12-23-2019, 02:11 PM | #126 |
Re: Son's 68 c10 Short Bed
Didn't take any pictures but got the power steering all buttoned up on Saturday. The boy is working this week on removing the old cross braces from underneath the original bed floor so we can install them under the new floor.
Had to order another fan relay and some other small parts (Transmission cooler lines, and Temp Sending unit) so we can get this thing ready to fire. Also, I figured out the radiator I bought didn't have an bung for the fan relay so I ordered one we will have to Heliarc it in.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
12-31-2019, 02:00 PM | #127 |
We got some stuff done over the Christmas break.
First picture is of the tranny cooler lines. I had a local shop sweat some fittings on them and I will run rubber hose to the radiator. Second picture is of the steering wheel my son got for Christmas. Third picture is of the engine with the harness all strung out. I still need to clean up the wiring but it is basically done. I bumped it over on Saturday which was exciting. Need to do a couple more small things like plumb the radiator and fill it with fluids. Also need to wire the fan relays and mount the computers but we should be making smoke by the weekend.
01-02-2020, 11:22 AM | #128 |
I was able to spend part of New Year's Day working on the truck. Finished the fan relays, and the transmission cooler lines. Today, they need to find some radiator hoses and add antifreeze and fuel and it should start.
01-02-2020, 11:24 AM | #129 |
I don't know why the pictures are uploading sideways. Anyone know how to fix it?
01-02-2020, 11:35 AM | #130 |
Are you using the 3-relay setup?
If you're using an iphone, you have to take the picture holding the phone sideways with the home button on the right.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
01-02-2020, 11:52 AM | #131 |
Looking good!
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
01-02-2020, 12:14 PM | #132 |
3 relays for the fan or the harness? The fan was 2 and the harness has 3.
01-02-2020, 12:15 PM | #133 |
01-02-2020, 12:30 PM | #134 |
For the fans. It's a GM schematic that allows both fans to run half speed at the low temp setting and then both run full speed at the high temp setting. This setup gets its triggers from the PCM. I like it because it pulls air across the whole radiator all the time and is quieter.
01-02-2020, 02:54 PM | #135 |
Well, this just happened.....
https://youtu.be/-L6-lUMfA7o https://youtu.be/4-5tb7Yw1HA https://youtu.be/tVoyquxHMdg
01-02-2020, 03:02 PM | #136 |
BadAZZ!!
qq, do your tailpipes clear the rear axle when fully suspended in c-notch? I had to bend mine up after the cross-member or they would hit when fully suspended up to bump-stops in c-notch. Just curious. The exhaust sounds really good. I will go back through your thread, but if you didn't say, what are the exhaust details? mufflers? H or X pipe?
01-02-2020, 03:28 PM | #137 | |
01-02-2020, 06:24 PM | #138 | |
Your truck looks good and is coming along nicely.
01-03-2020, 10:20 AM | #139 | |
I'm jealous of you guys with coil spring rear ends for the ride quality, traction characteristics, and clearance for mufflers to be hung up high.
01-06-2020, 11:15 AM | #140 |
The last one of these we built (link in signature) was a leaf spring truck. Each has it's own set of advantages and challenges that's for sure.
01-06-2020, 11:50 AM | #141 |
On Saturday, I was able to get most of gauges working. Still need to run a line for the oil pressure gauge and order a speedo converter.
I also installed the check engine light. It's currently lit because I haven't gotten my air intake in and installed so the MAF is plugged in but just sitting on top of the intake.
01-13-2020, 12:33 PM | #142 |
Small little update from the weekend. I am cleaning up the wiring still and got the Neutral Safety Switch all finished up as well. I also installed a radiator overflow. Picked it up from LMC and mounted it using the factor windshield wiper fluid bracket welded to the bracket that came with the catch can.
01-13-2020, 01:55 PM | #143 | |
01-15-2020, 11:21 AM | #144 |
Thanks, that was the idea.
01-17-2020, 10:58 AM | #145 |
Nice progress! Where are you guys with the bed? Hows that coming along? I'm looking forward to see the fuel door mods and set up.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
01-20-2020, 11:25 AM | #146 |
Honestly, we haven't touched it since the last pictures. Once school is out, the boy will jump back on it and hopefully knock it out relatively quickly. The front clip is stripped but nothing done on it either. Hopefully, next step is to get the doors painted and hung so I can wrap up the interior.
02-03-2020, 05:23 PM | #147 |
Spent a few hours on the truck last weekend and was able to get the air cleaner/filter assembly installed. I bought a cheap kit off amazon and had to cut it down and built a support arm off the battery box. Came out pretty nice though.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 Last edited by Camaroguy; 02-04-2020 at 12:09 PM. |
02-03-2020, 05:25 PM | #148 |
I also finally took the time to build a bracket to mount the DBW gas pedal. This was something I have been dreading but I think it came out nice.
02-05-2020, 05:36 PM | #149 |
Looks good to me! That seems to be what most guys do.
02-10-2020, 10:43 AM | #150 |
This past weekend we finished the sound deadening, and installed the carpet and seat. The boy got to putt the truck around the facility a few times which was fun.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 Last edited by Camaroguy; 02-11-2020 at 11:04 AM. |
