#26 |
Re: 68 GMC frame off build
In the air. I couldnt do what i do without this lift.
Because I lift from the rear, the box is very front heavy. A few 66lb bags of concrete level things out nicely. Making for a very easy lift.
--------------------------------------------------------------- Jason. 68 GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#27 |
I'm trying....
![]() Join Date: Oct 2013
Alright alright alright...here we go!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#28 |
As Im sure most know. Removing 51 year old carriage bolts is a PITA. Since the bed floor is junk, I just cut the floor 6 along the boxside. Then I just flipped them over to grind the bolts off.
#29 |
Swapped the body cart for some wheel dollys.
Need the body cart for the cab, which will be off shortly.
#30 | |
![]() Join Date: Dec 2009
Did you make them? .
#31 |
I did not. The same guy who shortened my frame and notched it built them. He has a whole line of Automotive restoration Accessories. Rottiseries, cab lifts, body carts, these dollies. And he’s always tinkering with other ideas.
#32 |
Finally drug the cab and chassis in the shop tonight.
#33 |
Got a bit more disassembled tonight. It sure is nice to take apart a truck that isnt super rusty! All bolts came out without any issue. Not common around here.
I dont plan on taking the front clip apart so have to wait for some assistance to get it off. Should be fully disassembled tomorrow.
#34 |
Popped the windshield out for a pleasant surprise. Some well earned patina but no rust.
Around here, these corners really like to bubble up when trucks sit.
#35 |
Looking good! Keep them progress pics coming!
71 C-10 SWB LS Swap |
#36 |
The floor on the other hand isnt quite as clean, but still in better shape than most around here.
2 cab corners 2 lower kicks and floor panel Both sills above the rocker. Not sure about the mounts yet. They look pretty good so far but wont know for sure until I get it off the frame.
#37 |
Thanks! Slow going but post when I can.
#38 |
I'm trying....
Looks like fun. Thanks for the update. PS...What's that white stuff on it in post #32?
#39 | |
#40 |
Well thats it, body is now completely disassembled.
#41 |
Rolled the old frame outside. Still gonna need some odds and ends from it, but for now it can sit.
From what i can tell, its the original 307. Not like anyone would put one in on purpose ![]() ![]() Ill throw it up for sale for a few bucks, but if it doesnt sell itll go to scrap. Too bad, cause it actually runs.
#42 |
![]() Join Date: Aug 2018
I sold my 307 pretty quick for $200, maybe just luck. It ran great and fired right up every time and only had 35,000 miles.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
#43 |
Ill put it up for few days before I junk it. Thats for sure.
#44 |
Forgot to post these up. Boxsides are quite nice. A few more dents than Id hoped for but zero rust. Pretty damned good for a farm truck that worked for a little over 40 years.
Theyll head out to a body guy soon to be shortened ![]() ![]()
#45 |
Crazy how the spotwelds on both were broken in this area.
An easy fix for sure. Just not by me ![]() ![]()
#46 |
Ran the box sides down to friends shop, hes really good at shortening factory sides with very little paint disturbance. Looking forward to getting them back.
#47 |
Managed to find a little bit of time to work on the cab tonight. Nothing crazy, but its the little things that aid in reassembly.
A simple tap through the hinge plates sure makes things easier later. It pretty nice when the original bolts clean up this nicely.
#48 |
Im so tired of cleaning up mouse nests and crap, the joys of fixing up a farm truck. Found this little apartment behind the gas tank.
#49 |
Fun pic of the day, Threw some extra parts at the parts truck to make it look complete. Now she looks cool just hanging out on the driveway.
Has no engine, trans or interior, and all i did to lower it was cut out the coils, but with a bumper and the 22s, She at least gives the impression of looking like an actual truck ![]() ![]() Guess you could call it driveway art.
#50 |
![]() Join Date: Mar 2011
you been busy
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
