you increase the size of the barrel, the size of the driven pulley decreases proportionally. So unless you're planning on a relatively large barrel for the tumbler, your motor might just be too fast for the application. A controller would allow you to dial down the speed, but make sure it's rated for the wattage of your motor.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 08-30-2019 at 10:10 PM. |
Couldn't you run the motors small pulley to a larger pulley on a shaft that has another smaller pulley on the other end? Then a belt that drives a third large pulley on a separate shaft that drives the tumbler? (To act as a gear reduction)
Will someone smarter than me please explain what Im trying to say ![]() This picture is what I mean. Or.... You could buy her a rock tumbler instead of giving her old stuff you don't use anymore. I'm kidding. I do this stuff all the time.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
How big of rocks? You could get a swamp cooler motor and a 55 gallon drum cheap enough....
![]() ![]() Join Date: May 2015
Just get a 1750rpm motor and itd solve half your problem...then reduce
#9 | |
#10 | |
Then I realized I dont know how to to do the most basic setup ..... so I stopped. ![]()
#11 | |
Think the larger stuff we will just cut and polish.
#12 | |
You think just like me. https://tampa.craigslist.org/pnl/mat...965955841.html
"Tail Gate Best Seat In House"
![]() Join Date: Oct 2007
[QUOTE=FAKKY;8585172]ha ha mongo.
You think just like me. Fakky ,,others have given you good advice to what you ask,,and I have nothing to add except a story ,,(hope you don't mind ) it happens to do with rock polishing Years ago I was a sawyer in a little sawmill and on week ends a millright The mill was built up on piling where logs came up a slip to me at the headrig,,as I cut the logs in cants the sawdust /bark ect would fall down into a conveyor that took it out to the Wig Wan where it burnt up So on one Saturday as I was working millright ,one of the millrights was working on the conveyor where the motor was at ,,,and he welded a big steel truck wheel onto the end of the shaft that came from the motor and run the conveyor chains ... This how he got the stones he put in there shined ,,he used what ever compound you use to polish them with and the conveyor ran 2 -8 hour shifts day and night ,, By any chance are you a sawyer with a sawmill to do the same as the guy I knew..
When you learn a thing a day you store up smart. |
in post 12..still to much....https://tampa.craigslist.org/pnl/mat...965955841.html
#15 |
and for the rheostat in post 3 to work youd need a dc motor..not ac
here s a thought....you could use your wifes front load washer and dryer...!!!!!!
#16 |
Good one Mongocanfly ,, he probably does not have a sawmill to use to turn a tub ,,and the dryer would be handy ,,noisy but handy
#17 |
Thanks Mongo/Gopa.
Here's some cross sectional with a tile saw. ![]()
