Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-18-2020, 10:38 PM   #76
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Creamsicle: My 70 K10 SWB is about to get sweeter
I’ve been following along and wanted to say thanks for the detailed build documentation. I’m intrigued by LS swaps into K trucks and you’ve paved a good path for others. The truck and build are outstanding.
Old 02-18-2020, 11:59 PM   #77
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Thanks for the kind words. This is my first LS swap, so I'm learning as I go along. I'm doing everything by myself. There are probably better ways of doing some of the things I've done and I'm sure I'll make some mistakes. This forum is an excellent source for information and the members are always willing to help. if I can reciprocate by helping someone out, it'll make me feel that much better.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-19-2020, 12:27 PM   #78
First c10
First c10's Avatar
Hey dan.
Truck is looking great. Thank you for the lick to the bed floor. I talked with Frank and he is working with me on some custom cut flooring for my project.
I was wondering how you got the decal now I know. Rock on brother.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 02-19-2020, 01:11 PM   #79
derotoreut
derotoreut's Avatar
Originally Posted by First c10 View Post
Hey dan.
Excellent! Can't wait to see what you do. Keep me posted. Will you go with the drop-in kit, or bolt-in kit? I went with drop-in kit here because it made sense for this project, but when I get back on my '71 C10 project it'll be a bolt in kit. Peace out!
~ Dan
Old 02-19-2020, 01:51 PM   #80
First c10
First c10's Avatar
I have a '72 wood floor bed. It will be the bolt in kit with hidden fasteners!
GO GO!!!
Old 02-19-2020, 02:34 PM   #81
Thealien
Thealien's Avatar
Bravo sir, Bravo!
Thealien is online now   Reply With Quote
Old 02-19-2020, 03:01 PM   #82
derotoreut
derotoreut's Avatar
Bravo sir, Bravo!
Thank you sir. It's kind of ironic you're posting today. This morning I went through and read your WTB and sale threads on the Blazer. Very disappointing, but you will pull through. There are a lot of great members here. Chalk it up to one bad experience and a learning lesson. Good luck with your shoulder issues my friend!
~ Dan
Old 02-19-2020, 03:37 PM   #83
Thealien
Thealien's Avatar
Thank you. Even when I wasn't injured I didn't have your skill, or awesome garage!
I did a similar build in a Jimmy over 10 years ago. It was fun and really makes these trucks enjoyable to drive.
Old 02-28-2020, 10:24 PM   #84
derotoreut
derotoreut's Avatar
So I'm doing some work on my AC lines. I want to conceal my AC and heater lines in the PS fender. I know that I could put a bulkhead on the firewall, but that would be too easy, LOL.
I bought this inexpensive bulkhead (sorry made in China) to use inside the PS fresh air vent.
My plan is to install the bulkhead inside the vent with the good side of the bulkhead inside the vent and the nuts on the outside (bottom) of the vent. This way I can remove each piece, make the connection outside of the vent and then put it back inside. Otherwise I wouldn't be able to get wrenches inside the vent to tighten the AC and heater hose connections.
This side will go on the bottom of the vent.
~ Dan
Old 02-28-2020, 10:40 PM   #85
derotoreut
derotoreut's Avatar
The bulkhead connectors have flats on them so they won't spin in the bulkhead plate.
I'm planning to use these fittings on the bottom of the vent.
~ Dan
Old 03-02-2020, 12:25 PM   #86
derotoreut
derotoreut's Avatar
AC Line Update: I've been doing a little more work on the routing of my AC and heater lines. I drilled holes in the bottom of the passenger side fresh air vent in order to mount my AC/Heater bulkhead. I drilled the first hole and then realized that layout wouldn't work. I ended up with an extra hole, but that will be mostly covered by the bulkhead. I'm not worried about it.
I mounted the bulkhead from inside the fresh air vent. I know it looks weird with the good side hidden in the vent, but this will allow me to remove each of the connectors and make the connections with the hoses outside of the vent. Otherwise, I would not be able to get wrenches inside of the vent to tighten the connections. I originally wanted to put grommets in the bottom of the vent, but it was impossible to bend the AC and heater hoses.
