1966 C-20 Heater box Top
It may seem like a easy tasks
But I can’t seem to remove my heater box top Located on the firewall .... any advice .? I can open the top to see the heater core But we’re it sits on the top of the firewall On the drip rail I need to take it off Removed the bolt/screws on the top and sides were it connects to that drip rail still won’t budge Thanks .... Sp
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
Re: 1966 C-20 Heater box Top
If I remember right there are 2-3 bolts, sheet metal screws that are located inside, top of foot well area.
Don't ask how I know. Also do a search on heaters and there is a ton of info there. Cal. |
Thank Cal
I did a search and you are correct I just have to Summon the courage to lay down inside this cab Maybe it my age but it is by far one of the nastiest cabs I’ve seen I’m pretty sure they were storing garbage inside for sometime before I bought it I should have hosed it out before pulling to the garage That on me Sp
60-66 Nut
The entire heater needs to be removed from the firewall to be able to remove the top.
#5 | |
that sound like a big job I might have to put it aside till after I get it running Thanks Captainfab . . . ....Sp . .
