Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 03-18-2019, 09:24 AM   #151
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1963-1966 Chevrolet & GMC C10 / C20 Aluminum Radiators!
Yes, its fine to put in on the passenger side on a downflow. We've been building this style like that for a decade with no issues.
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 04-01-2019, 10:00 PM   #152
SparkyRnD
SparkyRnD's Avatar
we appreciate the support!
Old 05-03-2019, 02:20 PM   #153
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 06-10-2019, 10:14 AM   #154
SparkyRnD
SparkyRnD's Avatar
up top again
Old 06-27-2019, 09:30 PM   #155
SparkyRnD
SparkyRnD's Avatar
back up again
Old 07-19-2019, 05:57 PM   #156
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering
Old 09-05-2019, 11:21 AM   #157
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 10-16-2019, 10:20 AM   #158
SparkyRnD
SparkyRnD's Avatar
up top!
Old 12-23-2019, 10:36 AM   #159
SparkyRnD
SparkyRnD's Avatar
Thanks for the continued support, we appreciate it!
Old 01-18-2020, 10:27 AM   #160
rodstored-72
chevy truck fan
rodstored-72's Avatar
Hi,
I have a 86 2wd C10 with a 4.8/4L60. I am looking for a reliable radiator/fan setup (this is a daily driver), I have a VA air conditioning unit. Can you please give me recommendations for a good radiator here in the desert? The engine is stock W/O any upgrades. ��
Thanks ��
rodstored-72 is offline   Reply With Quote
Old 01-20-2020, 02:19 PM   #161
SparkyRnD
SparkyRnD's Avatar
Sure, our standard radiator will be fine for that. With A/C and being in the desert, I'd go with our upgraded single 17" dual-speed fan. I assume you'll use the PCM / LS harness to control the fan?
Old 02-17-2020, 08:19 PM   #162
Clyde65
Clyde65's Avatar
I have an LT L83 with Ac and in Tx, what would you suggest and could you PM me the cost please?
I would like the best shroud & fan option also.
Clyde65 is offline   Reply With Quote
Old 02-19-2020, 10:59 PM   #163
scf100
scf100's Avatar
I see your located outside of Atlanta I am in Athens,
I am working on a 1970 Blazer 2WD factory 6 cylinder but PO dropped in a 454 stroked to a 496 and automatic no ac.....not hooked up yet so not running
What radiator, shroud combo do you have for this setup
1970 2WD Blazer 496 Rat Motor
scf100 is offline   Reply With Quote
Old 03-13-2020, 11:38 AM   #164
SparkyRnD
SparkyRnD's Avatar
sending PM shortly.
Does the 6-cylinder use the same radiator mounting / supports as the V8? If the width and mounts are the same, it'll be easy. If you wish, you can PM me pictures and a few measurements to confirm.
Sorry for the delayed reply, the forum didn't notify me there were replies.
Old 03-23-2020, 10:01 AM   #165
SparkyRnD
SparkyRnD's Avatar
up top!
Old 04-22-2020, 09:48 AM   #166
SparkyRnD
SparkyRnD's Avatar
we can build radiators for most any application!
Old 05-05-2020, 11:13 AM   #167
SparkyRnD
SparkyRnD's Avatar
back up top!
Old 05-27-2020, 01:00 PM   #168
SparkyRnD
SparkyRnD's Avatar
up top again!
Old 06-19-2020, 04:21 PM   #169
SparkyRnD
SparkyRnD's Avatar
remember to ask for your discount when ordering!
Old 07-10-2020, 10:23 AM   #170
SparkyRnD
SparkyRnD's Avatar
thanks for the support!
Copyright ©2000 - 2020, vBulletin Solutions Inc.
