Old 09-11-2019, 06:18 AM   #1
BigBird05
Vintage air systems
Has anyone used the vintage air systems on the 72 c-10 truck? If so how did you like it? What other kinds do you no of?
BigBird05 is offline   Reply With Quote
Old 09-11-2019, 03:59 PM   #2
bigmac73
bigmac73's Avatar
Re: Vintage air systems
I think subject this will be a broad range of opinions. a while back i was curious about the same question.
So i went to the search box and typed in "vintage air " and "Old Air" and clicked the 67-72 web page bubble and let it roll, plenty of threads on the subject and opinions based on actual experience of the products.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-11-2019, 09:14 PM   #3
flashed
I have Vintage Air in my 72 , it works great .
flashed is offline   Reply With Quote
Old 09-12-2019, 02:02 PM   #4
19Loki67
Another option u could look into is restomod air. They look like cool product. I don’t have any experience with either tho. But I will eventually
19Loki67 is offline   Reply With Quote
Old 09-12-2019, 02:26 PM   #5
siggyfreud
siggyfreud's Avatar
We used a vintage air in our 69 el camino project and it worked pretty well. Had a few install issues and a bad wiring harness that they swapped out, but otherwise blows really cold and seems well-built.
I'll probably go with a resto-mod air for my personal project. I like trying new things, plus I like some of their other controls.
siggyfreud is offline   Reply With Quote
Old 09-13-2019, 07:36 PM   #6
57larry
got VA in my 68, air & heat works great
57larry is offline   Reply With Quote
