89 S10 4.3 misfire
What do think of these readings??
Cyl 1 - 130 - Wet 140 Cyl 2 - 135 - Wet 155 Cyl 3 - 120 - Wet 130 Cyl 4 - 150 - Wet 160 Cyl 5 - 140 - Wet 150 Cyl 6 - 125 - Wet 130
1990 Chevy Suburban v2500 1990 Chevy/Geo Tracker LSi 4x4 2Dr 1996 Chevy/Geo Tracker LSI 4x4 4Dr 2011 Chevy Silverado Crew Cab LT 1991 Nissan 300zx SlickTop |
#2 | |
Moderator
![]() Join Date: Jun 2017
Re: 89 S10 4.3 misfire
These readings are indicative of a well used engine... The variance between dry and wet are about standard, with the exception of cyl 2 which has some ring sealing issues. Cyl 4 is the only one with a reasonable result.... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
![]() Join Date: Jan 2001
They're probably not directly related to your misfire. While some of them are low, early gasoline engines ran with 5:1 compression ratios.
However, as Aussie said, #2 readings indicate you may have some blow-by, causing spark plug fouling. How does that plug look?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
We have pulled the plugs and none of them stuck out from another. All looked fairly normal. No smoke from the tail pipe. We have changed the plugs and wires a few days ago. We did notice, after starting the truck a few minutes after running, the exhaust smells like raw fuel. The hard misfire is only present at idle, and moving from a stop. The truck can cruse on freeway going 70mph no problem. We have found a good used (Compression tested) engine a county over with 98k miles for $450. Might be way to go
I put quite a few hundred thousand kms on those. I think I changed at least three coils on the 90. One quit in the intersection and I had it changed before AMA arrived. They don't always quit outright. Keep a spare.
We tried the MSD coil out of my 90 Suburban and the mis is still present
Moderator
This sounds like a leaky fuel injector...dribbling fuel into throttle body causing over rich mix flooding a plug or 2....
Grab a couple of second hand injectors from a wrecking yard and try it,,,they are not that expensive to buy new. ![]() ![]() ![]()
Tried another set of injectors, problem remains. Time to get another engine.
![]() Join Date: Oct 2005
If it has a vacuum outlet on the back part of the intake manifold, a vacuum leak can cause a misfire like that. Check power brake booster & trans modulator & a/c vacuum resavoir.
George |
Two of the three 4.3's I had leaked coolant into the rear left combustion chamber but you would have noticed that sooner it its life.
Tags |
4.3, compression test, misfire |
