Old 06-24-2020, 07:39 PM   #76
tdishon
Re: 59 Apache/C6 Corvette build
Here we go. Getting busy on this project again. Bed mounted and fenders widened. Step is a little work.
Current project: 59 Apache with 2012 Corvette drivetrain
Jeep Trackhawk(beast)
tdishon is offline   Reply With Quote
Old 06-25-2020, 07:52 AM   #77
youngrodder
youngrodder's Avatar
Nice job on the fenders...it looks stock
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 06-25-2020, 11:30 AM   #78
tdishon
We added 1.5" and it looks very stock to the naked eye. I needed the room for the factory offset Corvette wheel. I was able to get a p355 tire on the 19x12.
Old 06-26-2020, 10:29 AM   #79
Rickysnickers
Wow, that fender work is phenomenal!
Old 06-26-2020, 12:48 PM   #80
joedoh
joedoh's Avatar
beautiful fab!
Old 07-14-2020, 06:48 PM   #81
tdishon
Here is a pic looking back. Hard to tell it's 1.5" wider.
Old 07-23-2020, 11:14 PM   #82
tdishon
Getting bed floor situated. Need a 4" floor lift and decided to have a tilt up floor.
I had my old tailgate and thought the script would look good on the back of the floor lift.
Old 07-24-2020, 09:39 AM   #83
youngrodder
Nice detail on the rear bed sill. Looking good..
Marc
Old 07-24-2020, 10:32 PM   #84
duramax55
where did you get your tailgate release from ????? first time i see one like that awsome
duramax55 is offline   Reply With Quote
Old 07-24-2020, 10:34 PM   #85
tdishon
Mar-k. Very nice quality. The whole bed is from them.
The tailgate has two bear claw latches and works smooth.
Old 08-01-2020, 05:46 PM   #86
tdishon
Bed floor coming together.
Old 08-01-2020, 08:37 PM   #87
slammed57
slammed57's Avatar
beautiful fab work sir!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 08-09-2020, 06:23 PM   #88
BLAC
BLAC's Avatar
Looks great! is that bed tilt setup a kit or did you fab that? I just ordered a couple "bed tonneau cover" gas struts and a couple ball mounts... not sure if its going to work until Mr Amazon drops it off
1959 Apache Fleetside Short Bed
BLAC is offline   Reply With Quote
Old 08-13-2020, 10:46 PM   #89
tdishon
It's not a kit. We are building a design we laid out on paper with Camaro trunk hinges and an electric assisted bear claw latch. The rest is 1" square tubing. The bed wood will attach with Mar-k strips and some threaded wood inserts from the underside. I didn't want to use the L strip on the bed sides. I wanted to have the wood bump up to the sides with no carriage bolts.
Old 08-22-2020, 09:35 PM   #90
tdishon
Tilt bed framing done and working. I have several rubber adjusters in several places that keep all squeeks away.
Old 08-23-2020, 06:20 PM   #91
Jason 56
Truck is looking great! Your fab work is top notch!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 08-23-2020, 11:01 PM   #92
tdishon
Thanks, Moving on to do the wood in the bed next.
Old 08-24-2020, 09:06 AM   #93
Rickysnickers
Wow, amazing work!!!
Old 08-25-2020, 08:03 PM   #94
joedoh
joedoh's Avatar
meaty!
Old 11-10-2020, 12:28 PM   #95
tdishon
Bed floor dialed in and done. Ready for wood. Added 60lb gas struts to lift and keep from lifting all the way up. Quick disconnects make lifting all the way up easy. I kept the gas helpers on the hinge, they keep it straight up when I remove the long struts.
Old 11-10-2020, 04:36 PM   #96
daveshilling
daveshilling's Avatar
Can I just shamelessly steal this entire setup?
daveshilling is offline   Reply With Quote
Old 11-22-2020, 06:16 PM   #97
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice job on the tilt bed floor!
ChuckDriver is offline   Reply With Quote
Old 11-23-2020, 02:37 PM   #98
Russell Ashley
Russell Ashley's Avatar
I just read back through this entire thread and all I can say is "WOW". And that 55 Plymouth grill looks right at home in this truck.
Russell Ashley is offline   Reply With Quote
Old 01-17-2021, 08:33 PM   #99
tdishon
Update
Old 01-18-2021, 11:19 AM   #100
Rickysnickers
Looking good!
