Old 11-19-2019, 11:32 AM   #6151
Gregski
Gregski's Avatar
Re: Restoring Rusty
more importantly this is the second time this has happened, a month or so ago I noticed the coolant was low, I topped it off and couldn't really tell where it went but it seemed like the 4.8L LSx water pump was weeping - it was hard to tell
now a month later this happened, how can it be that a weeping water pump goes back to good for a month than takes a dump again? I thought once they are bad they are bad?
Gregski is offline   Reply With Quote
Old 11-19-2019, 11:59 AM   #6152
wixthedog
wixthedog's Avatar
Re: Restoring Rusty
What an awesome thread, I can't believe I was able to read the whole thing while on the clock at work. Suckers!
Your attention to details, ingenuity, and humor were all appreciated. Thanks for taking the time to log it all.
wixthedog is offline   Reply With Quote
Old 11-19-2019, 12:08 PM   #6153
MikeB
MikeB's Avatar
Re: Restoring Rusty
Those vent window seals are b!tch to replace, but you can do it with patience and soapy water or silicon spray.
Be sure to leave the old seals and tape in your front yard because that's your absolute right.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-19-2019, 12:22 PM   #6154
MikeB
MikeB's Avatar
Re: Restoring Rusty
FWIW, I have seen Gen I SBC t-stat housing gaskets do the same thing. The leaks actually were worse on winter days after the truck had been sitting for days! Could be a difference in expansion rates of the metals, so as the temperature changes, the gasket isn't thick enough to compensate. However, those LS engines have some very nice gaskets, compared to GEN I gaskets, right?
Mike
Old 11-19-2019, 11:34 PM   #6155
LT7A
Re: Restoring Rusty
and having tried to fix it from the inside, this is how I drive around now, what a hack?
I'm a fan of making it work right and enhancing driveability. You can aesthetic-ize it later.
Old 11-20-2019, 12:58 AM   #6156
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Restoring Rusty
Puddles like that are why my 73 is manual steering now. Hate puddles under truck, like an untrained puppy
Old 11-20-2019, 11:13 AM   #6157
MikeB
MikeB's Avatar
Re: Restoring Rusty
I'm with you on leaks. They drive me nuts.
However, I must be lucky because I converted my 69 C10 from manual to power back around 1990 using a steering box, Pitman arm, pump, and hoses from a junkyard truck! The only thing that's been replaced since then is the return hose, because the old hose was looking pretty nasty. But I've never had a leak.
My 82 C10 came with power steering from the factory, but I did replace hoses and pump in 2015 when I converted the truck from 250 six to 350. No leaks there yet, but it's probably good for another 20 years.
Mike
Old 11-20-2019, 11:38 AM   #6158
Gregski
Gregski's Avatar
Re: Restoring Rusty
What an awesome feedback, I can't believe I was able to write the whole thing while on the clock at work, JK JK!
May I please turn you on to some of my other works: HP Tuners Tutorials
this one is guaranteed to cure your insomnia if and when it flares up ha ha INNOVATE DLG1 Wideband O2 Oxygen Sensor Tuning Diagnostics Logging Air Fuel Ratio etc
Old 11-20-2019, 11:39 AM   #6159
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by MikeB View Post
...Be sure to leave the old seals and tape in your front yard because that's your absolute right.
LOL, duh, where else would I put em'?
Old 11-20-2019, 11:41 AM   #6160
Gregski
Gregski's Avatar
Re: Restoring Rusty
100% agree on that, if nothing else the redesign of the LSx enjins is superb, tall cylinder heads with shallow lids for example to keep the oil in the enjin for example, ha ha, also smart intake manifold gaskets, no more running the beads of toothpaste on the China walls!!!
Old 11-20-2019, 11:43 AM   #6161
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank you, we can do the entire triangle window like that and call it 0% tint and perhaps start a new trend
Old 11-20-2019, 11:44 AM   #6162
Gregski
Gregski's Avatar
Re: Restoring Rusty
I believe Chevy's came like that from the factory, the option was called PLS, aka Pavement Lubrication System
let me tell you, other than this mishap the LS engine is awesome no more leaks, no more squeeks
Old 01-04-2020, 12:30 PM   #6163
Gregski
Gregski's Avatar
Re: Restoring Rusty
... well I don't usually do water pump repairs but when I do I pick the weekend after the Holidays that way I waste the first two hours breaking down all the cardboard boxes that somehow found their way into my workshop
Old 01-04-2020, 12:34 PM   #6164
Gregski
Gregski's Avatar
Re: Restoring Rusty
so got the truck in and performed the extraction, and there are Lessons Learned here
1. GM made at least two different water pumps one with a smaller 1.88" diameter thermostat opening and another with the larger 2.05" diameter thermostat housing (after buying the wrong smaller one first thinking it would make sense for the 4.8L I exchanged it for the larger one which was the one I needed for my 2001 GMC)
2. GM also made a couple different thermostat designs and also after buying not one but two wrong style ones I finally got the correct one, the correct one for the earlier 1999-04 trucks seems to be the one where the stat and the housing are one unit.
