07-26-2020, 01:10 PM | #1 |
72 th350 np203 swap to th400 np205
i've currently got a mild 454 engine th350 np203 in my 72 k10 i'm restoring the engine is moved 2 inches forward driveshafts have been shortened in the front lenghtened in the rear well now i'm considering swaping my driveline out for a th400 np205 out of a 79 k20 i guess i'm looking for anyone thats done this before to see what all its going to take to make it work
07-26-2020, 04:35 PM | #2 |
Re: 72 th350 np203 swap to th400 np205
Is the 400 already mated to the 205? That's the biggest issue.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-26-2020, 05:08 PM | #3 |
Do you have measurements of both from engine/bellhousing mating surface to yoke on transfer case? So you still have the slip-yoke on the 203 tail? Got pictures at least? I assume the '79 NP205 has the fixed yoke. I'm not familiar with your set-up in there now. M=Never seen anyone put a 203 in a '72 before. Where is the crossmember located, original position?
07-26-2020, 05:58 PM | #4 |
the th400 and np205 are together my current np203 is fixed yoke i've already swaped it to 1350 u joints i just didn't know if anyone had done this swap already and what they had to change
07-26-2020, 06:59 PM | #5 |
It is all bolt up stuff. Remove the 350/203 combo. Bolt in the 400/205. The trans lines will bolt up with just a little manipulation. torque convertor will bolt up -no issues. You may/will have to drill the frame for the x-member moving back (that will probably be the biggest deal). T-case shifter hole will move back a little, so a floor pan cut and repair (covered by carpet). Shifter from column will bolt up with a small adjustment. Driveshafts both front and rear rebuilt. Overall it is a pretty easy deal
07-26-2020, 09:04 PM | #6 |
All about them Ks
Everyone else already gave good advice here, all I can say is you probably won’t regret ditching the 203. The other thing your also gonna have to address is the electric kick down switch for the th400, again another easy hurdle to cross.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-26-2020, 09:44 PM | #7 |
whats the kickdown amount to just a switch on the carb linkage that tells it when its wot?i'm i kind of go shape i guess cause i could probably just move the crossmember back where it was and i've got a b&m floor shifter thats cable controlled just sucks i have my driveshafts the right lenght for my current setup
07-27-2020, 01:01 AM | #8 |
The np203 case is from a 73 up square body truck 67 to 69 our trucks used a rockwell case some 69s may have had a np205 stock
70 72 have np205 as stock transfer case T400 better tranny and np205 are fairly bullet proof Stock engine placement for 67 72 k series trucks is the back set of engine mount holes The reason behind this is so the diff does not have clearance issues with either the cross member or the oil pan Talking with my cousin on his 69 big block build he kept it in the back frame holes for two reasons center the weight more and to have more header clearance |
07-27-2020, 01:05 AM | #9 |
07-27-2020, 10:56 AM | #10 | |
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
07-27-2020, 06:23 PM | #11 |
All about them Ks
The kickdown switch mounts on the gas pedal mount bracket On the 67-72 trucks. Yea basically it tells the transmission to grab another gear when you mash the skinny pedal.
07-27-2020, 07:08 PM | #12 |
well scratch that it wasn't a turbo 400 is was a turbo 350 he didn't know what he had
07-28-2020, 07:22 PM | #13 |
So are you still going to swap in the NP205 ?
07-28-2020, 09:51 PM | #14 |
Don't let that 205 get away! Buy the combo if you have to and you'll have a spare TH350 lying around - you know to sell that NP203 with
07-28-2020, 10:07 PM | #15 |
All about them Ks
Thats the best advice of this thread!
