Old 06-05-2020, 12:06 PM   #76
swissarmychainsaw
Re: Suburban A/C fix + Vintage Air?
I found this wire tucked away for safe keeping.
Is this the connector for the Compressor? If so, that good news!
Can anyone confirm? Ya'll bein' real quiet!
swissarmychainsaw is offline   Reply With Quote
Old 06-05-2020, 12:41 PM   #77
hatzie
Moderator
hatzie's Avatar
That looks like the connector used on some of the Harrison Frigidaire A6 and R4 compressors.
The wire colors are correct for that.
IIRC it's Packard 56 terminals inside a special connector shell.
When I convert over to the Sanden style compressor I run the ground through the High Pressure Cutout Switch and leave the LPCO in the hot as originally wired. You can run the HPCO in series with the LPCO but it's easier to put it in the ground side.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 06-05-2020, 02:25 PM   #78
swissarmychainsaw
Originally Posted by hatzie View Post
...Snip...
Thanks for this.
I just reached out to the supplier of my parts:
The modern compressor do not have any switches in them, so it is recommended to install one. Here is a link to a very easy to install switch kit.
https://www.originalair.com/ac-high-...tch-kit-o-ring
In your situation, it would need to be attached to the lower fitting of the condenser (#6) and then attach the hose directly to that.
Just ordered this, but I don't think it will get here in time for my vacation plans!
Old 06-05-2020, 03:09 PM   #79
hatzie
Moderator
hatzie's Avatar
Originally Posted by swissarmychainsaw View Post
Thanks for this.
You could get a crimp in pressure switch fitting and install in the hose right off the compressor head.
The compressor head fittings, be it a Sanden or one of the Harrison units, can be acquired with an HPCO threaded switch fitting... and even both LPCO & HPCO threaded switch fittings.
Old 06-05-2020, 03:18 PM   #80
swissarmychainsaw
Like this?
https://www.summitracing.com/parts/vta-24678-vus
So is the Low pressure switch a "binary" and the high pressure "trinary"?
Edit: Found this on "trinary switch" -- If you need to trigger an electric fan, use one!
https://www.youtube.com/watch?v=l604JCZx_ow
Old 06-05-2020, 04:21 PM   #81
swissarmychainsaw
Ok, now I'm scratching my head.
So I believe this to be a low pressure switch, can anyone confirm that?
Can I also use that unused "port" (with the black cap) for a high pressure trinary switch?
Old 06-05-2020, 06:01 PM   #82
hatzie
Moderator
hatzie's Avatar
That is indeed the LPCO switch.
The black capped fitting is the low pressure manifold gauge service connection.
The HPCO has to be in the high pressure side of the system. Usually right off the compressor in the high side line.
Old 06-06-2020, 02:27 PM   #83
swissarmychainsaw
Holy Cow, I ordered a Trinary switch from Summit Racing YESTERDAY and it's in the mailbox already. Less than 24 hours. Crazy.
Here we go!
Brackets for the condenser. I took the "install kit" cut it and bent it to use existing hols in the core support.
Final of the Condenser bracket install. Getting this all in there was the hardest part so far.
Old 06-06-2020, 06:14 PM   #84
swissarmychainsaw
The moment of truth:
The first crimp!
Now like 45 to go!
Mocking up:
Routing the hoses is harder than I thought it would be.
I don't want it to look like a cluster. Every combination looks weird!
Old 06-06-2020, 11:32 PM   #85
swissarmychainsaw
Running the lines and mocking things up before "the final crimpdown!"
Old 06-07-2020, 04:37 PM   #86
swissarmychainsaw
This gives me feelings of optimism:
Drain Hole from "kustom drain holes express"
yes, buy some extra length hose, just in case!
Aaaaand Here is the final mock up before all the crimpin' goes down.
Might not win a trophy, but if she blows cold, well, winning!
It looks like those hoses touch the belt in this pic, but there is plenty of room.
Old 06-07-2020, 11:12 PM   #87
swissarmychainsaw
Carry on my wayward son...
Ok so all crimped up and read to rock and roll.
Now for the bad news:
Never was able to pull more vacuum than this.
And after I shut it off, I lose vacuum.
So I have a leak in all my glorious crimps and connections.
What next?
Old 06-08-2020, 09:18 AM   #88
swissarmychainsaw
Seems the smart thing to do is to put some compressed air into the system and spray some soapy water the connections.
Here is a video that shows the procedure I used
https://www.youtube.com/watch?v=J6DSpx1V3Ms
Basically you put a rubber tipped air gun where the yellow vacuum pump hose goes, and pressurize the system, then with a spray bottle of soap and water get to squirting on your joints.
The great thing about air leaks is that you can *hear them!
So I found the leak!
This puppy was hissing air.
Now, no one in their right mind would put a junk yard Low Pressure Cut Off switch on their brand spanking new AC system...would they???
Next up, we put it back on the vacuum pump and see if it holds! Fingers crossed.
Old 06-08-2020, 12:41 PM   #89
jjzepplin
jjzepplin's Avatar
Hang in there! It's probably something simple. Check all your fittings for O rings and damaged O rings as well as switches.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-08-2020, 01:20 PM   #90
hatzie
Moderator
hatzie's Avatar
Make sure the Schraeder valve on the service port that's on the side of the accumulator isn't leaking.