Old 01-04-2020, 01:08 PM   #6165
Gregski
Gregski's Avatar
Re: Restoring Rusty
I found in order to properly wire wheel the old crusty water pump gasket off of the driver side block I had to remove the accessory bracket and slide it out of the way, I like my surfaces pretty darn clean, and even using a gasket scraper I could not get all the pieces off otherwise (you can leave the power steering pump plumbed)
Old 01-04-2020, 01:11 PM   #6166
Gregski
Gregski's Avatar
Re: Restoring Rusty
not sure why two bolts were super rusty, one on either side, I don't think any of the six bolt holes go all the way through to the water jackets, I tested them with a poker and all of them bottom out
oh well I cleaned all of them threads and used anti seize on em as I always do, you're welcome future owner, ha ha
Old 01-04-2020, 01:16 PM   #6167
Gregski
Gregski's Avatar
Re: Restoring Rusty
so um yeah, back to that thermostat, this unit is one piece the thermostat does not come out of the housing, no matter if you use a vice and a chisel... German Engineering at it's finest (no joke)
Old 01-04-2020, 01:22 PM   #6168
Gregski
Gregski's Avatar
Re: Restoring Rusty
my buddy Pontiac Mike found this write up on the early LS GM water pumps you mind find helpful / useful
https://www.lingenfelter.com/PDFdown...ats%20List.pdf
Old 01-04-2020, 01:24 PM   #6169
Gregski
Gregski's Avatar
Re: Restoring Rusty
my buddy Pontiac Mike found this write up on the early LS GM water pumps and thermostats you mind find helpful / useful
GM Gen III & IV V8 Engine Thermostat Identification:
GM has changed water pump and thermostat designs on the Gen III & IV V8 engines (LS engines) several times over the years. Make sure you have the correct thermostat for your vehicle. This is especially important if you have had your water pump replaced because in some applications the service replacement pump and thermostat may be different than the original equipment pump and thermostat:
Old 01-05-2020, 04:03 PM   #6170
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I found in order to properly wire wheel the old crusty water pump gasket off of the passenger side block I had to remove the accessory bracket and slide it out of the way, I like my surfaces pretty darn clean, and even using a gasket scraper I could not get all the pieces off otherwise
I use Roloc 3M Scotchbrite discs on an air grinder. Knocks that stuff right off right now.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-11-2020, 12:05 PM   #6171
Gregski
Gregski's Avatar
Re: Restoring Rusty
I skierd sand paper will chew the metal especially if it's aluminium
Old 01-11-2020, 12:07 PM   #6172
Gregski
Gregski's Avatar
Re: Restoring Rusty
I knew I should have done did the belt at the same time as I replaced the water pump, but why do it once when you can do it twice, ha ha
no seriously I was a bit low on funds
went with all AC Delco junk to keep it as OEM(ish) as possible fully aware you never get the stock type quality parts once the horse is out of the barn anyways
Old 01-11-2020, 05:56 PM   #6173
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
You can get fine 2" Roloc Scotchbrite pads that don't seem to do much to aluminum as long as you don't lean into them and don't dwell in one place.
Kiss the surface with them and let the plastic mesh do its' thing.
They cut the paper and silicone gasket crud off pretty quick. They'll eat up oxidation but not quite as fast.
Old 01-23-2020, 11:50 AM   #6174
Gregski
Gregski's Avatar
Re: Restoring Rusty
scored some black used Suburban inside door handles for my truck on eBay, so time to ditch the piece of junk all foam LMC new ones and go back to OEMish used ones that actually work cause they actually have a metal bracket molded into them as God intended....
Old 01-23-2020, 11:54 AM   #6175
Gregski
Gregski's Avatar
Re: Restoring Rusty
there is a short list of advantages of cold humid days and finding exhaust leaks would be one of them
here I show you the crappy job I did welding my own exhaust pipes on my back under the truck, whaaa whaa whaa excuses excuses
saw these drip drips from a mile away one crispy cold morning, so I peaked under there
this is the passenger side right before the rear axle, this bend was the worst one of them all, we had to weld in a pie shaped patch here and it was crazy ugly
