Old 06-09-2019, 08:57 AM   #101
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1963 1/2 Ford Falcon aka Martha
I sure hope this is fixed too....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-09-2019, 09:57 PM   #102
nlped
nlped's Avatar
Originally Posted by Bean Counter View Post
Those gremlins you're dealing with SUCK but don't let them get you down! The car is looking great; can't wait to see the new interior!
David, you are SO right about the gremlins! But the engine oil leaks seem to be fixed. It showed a little leak at the trans dipstick tube so I replaced the o’rings on the Lokar piece and that seems fixed too. I also figured out the right rear drum was way over adjusted (not sure how that happened) and killed the shoes, so I got the brakes torn down, cleaned and ready for for new shoes and hardware. I’m off tomorrow, so I’m hoping to get that resolved. What’s next GrEmLiNs!!!
Thanks Dale,
Engine Oil leaks appear to be FIXED!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-09-2019, 10:05 PM   #103
nlped
nlped's Avatar
I also cut half a coil off the front springs. Don’t know how it’s going to sit, but it’s a start.
Carter
Old 06-10-2019, 07:45 PM   #104
nlped
nlped's Avatar
Rear brakes have been replaced! I forget how much I hate doing drum brakes . I’m going to take it for another test drive on the next dry day.
Carter
Old 06-12-2019, 08:51 PM   #105
nlped
nlped's Avatar
Got it out for a quick drive. Leaks seem to be fixed, but the TV cable seems to still be out of adjustment so I didn’t drive it far. I do like the new ride height though.
Before & After
Carter
Old 06-12-2019, 08:58 PM   #106
Ol Blue K20
Great news on the oil leak.....I like the new ride height. How much did it change the ride?
Dale
Old 06-12-2019, 09:02 PM   #107
nlped
nlped's Avatar
The ride doesn’t seem to have changed at all
Carter
Old 06-12-2019, 09:04 PM   #108
mongocanfly
mongocanfly's Avatar
WHAT?!!!....no oil leak?.....wow...you ready now...get TV fixed and go...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-12-2019, 09:50 PM   #109
Ol Blue K20
Awesome!!! That's great!
Dale
Old 06-22-2019, 11:27 PM   #110
nlped
nlped's Avatar
Well, I got all the little leaks solved and now the Broader Performance AOD took a dump! So, I’m hunting a 4r70w to put in that POS’s place.
Carter
Old 06-23-2019, 07:14 AM   #111
Ol Blue K20
That sucks!
Dale
Old 06-23-2019, 07:41 AM   #112
mongocanfly
Dont it though!....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-26-2019, 08:52 AM   #113
nlped
nlped's Avatar
That sucks!
Originally Posted by mongocanfly View Post
Dont it though!....
Yeah guys, this gremlin business is getting out of hand. It’s costing me a small fortune to get this d@mn car squared away.
Carter
Old 07-03-2019, 05:07 PM   #114
nlped
nlped's Avatar
I finally rounded up a 4r70w. Having it freshened up with a mild shift kit, new 2600 stall convertor, and US Shift controller enroute too. Hopefully I will have this in by the end of the month.
A buddy sent me this and I had to share...
Carter
Old 08-19-2019, 07:30 PM   #115
nlped
nlped's Avatar
Freshly built 4r70w is in the shop. Waiting on the PTC convertor and the US Shift controller. Then I’ll start the swap. Hoping to have it ready for the Holley Ford Festival in Bowling Green the end of September
Carter
Old 08-28-2019, 04:19 AM   #116
big_dan
Sweet project, even if I am a little biased!
All the startup gremlins will drive a dude crazy. When I finished my 65 and got it on the road, I fought a faulty master cylinder, leaking head studs and coolant leaks at the rear of the intake as well. It's all good now, though.
Following along -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 09-02-2019, 06:33 PM   #117
nlped
nlped's Avatar
So, I’ve finally begun the trans swap. I just got it on the lift and drained the trans fluid tonight. But, I’m hoping to get some time every evening to get it out this week. Then I’ll, hopefully, get the 4r70 in this weekend. I still have to figure out how to get my Lokar shifter to work with the 4r70w, as the 4r70 ‘pulls’ vs my AOD which ‘pushes’.
Carter
Old 09-08-2019, 05:42 PM   #118
nlped
nlped's Avatar
I got as far as I could on Belushi, so I got back on Martha. I got the AOD out and got all The related fittings and such swapped to the new 4r70w. I’ve got a buddy coming over to help me do a trial fit. Problem is that the “bellhousing” on the 4r70w is BIGGER and the Falcon has a tiny tunnel.
Carter
Old 09-13-2019, 05:32 PM   #119
nlped
nlped's Avatar
No pictures but I did a test fit of the transmission. It went in easy, but it went south pretty quick. Bellhousing hits the floorpan before the rear of the transmission was in place. Then I figured out that the trans crossmember was now to far forward and my cool a$$ aluminum driveshaft is to long too. Geezus, modifying a custom car crap always has issues.
I modified the floorpan (read BFH) and I built offset brackets to move the transmission crossmember back 1”. I’ll have to take the driveshaft to a pro to have it shortened and rebalanced.
Carter
Old 09-13-2019, 08:57 PM   #120
mongocanfly
It's never ends.....trust me...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-13-2019, 10:20 PM   #121
Ol Blue K20
X2, I love my truck but sometimes my modifications bite me in the butt
Dale
Old 09-14-2019, 07:50 PM   #122
nlped
nlped's Avatar
I totally know this, but for some reason, I’m still always surprised when things go sideways.
I did another test fit to confirm my BFH work on the trans tunnel and my new offset crossmember mounts are going to work. Looks like they’ll both pass muster. Now just gotta get the driveshaft shortened and throw it all back together.
Carter
Old 09-14-2019, 08:23 PM   #123
Ol Blue K20
I'm hoping everything goes smooth now
Dale
Old 09-14-2019, 09:10 PM   #124
nlped
nlped's Avatar
Thanks Dale! Me too!
Carter
Old 10-03-2019, 09:32 PM   #125
nlped
nlped's Avatar
I got the PTC torque converter and the correct Lokar shift shaft ordered today. I’m gunning to have this one ‘done’ by the end of the month.
Carter