Old 06-08-2020, 01:58 PM   #91
swissarmychainsaw
Let us know how the Mastercool Hydracrimp knockoff works.
This thing worked great, I think I only had to make a dozen crimps, but it worked very well. (So far not leaking).
Edit: I was looking at the mechanical (non-hydraulic) mastercool one, but decided on this one. I'm glad I did because at some point you will need to make a crimp in a hard to reach place and the hydraulic one is the no-brainer choice as it does not need to be held in a vise.
Old 06-08-2020, 06:19 PM   #92
swissarmychainsaw
Looks like you have a compressor cycling thermal cutoff switch with a capillary tube in the Evaporator. There should be a Low pressure cutoff switch on the accumulator as well. The aftermarket compressor and or hoses likely has provision for a high pressure cutout switch. If you're running R134a you'll want to add a HPCO switch in series with the LPCO and thermal switches because it has a tendency to run much higher pressures than R12 or HC blends.
I'd use a relay to offload the control amperage to the actual compressor clutch so the high amp load of engaging the electromagnet is run through an easy to replace $1.25 relay rather than the HVAC controls and the LPCO and Thermal switches.
Get a relay socket rather than using 1/4" disconnects. It makes the wiring job look better and it's much easier to replace the relay when and if it needs to be done.
Run a ground in series through the LPCO, HPCO, and Thermal switch to terminal 85 of a Mini ISO Bosch Automotive relay.
Run the Green AC compressor "on" wire from the HVAC control panel to terminal 86 of the same relay.
Run a 14ga wire through a 16ga fusible link or a 20A ATC fuse from the J stud on the firewall to the relay common terminal 30.
Run a 14ga wire from relay terminal 87 (normally open) to the actual compressor clutch plug.
I'm trying to get the wiring sorted out for the trinary switch and Vintage Air only used two colors of wires.
Does this look right?
Upper left Black wire: This is the Original ON green wire that passes through the Low Pressure switch. This wire originally would have plugged directly to the compressor.
Upper right blue wire: To terminal 86 (trigger) of the Fan relay.
Lower left blue: Keyed power.
Lower right black: to 86 (trigger) of Compressor relay.
Thanks for the help on this!
I have a new LPCO on order, I'm getting close!
Old 06-09-2020, 02:36 PM   #93
swissarmychainsaw
My fan relay has a part number on it. I went and bought another one just to have the instructions.
"Green Wire (Air conditioning override) ... attach the green wire to the A/C Clutch wire"
If I understand this correctly this means when the green wire gets power, the fan gets triggered. (you can't actually see where the wires are connected as they are epoxied together.
If this is true then I don't have to hook up the blue wires of the Trianary switch.
Key On:
I just connected the Green wire to the battery assuming that putting voltage to that wire would trigger the fan to come on.
Nothing happened.
I'm kinda lost on this wiring setup.
Here is why my jumble jangle switch looks like.
I need to spend some time and clean up all the janky wiring the PO left behind.
Old 06-10-2020, 09:35 AM   #94
swissarmychainsaw
I had a couple issues getting the right LPCO switch, and once I got it, I had trouble getting it to seal. Pro Tip: hand tight only!
Also the rear blower was hitting the case so I had to pull that down and align the motor better.
First I was going to trim it:
The fix was to undo the one bolt on the fan clamp and slide it over a bit so the blades fit in the case properly without rubbing.
Test before you hang it!
Otherwise system is now holding pressure, today I'm getting the wiring sorted out, and hopefully put some charge to it!
Old 06-10-2020, 12:02 PM   #95
jjzepplin
jjzepplin's Avatar
Yeehaw!
Old 06-10-2020, 01:18 PM   #96
SCOTI
SCOTI's Avatar
Persistence!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-11-2020, 12:33 PM   #97
swissarmychainsaw
Thanks for the encouragement fellas!
This seems really simple when I draw up this pic, but it took me a while to get there.
Thanks to @hatzie for suggesting this wiring strategy of using a relay for the compressor!
Not shown is the relay and switch for the rear AC Blower.
This means the wiring is now hooked up, and I can potentially run the system today.
Is today THE DAY?
I'm sure there are about 30 things that need buttoning up, but I'm going for it!
Here is some wiring for your enjoyment, not many folks appreciate a good crimp!
A little wire loom makes those wires look a lot better:
This is when you know you should step away from the heat gun.
Old 06-11-2020, 12:42 PM   #98
jjzepplin
jjzepplin's Avatar
FANcy!
Old 06-11-2020, 12:58 PM   #99
swissarmychainsaw
I need to add about 3 oz of PAG oil to this system.
I arrived at that number by looking at the manual and talking to the sales/tech, the original system (with dual AC!) had 3 oz more then the since evap system.
So assuming the compressor has enough oil in it for a single AC system, we then will add 3 oz for a dual.
How should I add the oil?
I need to pull a vacuum on it anyway, so it's open, now.
I'm seriously considering opening one of the rear lines and just pouring 3 oz in.
Considering the rear lines are 15 feet long, I don't think it should be a problem.
Old 06-11-2020, 06:21 PM   #100
swissarmychainsaw
Wiring done enough to run the system
Only add to the high pressure (discharge) side or your compressor will suck in liquid oil and the sun will stop spinning in the sky!
Make sure you have a good assistant!
Right now, we are pulling a vacuum and double checking Last Time for leaks!
