Top crack repair
Wondering if the best fix for these joints is seam sealer
Re: Top crack repair
Bueller.......Bueller........Anybody? trying to do this week and really trying to do it right...lol
![]() Join Date: Jan 2001
I'm not a bodywork expert, but I think the answer would be that seam sealer would be a temporary fix at best. The top is made of SMC (sheet molded composite, similar to fiberglass) and what you're seeing is a structural defect. Seam sealer isn't meant for structural problems.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Those are factory seams. What ever they used, is cracking out. The other common place i found for this to happen is in the gutters. I am of no help on the correct fix.
You might try the paint and bodywork subforum.
I'm thinking grind the old sealer out and recoat with new seam sealer and re-raptor the top. Definitely not structural just where the top was seamed at the factory, years of on and off probably pushed the 50 year old product to it's max.
![]() Join Date: Nov 2013
grind and feather out the seam and repair with stranded fiberglass epoxy filler
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Got a heads up from a local guy who recommended PC 11 marine epoxy which can be sanded and painted. I'll let you know how it turned out
The seams on SMC are structural. It's where two pieces of molded composite were joined together. Look at the curve at the top of the window and you can see a crack around the radius.
Probably not corrcect to call it not structural. But the "crack" at the window is still just the seam opening.
I wasn't talking about the seam. It looks like there's a small crack that's around the radius of the window opening. The red lines point to what I'm talking about.
Following
