07-13-2020, 04:04 PM | #1 |
Re: Steering column height
I appreciate the advice. There is no moving that column, however. It will not budge a millimeter. Guess I'm looking at shims. I may get a piece of steel stock in the thickness I need and cut it to the outline of the steering box where it touches the frame.
07-13-2020, 04:18 PM | #2 |
Depending on how original you want to keep the truck, aftermarket column drops are available in various lengths. They are made to do exactly what you're trying to accomplish. This one is available from Brothers:
1951 Chevy Panel Truck |
07-13-2020, 04:40 PM | #3 | |
did you rebuild the floor of your truck? did you put rubber between the front cab mount and the cab? did you change out your rear cab mounts? are the rear cab mounts sagging? I would look from the side and see if your cab is maybe a little low in the rear. you could take the rear body mounts loose and use two jacks one on each side of the back of the cab, and lift the rear slightly. the gap might close up a little. if it doesnt, you might have your front floor 1/2" too low. I hate those columns, by the way, I always end up cutting them in half because taking the cab off the frame is a gigantic pain.
07-13-2020, 04:49 PM | #4 | |
07-13-2020, 11:09 PM | #5 | |
