![]() Join Date: Nov 2018
70 C20 12v Cummins
$8500
Looking to sell not trade, too many vehicles. Price drop is now reflective of wanting to sell the truck so keep that in mind. I've had the truck for 16 years now and has a clean title. Factory C10 frame swapped to a correct 3/4 chassis. 92 12valve VE pump rebuilt & tuned, he341 turbo, a518 46rh overdrive trans, would hit 41 lbs of boost when the fresh pump was put on but have it backed down to a safe 35 pounds. Rear suspension is trailing arms with airbags which do not leak and front is from disc brakes are from a single wheel square body C30, with the weight of the Cummins it rides just like when it was 1/2 ton with a small block. 3" in and out intercooler with matching pipes. Truck has been overbuilt as I didn't want to have to fix anything. All parts are able to be store bought also, everything was centered around parts for a 1990 R20/R30 series truck to keep things simple and parts available without special order. I'll just list everything in addition to the above to keep questions to a minimal. Ho52 Eaton rear axle with 4.10 locker Not sure what all was done to the trans in its previous life but it has an aftermarket purple converter and has never slipped or had a sloppy gear change once. It definitely has some work done to it. Engine was all stock in a work truck with 135k miles when I got it. Driveshaft is a 1 piece built by Nash truck parts with 1410 joint in the front and the stock 1350 at the axle 32.5” tires on 18x9 wheels Aluminum radiator with 2 1.25" wide cores(stays under 175 in 90 degree weather) have a new thermostat just haven’t installed as it seems to run too cool 3.5" downpipe to 4" exhaust with a 5” tip that you can barely see Currently have 98% of the parts to convert it to P-pump also Injection pump has a new head/rotor assembly, new cam plate, 3200 governor spring. 15x.012 VCO nozzle on Bosch injectors from DAP “The hungry diesel” high volume/low pressure piston pump Timing advanced to 19-20 degrees(advanced one tooth at pump gear and pump pulled away from the head) All last year didn’t have the grid heater hooked or used the block heater all the way down into the 20s and still fired off great. Verified last night the block heater does work. EGTs will not go over 1250 no matter how long you stay in it, pushing 34.5-36 lbs of boost. Spools almost instantly with the HE351 turbo Group 31 battery mounted in proper plastic box inside of an old tool box in the bed. Rebuilt original Bosch starter Full auto meter gauges(tach, trans temp, boost, pyro, water, oil pressure) trans temp I haven’t hooked up yet All led dash lights, led interior and floor lights Newish filters and fluids (trans, oil, fuel) only live a few miles from work Hyrdroboost conversion using new factory replacement gm parts for a 90 model square body and factory hoses Curt receiver hitch Braided Teflon lined fuel supply lines Clear headlights with HIDs LED front running/turn signals and rear tail/brake lights Factory Chrysler 140 amp alternator with internal regulator conversion Carpet in good shape Lokar cable shift conversion using stock automatic column(overdrive is a toggle as I never installed pressure switches to make it automatic) New complete ac/heater wiring harness and box resealed years back, cables are under the dash but not hooked up as I didn’t have the retainer when replacing the heater core a couple months ago(aftermarket aluminum and think it’s leaking again slightly) Factory AC truck and compressor on engine, needs hoses made and a condenser to have working air Heat and defrost does work Wipers and even the windshield washer squirters work Sony CD player with USB and Infinity 6x9s behind the seat in cab corners 2" body lift to clear drivetrain while keeping the low hump trans tunnel to keep maximum ground clearance and nothing hangs below the frame KDP taken care of, new crank and timing cover seal Needs a couple loose ends tied up(wires cleaned up but everything properly fused, bed wood replaced, 15 gallon fuel cell in the bed as I never bought a tank to go under the truck) Needs door panels and previously had 6x9 speakers added in the lower doors but they are messed up. Seat has a torn spot that could still be repaired. Mechanically it is right and no issues going down the highway at 75 MPH and will keep going right past that if you want Rust issues are pictured and have been this way for the 15 plus years I’ve had the truck as it’s either been garaged or parked under cover. As you can see the inner rocker needs repair but not necessarily a full replacement. Outter rockers need replacing. The truck has its problems but nothing serious as I drive it over half of the week. I know it’s a lot to read but I try to be very thorough on the good and the little bit of bad. I’ve towed 8k lbs a few times and it handles it great.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... 72 burb no longer getting the short bus treatment, cut the a** end off to become a Denali! Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 10-20-2020 at 11:07 PM. |
Re: 70 C20 12v Cummins
And the goods
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... 72 burb no longer getting the short bus treatment, cut the a** end off to become a Denali! Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
![]() Join Date: May 2012
Looks like a ton of fun! If only my lottery tickets would start paying off...
![]() Join Date: Jan 2013
Price??
72 Cheyenne k/20, Custom Camper 72 Cheyenne k/20 71 blazer K/5 2WD 454, 6 sp. 67 Chevy Napco c30 Dump 56 GMC Napco 4x4 short step 66 Chevy K10 68 Chevy C/30 4x4 |
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... 72 burb no longer getting the short bus treatment, cut the a** end off to become a Denali! Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 12-18-2019 at 12:41 PM. |
I do have a bunch of new parts, dash pad, arm rests, seals, various items. For the right price I’ll let extras go with it
If anyone is interested, still open to letting it go if it sells before the crew cab. But only selling 1 of the 2. Willing to talk numbers for the right person
Available again, $8500 this time. Still drive it once a week, price is right as to help someone that will appreciate it.
![]() Join Date: Nov 2004
Aw maaaan…. Wish a could. I NEED that! Good luck with the sale to the lucky buyer
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi..........'The 67' (project) '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72' (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 |
I know tight. Figured I’d make an easy sell price and have one less vehicle to worry about.
Is this still for sale?
1983 M35 (bobbed and converted to dump) 1988 Chevy Suburban (5.7TBI/TH700R4/NP208) 1991 Chevy Suburban (5.7TBI/TH700R4/NP241C) 2005 Toyota Matrix 2002 VW Passat (sold) (YEA!) 1986 M1009 (6.2/TH400/NP208) (sold) |
That’s actually a good question. I ran it hard with an unknown stopped up fuel filter last month and scored the pump, actually have the parts on the way and fixing it this weekend. Still runs good but needs help starting. But I haven’t thought much about selling it. So technically yes it’s for sale but no desire to push a sale.
Also all the extras wouldn’t be sold with it, they’d have to stay for the crew cab