Here is the bottom of the fresh air vent, where I will tighten each of the bulkhead connectors.
Here is how the AC and heater hose fittings will come out of the bottom of the fresh air vent.
I slowly keep banging away at it. Peace Out!
~ Dan
Old 03-05-2020, 10:17 PM   #87
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I like how you ran these. Have you fit the hoses on the interior yet?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 03-05-2020, 10:35 PM   #88
derotoreut
derotoreut's Avatar
I made up a couple of sections so far. I'm using VA's EZ-Clip system for my hoses, so I make them up myself. I'll get more pictures as I go along.
~ Dan
Old 03-06-2020, 02:09 AM   #89
Richard
Pretty cool what you have done there. Are you doing hard lines all the way into the engine compartment?
Richard
Old 03-06-2020, 11:36 PM   #90
derotoreut
derotoreut's Avatar
No I'm using VA's EZ-Clip hoses from the cab to the engine compartment.
~ Dan
Old 03-06-2020, 11:50 PM   #91
derotoreut
derotoreut's Avatar
I worked on installing my Derale transmission cooler. I bought the Derale model 52506, 25-row stack plate cooler.
(https://derale.com/product-footer/fl...-inlets-detail)
Here is the Derale cooler I bought
Today I made up a mount for the front of my condenser and core support.
I put in a couple of rivet nuts on the core support to attach the bracket.
Put the other bracket on and leveled out.
~ Dan
Old 03-06-2020, 11:56 PM   #92
derotoreut
derotoreut's Avatar
Installed the trans cooler.
Had to space out the bracket away from the condenser. I love using stainless button head screws.
This is the hose and fittings I'm planning to use.
~ Dan
Old 03-07-2020, 10:15 PM   #93
derotoreut
derotoreut's Avatar
I just got my Speed Engineering headers back. I sent them out and had them ceramic coated, black satin color. They did a good job and coated inside of the primaries and collector.
~ Dan
Old 03-12-2020, 03:13 PM   #94
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Question re the Pacific Fab x-member. Any reason to suspect it would not clear the differential on a stock height truck?
Old 03-12-2020, 03:35 PM   #95
derotoreut
derotoreut's Avatar
The short answer is YES. According to Pacific Fab, you need to either have new factory springs or install a 2" lift. If springs are old and sagging, they cannot guarantee it. I had old, original springs and one was actually cracked, which I didn't realize until I replaced them.
See the attached link, and the fine print at the bottom which states:
Not designed for 2wd vehicles.
Note: This crossmember is designed to be used with new factory springs. If your vehicles springs are worn out or sagging a 2" lift may be necessary for clearance to the front differential. Subject to availability.
http://pacificfabrication.com/63-72-...ssmembers.html
~ Dan
Old 03-12-2020, 09:27 PM   #96
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I had seen that. Thanks for confirming. Seems like a cleaner xmember than the DD example.
Old 03-12-2020, 09:30 PM   #97
derotoreut
derotoreut's Avatar
No problem. I'm really happy with it. You might be able to get away with using it if you have decent stock springs.
~ Dan
Old 03-12-2020, 09:36 PM   #98
derotoreut
derotoreut's Avatar
I worked a little bit on figuring out an upper radiator hose. I think I'm going to use two 45-degree elbows with a piece of 1-1/2" stainless connector in between.
~ Dan
Old 03-30-2020, 09:40 PM   #99
derotoreut
derotoreut's Avatar
I bought the Lokar firewall mount transmission dipstick for 4L60E. I hope the length of the dipstick inside the transmission is correct, since I don't have a stock one to gauge it to.
Marked off the location on the firewall and drilled and tapped it.
Install complete
~ Dan
Old 03-30-2020, 09:50 PM   #100
derotoreut
derotoreut's Avatar
A friend of mine owns a welding and fabrication company. He used his company's CNC machining center and made me this shifter boot ring for my NP205. It's made out of 3/8" aluminum, so it's thicker then the stock one. All other dimensions are the same. Pretty cool.
~ Dan
