Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-22-2019, 05:26 PM   #3176
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Today was a rare exception, everything went right. Double flare on the rear axle worked first time, brakes are done, and clamped to the frame rail with totally stainless 3/16" clamps. I'll let them bleed them. 5th or 6th time on the power steering belt tensioned up today, both belts are now done. Just waiting on some parts I lost (u-bolts) for the drive shaft, and PTO cover plate gasket, both found locally. rear diff. cover sealed up, and both shocks are mounted
also mounted the remote tank for the hydro boost
[url=https://flic.kr/p/2hNX7r6]20191121_121327
Now its time for some R&R, thanks giving then a florida trip for a week, hope the fish are biting, and not the bugs
Balls in Dale's court
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-22-2019, 08:16 PM   #3177
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2hNW6uC]20191121_121427
SAFETY FIRST
AS usual, off topic
Jim
Old 11-22-2019, 09:22 PM   #3178
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
lookin good......
zicc1835 is offline   Reply With Quote
Old 11-23-2019, 02:33 PM   #3179
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
lookin good......
Thanks Jesse, its so close I can feel it, but I hate to leave it for two weeks
SAFETY FIRST
AS usual, off topic
Jim
Old 11-23-2019, 02:48 PM   #3180
IronCanine
I'm trying....
IronCanine's Avatar
Re: PO has me PO'd
Originally Posted by jaros44sr View Post
Today was a rare exception, everything went right. Double flare on the rear axle worked first time, brakes are done, and clamped to the frame rail with totally stainless 3/16" clamps. I'll let them bleed them. 5th or 6th time on the power steering belt tensioned up today, both belts are now done. Just waiting on some parts I lost (u-bolts) for the drive shaft, and PTO cover plate gasket, both found locally. rear diff. cover sealed up, and both shocks are mounted .....also mounted the remote tank for the hydro boost...
Congrats. Doesn't if feel good to get a win. I'm still seeing failed flares in my nightmares. Enjoy your success and your well earned break.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-23-2019, 08:14 PM   #3181
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thank you, and thanks for entertaining me with your two unbelievable builds.
My last flare, I was laying on my creeper upside down and backwards, not seeing clearly as my bifocals were coming in and out of range, working in the dark with a little flashlight, afraid to unclamp the flaring tool.
but to my surprise as I brought it down and looked, it was perfect, sometimes you just get lucky. This truck has fought me every step of the way for over twenty years. This the first day that I have not gone to a shop, or thought about it, in some fashion for that long of a time. I will never modify a project again!
Yeah right, my mind is now drifting to installing a LS engine in a TR-6. That is where my roots started, early english sports cars
But, thanks for stopping by and your kind words, whats up with you and your next project after your break
SAFETY FIRST
AS usual, off topic
Jim
Old 11-24-2019, 09:20 AM   #3182
Thealien
Thealien's Avatar
Re: PO has me PO'd
That sounds "FUN"
Old 11-24-2019, 09:24 AM   #3183
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
That sounds "FUN"
Sorta like a Caroll Shelby knock off, using a frame from a kit car with corvette suspension
never liked the doors on an AC Cobra, plus my workshop is too small for trucks LOL
Plus tr-6's have flat panels on the bonnet and rear deck to widen the body
Yeah, I'm a glutton for punishment
SAFETY FIRST
AS usual, off topic
Jim
Old 11-25-2019, 02:28 PM   #3184
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
found some oem parts that I lost in my basement at my local 4X4 shop
[url=https://flic.kr/p/2hQPiZX]20191125_132123
SAFETY FIRST
AS usual, off topic
Jim
Old 12-09-2019, 04:20 PM   #3185
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2hXai2X]20191209_122114
[url=https://flic.kr/p/2hXahYa]20191209_121959
[url=https://flic.kr/p/2hXahX8]20191209_122025
[url=https://flic.kr/p/2hXai5T]20191209_122136
SAFETY FIRST
AS usual, off topic
Jim
Old 12-09-2019, 07:57 PM   #3186
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
When I returned from Florida (83 degrees and sunny all week) This what Dale had accomplished. I finished the work on the drive shaft and PTO cover. Now I have to build a bracket for the trans dip stick since it sits to close to the firewall
found out that 2 of the holes are blind, in the T/C so, had to come up with a 1/4" shorter bolts, they are the 2 bolts towards the drive shaft
He doesn't like to mount the air temp. sensor in the plenum as it will see heat and throw off the readings, so, later on I will mount it in the air cleaner somehow
SAFETY FIRST
AS usual, off topic
Jim
Old 12-12-2019, 09:09 AM   #3187
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Its alive
SAFETY FIRST
AS usual, off topic
Jim
Old 12-12-2019, 09:11 AM   #3188
rsavage
rsavage's Avatar
Re: PO has me PO'd
Yay!!!
1961 C1 Corvette
69 Blazer K5
2019 Ram Rebel
rsavage is offline   Reply With Quote
Old 12-12-2019, 09:18 AM   #3189
richard2717
Senior joke offender
richard2717's Avatar
Re: PO has me PO'd
Congrats, it has to be a great feeling
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton
https://paypal.me/6772GMtruckparts ....
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-12-2019, 11:40 AM   #3190
Thealien
Thealien's Avatar
Re: PO has me PO'd
Its alive
Excellent
Old 12-12-2019, 04:48 PM   #3191
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
litebulblsc is offline   Reply With Quote
Old 12-15-2019, 12:57 PM   #3192
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
Its alive
Video is required to support such statements.
- AJ
Cruiser Crawler Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 12-15-2019, 01:20 PM   #3193
toolboxchev
Re: PO has me PO'd
Yea, X2 on that. How about a rip down the freeway!
toolboxchev is offline   Reply With Quote
Old 12-15-2019, 08:10 PM   #3194
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Excellent Jim.
low'n slow is offline   Reply With Quote
Old 12-15-2019, 09:46 PM   #3195
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
fantastic.......
Old 12-23-2019, 05:44 PM   #3196
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20191223_135155 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 12-23-2019, 05:51 PM   #3197
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20191223_134840 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 12-23-2019, 06:08 PM   #3198
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
yeah, she leaks alittle, and has some wierd rattles, and shakes, but give me some time and she'll be on the road
Thanks everyone for following this epic build, and your input over the years, it's been real
first video, touch the screen
SAFETY FIRST
AS usual, off topic
Jim
Old 12-23-2019, 06:23 PM   #3199
IronCanine
I'm trying....
IronCanine's Avatar
Re: PO has me PO'd
That is awesome Jim. Congratulations!
Old 12-23-2019, 06:51 PM   #3200
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Bud, just have to figure out some metal to metal noises
SAFETY FIRST
AS usual, off topic
Jim
Copyright ©2000 - 2020, vBulletin Solutions Inc.
